查看: 1254|回复: 1
[求助] 兄弟们~~ 这个错误如何解决?
发表于 2024-9-23 10:30:58 | 显示全部楼层 |阅读模式
githome集虹零火开关 zigbee2mqtt 里开关不能控制,
这个开关在z2m里能正常识别并自动配置成功,但识别成 livolo:Livolo TI0001 control via MQTT | Zigbee2MQTT   ,买自咸鱼卖家,但卖家也不知道怎么解决,需要重写配置文件吗?
现在能正常识别成功,写配置文件还能生效吗?
补充日志中的错误信息:
error 2024-09-22 16:03:16z2m: EventBus error 'Publish/mqttMessage': Cannot read properties of undefined (reading 'ID')
info 2024-09-22 16:04:35z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/gh01', payload '{"linkquality":105,"state_bottom_left":null,"state_bottom_right":null,"state_left":"ON","state_right":"OFF"}'
info 2024-09-22 16:04:51z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/gh01', payload '{"linkquality":120,"state_bottom_left":null,"state_bottom_right":null,"state_left":"OFF","state_right":"OFF"}'
error 2024-09-22 16:06:07z2m: EventBus error 'Publish/mqttMessage': Cannot read properties of undefined (reading 'ID')
error 2024-09-22 16:06:09z2m: Publish 'set' 'scene_store' to 'gh01' failed: 'Error: Scene ID 0 cannot be used with group ID 0 (reserved).'
error 2024-09-22 16:11:58z2m: Publish 'set' 'scene_remove_all' to 'gh01' failed: 'Error: ZCL command 0x00124b000ff6a9ef/8 genScenes.removeAll({"groupid":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 33510 - 8 - 58 - 5 - 3 after 10000ms)'
warning 2024-09-22 16:12:22zhc:tz: Unknown scene was recalled for 0x00124b000ff6a9ef, can't restore state.
开关图片引用卖家的图片
 楼主| 发表于 2024-9-23 10:36:50 | 显示全部楼层
z2m 中的 日志信息 已补充;
GMT+8, 2025-12-17 16:50 , Processed in 1.042852 second(s), 7 queries , MemCached On.
