楼主:
[基础教程] (20180630更新)Ubuntu安装HomeAssistant教程(ubuntu17.10无坑版)
发表于 2019-7-13 01:26:27 | 显示全部楼层
支持支持
发表于 2019-7-15 06:32:29 | 显示全部楼层
发表于 2019-7-15 10:04:58 | 显示全部楼层
跟大神学习
发表于 2019-8-4 10:32:35 | 显示全部楼层
然后装好以后的配置文件在哪?
发表于 2019-8-7 14:05:07 | 显示全部楼层
感谢教程,学习大神
发表于 2019-8-14 14:29:00 | 显示全部楼层
感谢分享!值得学习!
发表于 2019-10-30 10:25:31 | 显示全部楼层
成功之后 status里面 Active:active(running)
否则是fail
发表于 2019-11-22 10:15:13 | 显示全部楼层
谢谢分享
发表于 2019-12-18 16:55:53 | 显示全部楼层
ERROR: Command errored out with exit status 1:
   command: /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmpi8_q5muz
       cwd: /tmp/pip-install-o6iizguk/cryptography
  Complete output (137 lines):
  running bdist_wheel
  running build
  running build_py
  creating build
  creating build/lib.linux-i686-3.6
  creating build/lib.linux-i686-3.6/cryptography
  copying src/cryptography/fernet.py -> build/lib.linux-i686-3.6/cryptography
  copying src/cryptography/exceptions.py -> build/lib.linux-i686-3.6/cryptography
  copying src/cryptography/__init__.py -> build/lib.linux-i686-3.6/cryptography
  copying src/cryptography/utils.py -> build/lib.linux-i686-3.6/cryptography
  copying src/cryptography/__about__.py -> build/lib.linux-i686-3.6/cryptography
  creating build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/oid.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/name.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/extensions.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/base.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/__init__.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/certificate_transparency.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/general_name.py -> build/lib.linux-i686-3.6/cryptography/x509
  copying src/cryptography/x509/ocsp.py -> build/lib.linux-i686-3.6/cryptography/x509
  creating build/lib.linux-i686-3.6/cryptography/hazmat
  copying src/cryptography/hazmat/_der.py -> build/lib.linux-i686-3.6/cryptography/hazmat
  copying src/cryptography/hazmat/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat
  copying src/cryptography/hazmat/_oid.py -> build/lib.linux-i686-3.6/cryptography/hazmat
  creating build/lib.linux-i686-3.6/cryptography/hazmat/bindings
  copying src/cryptography/hazmat/bindings/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings
  creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/padding.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/constant_time.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hashes.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/cmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/keywrap.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/poly1305.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  copying src/cryptography/hazmat/primitives/hmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives
  creating build/lib.linux-i686-3.6/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/interfaces.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends
  copying src/cryptography/hazmat/backends/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends
  creating build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/binding.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/_conditional.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
  copying src/cryptography/hazmat/bindings/openssl/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/bindings/openssl
  creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/padding.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/dh.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/rsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/x25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ec.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/utils.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  copying src/cryptography/hazmat/primitives/asymmetric/ed25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/asymmetric
  creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/ssh.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/pkcs12.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/base.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
  copying src/cryptography/hazmat/primitives/serialization/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/serialization
  creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/aead.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/modes.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/algorithms.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/base.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
  copying src/cryptography/hazmat/primitives/ciphers/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/ciphers
  creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/concatkdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/hkdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/x963kdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/kbkdf.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/pbkdf2.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  copying src/cryptography/hazmat/primitives/kdf/scrypt.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/kdf
  creating build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/utils.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/hotp.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
  copying src/cryptography/hazmat/primitives/twofactor/totp.py -> build/lib.linux-i686-3.6/cryptography/hazmat/primitives/twofactor
  creating build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/encode_asn1.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/aead.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x509.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hashes.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/decode_asn1.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/cmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/backend.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/dh.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ciphers.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed448.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/rsa.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/x25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ec.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/__init__.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/utils.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/poly1305.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/hmac.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ocsp.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  copying src/cryptography/hazmat/backends/openssl/ed25519.py -> build/lib.linux-i686-3.6/cryptography/hazmat/backends/openssl
  running egg_info
  writing src/cryptography.egg-info/PKG-INFO
  writing dependency_links to src/cryptography.egg-info/dependency_links.txt
  writing requirements to src/cryptography.egg-info/requires.txt
  writing top-level names to src/cryptography.egg-info/top_level.txt
  reading manifest file 'src/cryptography.egg-info/SOURCES.txt'
  reading manifest template 'MANIFEST.in'
  no previously-included directories found matching 'docs/_build'
  warning: no previously-included files found matching 'vectors'
  warning: no previously-included files matching '*' found under directory 'vectors'
  warning: no previously-included files found matching 'azure-pipelines.yml'
  warning: no previously-included files found matching '.azure-pipelines'
  warning: no previously-included files found matching '.travis.yml'
  warning: no previously-included files found matching '.travis'
  warning: no previously-included files matching '*' found under directory '.azure-pipelines'
  warning: no previously-included files matching '*' found under directory '.travis'
  warning: no previously-included files found matching 'release.py'
  warning: no previously-included files found matching '.coveragerc'
  warning: no previously-included files found matching 'codecov.yml'
  warning: no previously-included files found matching 'dev-requirements.txt'
  warning: no previously-included files found matching 'rtd-requirements.txt'
  warning: no previously-included files found matching 'tox.ini'
  writing manifest file 'src/cryptography.egg-info/SOURCES.txt'
  running build_ext
  generating cffi module 'build/temp.linux-i686-3.6/_padding.c'
  creating build/temp.linux-i686-3.6
  generating cffi module 'build/temp.linux-i686-3.6/_constant_time.c'
  generating cffi module 'build/temp.linux-i686-3.6/_openssl.c'
  building '_openssl' extension
  creating build/temp.linux-i686-3.6/build
  creating build/temp.linux-i686-3.6/build/temp.linux-i686-3.6
  i686-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/homeassistant_venv/include -I/usr/include/python3.6m -c build/temp.linux-i686-3.6/_openssl.c -o build/temp.linux-i686-3.6/build/temp.linux-i686-3.6/_openssl.o -Wconversion -Wno-error=sign-conversion
  build/temp.linux-i686-3.6/_openssl.c:498:10: fatal error: openssl/opensslv.h: No such file or directory
   #include <openssl/opensslv.h>
  compilation terminated.
  error: command 'i686-linux-gnu-gcc' failed with exit status 1
  ERROR: Failed building wheel for cryptography
  Running setup.py clean for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
发表于 2020-2-1 00:04:37 | 显示全部楼层
请教  esxi ubuntu server19.4版HomeAssistant安装教程
GMT+8, 2025-12-29 08:20 , Processed in 1.525939 second(s), 16 queries , MemCached On.
