查看: 1609|回复: 1
[求助] esp-01s做继电器开,老是自动重启?求解
发表于 2024-9-22 22:35:42 | 显示全部楼层 |阅读模式
我刷得是tasmota固件,设置如下:
22:30:53.308 QPC: Reset          重点是这里,为什么他会重启。。。。
我是用充电器5v供电的,很稳定的,不知道为什么esp-01s老是重启。
通电日志如下:
00:00:00.001 HDW: ESP8266EX
00:00:00.054 CFG: 从 flash 载入: F7, 数量: 445
00:00:00.060 QPC: Count 1
00:00:00.071 项目: tasmota - dadroomlight 版本 14.2.0.3(fade4f8-tasmota)-2_7_7(2024-09-07T13:45:33)
00:00:01.001 WIF: 连接到 AP1 MyDreamHome2_24 Channel 11 BSSId 48:814C:CF:E7 模式: 11n 名称: dadroomlight...
00:00:02.512 WIF: 已连接
00:00:02.764 HTP: Web 服务器地址: dadroomlight IP 地址: 192.168.5.224
22:30:50.411 MQT: 尝试连接...
22:30:51.010 MQT: 已连接
22:30:51.014 MQT: tele/dadroomligth_4A7DA0/LWT = Online (已保留)
22:30:51.017 MQT: cmnd/dadroomligth_4A7DA0/POWER =
22:30:51.026 MQT: tele/dadroomligth_4A7DA0/INFO1 = {"Info1":{"Module":"Generic","Version":"14.2.0.3(fade4f8-tasmota)","FallbackTopic":"cmnd/DVES_4A7DA0_fb/","GroupTopic":"cmnd/tasmotas/"}}
22:30:51.035 MQT: tele/dadroomligth_4A7DA0/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"dadroomlight","IPAddress":"192.168.5.224"}}
22:30:51.054 MQT: tele/dadroomligth_4A7DA0/INFO3 = {"Info3":{"RestartReason":{"Exception":0,"Reason":"Exception","EPC":["4027a18b","00000000","00000000"],"EXCVADDR":"0000000c","DEPC":"00000000","CallChain":["4027a11a","401039e6","40105d6a","40105d4c","40258e2f","401027ac","400005e1","40258e2f","40258ebc","40103a20","40100b38","40252f36","401012c2","40252f70","402280b2","401061c5","401012c2","401012c2","40258ebc","40252178","4022cd4d","40243108","40100b38","40252fb4","40101f51"]},"BootCount":126}}
22:30:51.094 MQT: stat/dadroomligth_4A7DA0/RESULT = {"OWER":"OFF"}
22:30:51.097 MQT: stat/dadroomligth_4A7DA0/POWER = OFF
22:30:52.139 MQT: stat/dadroomligth_4A7DA0/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota/release/tasmota-CN.bin.gz","RestartReason":"Exception","Uptime":"0T00:00:07","StartupUTC":"2024-09-22T14:30:45","Sleep":50,"CfgHolder":4617,"BootCount":125,"BCResetTime":"2024-09-16T04:42:16","SaveCount":445,"SaveAddress":"F7000"}}
22:30:52.191 MQT: stat/dadroomligth_4A7DA0/RESULT = {"Time":"2024-09-22T22:30:52","Uptime":"0T00:00:07","UptimeSec":7,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":38,"MqttCount":1,"OWER":"OFF","Wifi":{"AP":1,"SSId":"MyDreamHome2_24","BSSId":"48:814C:CF:E7","Channel":11,"Mode":"11n","RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:04"}}
22:30:52.294 MQT: stat/dadroomligth_4A7DA0/STATUS11 = {"StatusSTS":{"Time":"2024-09-22T22:30:52","Uptime":"0T00:00:07","UptimeSec":7,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":40,"MqttCount":1,"OWER":"OFF","Wifi":{"AP":1,"SSId":"MyDreamHome2_24","BSSId":"48:814C:CF:E7","Channel":11,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}}
22:30:55.242 MQT: tele/dadroomligth_4A7DA0/STATE = {"Time":"2024-09-22T22:30:55","Uptime":"0T00:00:10","UptimeSec":10,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"OWER":"OFF","Wifi":{"AP":1,"SSId":"MyDreamHome2_24","BSSId":"48:814C:CF:E7","Channel":11,"Mode":"11n","RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:04"}}
22:30:55.273 MQT: tele/dadroomligth_4A7DA0/SENSOR = {"Time":"2024-09-22T22:30:55","Switch1":"OFF"}
22:31:00.226 MQT: tasmota/discovery/483FDA4A7DA0/config = {"ip":"192.168.5.224","dn":"dadroomlight","fn":["dadroomlight",null,null,null,null,null,null,null],"hn":"dadroomlight","mac":"483FDA4A7DA0","md":"Generic","ty":0,"if":0,"ofln":"Offline","onln":"Online","state":["OFF","ON","TOGGLE","HOLD"],"sw":"14.2.0.3","t":"dadroomligth_4A7DA0","ft":"%prefix%/%topic%/","tp":["cmnd","stat","tele"],"rl":[1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"swc":[-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"swn":[null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null,null],"btn":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"so":{"4":0,"11":0,"13":0,"17":0,"20":0,"30":0,"68":0,"73":0,"82":0,"114":0,"117":0},"lk":0,"lt_st":0,"bat":0,"dslp":0,"sho":[],"sht":[],"ver":1} (已保留)
22:31:00.237 MQT: tasmota/discovery/483FDA4A7DA0/sensors = {"sn":{"Time":"2024-09-22T22:31:00","Switch1":"OFF"},"ver":1} (已保留)
22:31:55.243 MQT: tele/dadroomligth_4A7DA0/STATE = {"Time":"2024-09-22T22:31:55","Uptime":"0T00:01:10","UptimeSec":70,"Heap":25,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"OWER":"OFF","Wifi":{"AP":1,"SSId":"MyDreamHome2_24","BSSId":"48:814C:CF:E7","Channel":11,"Mode":"11n","RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:04"}}
22:31:55.271 MQT: tele/dadroomligth_4A7DA0/SENSOR = {"Time":"2024-09-22T22:31:55","Switch1":"OFF"}
 楼主| 发表于 2024-9-23 06:56:39 来自手机 | 显示全部楼层
结贴了,tasmota固件问题,已改为esphome,解决了。
GMT+8, 2025-12-17 18:45 , Processed in 0.925143 second(s), 8 queries , MemCached On.
