查看: 2030|回复: 3
[基础教程] 改造用ESPHOME改了Orvibo的红外遥控
发表于 2024-10-1 08:08:32 | 显示全部楼层 |阅读模式
Orvibo的红外遥控是8266的芯片。然后各种找资料代码如下:顺便说下。我主要是玩悟空的时候电视机少了遥控器属于整了这
substitutions:
  device_name: "ESP8266IR"
  run_time: 15s       # 运行时间
  sleep_time: 44s     # 休眠时间
esphome:
  friendly_name: ESP8266
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "kWLEm1CRtH1ikbQDKedCshqelOhhhwzfgVGUDtVoPZo="
ota:
  - platform: esphome
    password: "580f85d3239973eb61506976578f0a09"
wifi:
  ssid: !secret wifi_ssid
  # fast_connect: True
  reboot_timeout: 300s
  manual_ip:
    static_ip: 192.168.1.188
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 183.221.253.100
web_server:
  port: 80
captive_portal:
script:
  - id: opne_changhong_hdmi
    then:
      - button.press: but_chpower
      - delay: 60s
      - button.press: but_chsource
      - delay: 1s
      - button.press: but_menu
  - id: close_changhong_hdmi
    then:
remote_transmitter:
  - id: IR_transmitter
    pin: GPIO14   #红外引脚
    carrier_duty_percent: 50%
remote_receiver:
  - id: IR_receiver
    pin:
      number: GPIO5 #红外接收引脚
      inverted: True
    dump:
    - raw
    - nec
status_led:
  pin: GPIO15
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO4
      inverted: true
button:
  - platform: template
    icon: mdi:power
    on_press:
      - script.execute: opne_changhong_hdmi
  # Received NEC: address=0x3000, command=0xFD02 command_repeats=1
    icon: mdi:power
    on_press:
      - remote_transmitter.transmit_nec:
          address: 0x3000
          command: 0xFD02
          command_repeats: 1
    icon: mdi:menu
    on_press:
          address: 0x3000
          command: 0xEA15
          command_repeats: 1
    icon: mdi:power
    on_press:
          address: 0xBF40
          command: 0xED12
          command_repeats: 1
    icon: mdi:source-branch
    on_press:
          address: 0xBF40
          command: 0xEB14
          command_repeats: 1
    icon: mdi:volume-plus
    on_press:
          address: 0xBF40
          command: 0xE51A
          command_repeats: 1
    icon: mdi:volume-minus
    on_press:
          address: 0xBF40
          command: 0xE11E
          command_repeats: 1
    icon: mdi:volume-mute
    on_press:
          address: 0xBF40
          command: 0xEF10
          command_repeats: 1
    icon: mdi:menu-left
    on_press:
          address: 0xBF40
          command: 0xB946
          command_repeats: 1
    icon: mdi:menu-right
    on_press:
          address: 0xBF40
          command: 0xB847
          command_repeats: 1
    icon: mdi:menu-up
    on_press:
          address: 0xBF40
          command: 0xE619
          command_repeats: 1
    icon: mdi:menu-down
    on_press:
          address: 0xBF40
          command: 0xE21D
          command_repeats: 1
    icon: mdi:menu
    on_press:
          address: 0xBF40
          command: 0xF50A
          command_repeats: 1
# Received NEC: address=0xBF40, command=0xED12 command_repeats=1
# Received NEC: address=0xBF40, command=0xEB14 command_repeats=1
# Received NEC: address=0xBF40, command=0xB847 command_repeats=1
# Received NEC: address=0xBF40, command=0xB946 command_repeats=1
# Received NEC: address=0xBF40, command=0xE619 command_repeats=1
# Received NEC: address=0xBF40, command=0xE21D command_repeats=1
# Received NEC: address=0xBF40, command=0xF50A command_repeats=1
# Received NEC: address=0xBF40, command=0xEF10 command_repeats=1
发表于 2024-10-1 10:31:46 | 显示全部楼层
   on_press:
这行代码 什么意思 ,后面的是遥控器代码 这个我知道
如果 还要添加 其它遥控器 怎么添加???
怎么添加??
你这个是一个设备的 遥控器 代码 ,一些功能键的代码。
比如我要添加 电视盒子 投影机 空调 怎么添加 设备
发表于 2024-10-1 10:53:19 | 显示全部楼层
lifesmart 超级碗 提示,没有OTA 足够的 空间!
 楼主| 发表于 2024-10-3 11:27:28 | 显示全部楼层
tanbobo 发表于 2024-10-1 10:31
on_press:
这个是个脚本,我玩游戏需要切换信号源到HDMI。这个电视没有开机自动切换所以我就弄了这
GMT+8, 2026-1-8 05:18 , Processed in 1.133883 second(s), 10 queries , MemCached On.
