楼主:
[基础教程] (20180630更新)Ubuntu安装HomeAssistant教程(ubuntu17.10无坑版)
发表于 2020-3-26 21:33:44 | 显示全部楼层
写的很详细,学习了,谢谢分享
发表于 2020-5-1 11:01:29 | 显示全部楼层
想请教一下已经安装完成启动了,查看状态也正常,为什么通过IP地址加8123无法通过浏览器查看呢?
[email protected] - Home Assistant
   Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2020-05-01 10:40:35 CST; 11min ago
 Main PID: 11263 (hass)
    Tasks: 21 (limit: 4313)
   CGroup: /system.slice/system-home\x2dassistant.slice/[email protected]
           └─11263 /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/bin/hass -c /home/homeassistant/.homeassistant
5月 01 10:40:40 water-virtual-machine hass[11263]: 2020-05-01 10:40:40 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
5月 01 10:40:40 water-virtual-machine hass[11263]: 2020-05-01 10:40:40 INFO (MainThread) [homeassistant.setup] Setting up logbook
5月 01 10:40:40 water-virtual-machine hass[11263]: 2020-05-01 10:40:40 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
5月 01 10:40:40 water-virtual-machine hass[11263]: 2020-05-01 10:40:40 INFO (MainThread) [homeassistant.setup] Setting up default_config
5月 01 10:40:40 water-virtual-machine hass[11263]: 2020-05-01 10:40:40 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds.
5月 01 10:40:42 water-virtual-machine hass[11263]: 2020-05-01 10:40:42 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 5.77s
5月 01 10:40:42 water-virtual-machine hass[11263]: 2020-05-01 10:40:42 WARNING (MainThread) [homeassistant.bootstrap] Python 3.6 support is deprecated and will
5月 01 10:40:42 water-virtual-machine hass[11263]: 2020-05-01 10:40:42 INFO (MainThread) [homeassistant.core] Starting Home Assistant
5月 01 10:40:42 water-virtual-machine hass[11263]: 2020-05-01 10:40:42 INFO (SyncWorker_3) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
5月 01 10:40:42 water-virtual-machine hass[11263]: 2020-05-01 10:40:42 INFO (MainThread) [homeassistant.core] Timer:starting
直接ping这个地址也ping不通。
/$ ping 192.168.1.104:8123
ping: 192.168.1.104:8123: Name or service not known
发表于 2020-9-24 14:24:52 | 显示全部楼层
Ubuntu 20.04.1 LTS 版本系统。按照楼主的步骤顺利完成安装。
发表于 2021-4-16 15:48:04 | 显示全部楼层
谢谢分享
发表于 2021-7-2 08:55:57 | 显示全部楼层
坑死人啊
不行了
发表于 2024-2-1 17:10:33 | 显示全部楼层
好东西,学习
GMT+8, 2025-6-24 09:59 , Processed in 0.116095 second(s), 27 queries .
