查看: 1642|回复: 4
[求助] yaml代码报错
发表于 2024-9-26 13:38:09 | 显示全部楼层 |阅读模式
#实时统计此时未知用电功率(未扣除弱电)
  - platform: template
    sensors:
      delta_power:
        unique_id: "delta_power"
        friendly_name:   "delta_power"
        unit_of_measurement: W
        icon_template: mdi:lightning-bolt
        value_template: >
          {% set P = states('sensor.ju_wei_dian_neng_bao_xi_lie_at2pl_gr2p_power') | float %}
          {% set P1 = states('sensor.ykcn_cbcsmj_d0d2_electric_power') | float %}
          {% set P2 = states('sensor.ykcn_cbcsmj_3979_electric_power') | float %}
          {% set P3 = states('sensor.ykcn_cbcsmj_d2f4_electric_power') | float %}
          {% set P4 = states('sensor.ykcn_cbcsmj_356f_electric_power') | float %}
          {% set P5 = states('sensor.ykcn_cbcsmj_d264_electric_power') | float %}
          {% set P6 = states('sensor.ykcn_cbcsmj_e887_electric_power') | float %}
          {% set P7 = states('sensor.zimi_zncz01_1c5f_electric_power_2') | float % }
          {% set P8 = states('sensor.zimi_zncz01_fe85_electric_power_2') | float % }
          {{ P - P1 - P2 - P3 - P4 - P5 - P6 - P7 - P8 }}
这样写有问题吗?怎么老是识别不了?
发表于 2024-9-26 15:18:03 | 显示全部楼层
其他不清楚,你试试unique_id用这网站生成的格式,https://www.uuidgenerator.net/
发表于 2024-9-27 10:45:31 | 显示全部楼层
试下这个
  sensors:
    delta_power:
      value_template: >
        {% set P7 = states('sensor.zimi_zncz01_1c5f_electric_power_2') | float %}
        {% set P8 = states('sensor.zimi_zncz01_fe85_electric_power_2') | float %}
        {% if P >= 0 and P1 >= 0 and P2 >= 0 and P3 >= 0 and P4 >= 0 and P5 >= 0 and P6 >= 0 and P7 >= 0 and P8 >= 0 %}
        {% else %}
        {% endif %}
 楼主| 发表于 2024-9-27 13:48:33 | 显示全部楼层
识别出来了~!!感谢大神~可是为什么要设置P必须得>0呢
 楼主| 发表于 2024-9-27 14:42:46 | 显示全部楼层
原来是有时候返回了null,只要吧这个null转成0应该也行。
GMT+8, 2025-12-17 16:53 , Processed in 0.969792 second(s), 10 queries , MemCached On.
