查看: 5130|回复: 2
[求助] 这个是什么情况,log报错
发表于 2018-2-3 06:01:57 | 显示全部楼层 |阅读模式
请帮助看下,如何解决呢
Fri Feb 02 2018 23:28:36 GMT+0800 (CST)
Error while setting up platform xiaomi_miioTraceback (most recent call last):  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)  File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for    return fut.result()  File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result    raise self._exception  File "/usr/lib/python3.6/asyncio/tasks.py", line 180, in _step    result = coro.send(None)  File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro    res = func(*args, **kw)  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/xiaomi_miio.py", line 41, in async_setup_platform    from miio import Device, DeviceException  File "/usr/lib/python3.6/site-packages/miio/__init__.py", line 2, in <module>    from miio.protocol import Message, Utils  File "/usr/lib/python3.6/site-packages/miio/protocol.py", line 179, in <module>    Const(0x2131, Int16ub),  File "/usr/lib/python3.6/site-packages/construct/core.py", line 1894, in __init__    super(Const, self).__init__(subcon)  File "/usr/lib/python3.6/site-packages/construct/core.py", line 291, in __init__    raise TypeError("subcon should be a Construct field")TypeError: subcon should be a Construct field
发表于 2018-2-3 07:55:19 | 显示全部楼层
应该还是miio的问题
★Raspberry + Raspbian + Home Assistant v0.1
★树莓派 + Raspbian系统 + HomeAssistant
https://github.com/huangqian8/homeassistant
发表于 2018-2-3 09:13:31 | 显示全部楼层
bluefire1982 发表于 2018-2-3 07:55
应该还是miio的问题
现在有办法解决吗?树莓派hassio
GMT+8, 2025-12-25 09:49 , Processed in 0.063271 second(s), 10 queries , MemCached On.
