查看: 889|回复: 0
[求助] 小爱音箱L06a开机卡黄灯?TTL跑码如下,大佬帮忙看下。
发表于 2024-9-13 23:08:15 | 显示全部楼层 |阅读模式
Xshell 8 (Build 0055)
Copyright (c) 2024 NetSarang Computer, Inc. All rights reserved.
Connecting to COM4...
Connected.
AXG:BL1:d1dbf2:a4926f;FEAT:E0DC318C:2000OC:F;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
sdio debug board detected
TE: 22885
BL2 Built : 15:46:00, Sep 29 2019. axg g8667414 - sentao.gao@droid08-bj
set vcck to 1140 mv
set vddee to 1070 mv
Board ID = 12
CPU clk: 1200MHz
DDR low power enabled
DDR DQS-calibration enabled
DDR scramble enabled
DDR3 chl: Rank0 16bit @ 792MHz - PASS
Rank0: 256MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
NAND init
chk page: 00000500
chk page: 00000540
chk page: 00000580
chk page: 000005c0
bbt blk:00000014
bbt page:00000000
0000000000000000000000000000000000000000000000000000000000000000
Load FIP HDR from NAND, src: 0x0000c000, des: 0x01700000, size: 0x00004000
Load BL3x from NAND, src: 0x00010000, des: 0x01704000, size: 0x00080000
NOTICE:  BL31: v1.3(release):87b5e26
NOTICE:  BL31: Built : 11:33:44, Apr 10 2020
NOTICE:  BL31: AXG normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: axg_v1.1.3268-b93dd79 2017-12-01 14:22:18 huan.biao@droid12]
OPS=0x43
cc c 6 f3 c2 25 5 8c 27 39 cf 76 bl30:axg ver: 9 mode: 0
bl30:axg thermal0
[0.014319 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Apr 25 2021 - 15:31:41), Build: jenkins-Mico_lx06_ota_publish-229
DRAM:  256 MiB
Relocation Offset is: 0ef17000
register usb cfg[0][1] = 000000000ff89648
NAND:  nand id: 0x98 0xf1
128MiB, SLC, page size: 2048, OOB size: 64
NAND device id: 98 f1 80 15 f2 16
NAND device: Manufacturer ID: 0x98, Chip ID: 0x98 (Toshiba A revision NAND 1Gib TC58BVG0S3HTA00 )
oob avail size 6
Creating 1 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000000000-0x000000200000 : "bootloader"
A revision NAND 1Gib TC58BVG0S3HTA00  initialized ok
nand id: 0x98 0xf1
PLANE change!
aml_nand_init obmul=1,oobfree.length=8,oob_size=64
oob avail size 8
bbt_start=20 env_start=24 key_start=32 dtb_start=40
nbbt: info size=0x400 max_scan_blk=24, start_blk=20
nbbt : phy_blk_addr=20, ec=0, phy_page_addr=0, timestamp=1
nbbt free list:
blockN=21, ec=-1, dirty_flag=0
blockN=22, ec=-1, dirty_flag=0
blockN=23, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=1
aml_nand_scan_rsv_info 1254
nbbt valid addr: 280000
aml_nand_bbt_check 1389 bbt is valid, reading.
aml_nand_read_rsv_info:397,read nbbt info to 280000
nenv: info size=0x10000 max_scan_blk=32, start_blk=24
nenv : phy_blk_addr=25, ec=408, phy_page_addr=0, timestamp=829
nenv free list:
blockN=24, ec=409, dirty_flag=1
blockN=26, ec=8, dirty_flag=1
blockN=27, ec=-1, dirty_flag=0
blockN=28, ec=-1, dirty_flag=0
blockN=29, ec=-1, dirty_flag=0
blockN=30, ec=-1, dirty_flag=0
blockN=31, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=32
nenv valid addr: 330000
nkey: info size=0x8000 max_scan_blk=40, start_blk=32
nkey : phy_blk_addr=32, ec=0, phy_page_addr=0, timestamp=1
nkey free list:
blockN=33, ec=-1, dirty_flag=0
blockN=34, ec=-1, dirty_flag=0
blockN=35, ec=-1, dirty_flag=0
blockN=36, ec=-1, dirty_flag=0
blockN=37, ec=-1, dirty_flag=0
blockN=38, ec=-1, dirty_flag=0
blockN=39, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=16
nkey valid addr: 418000
ndtb: info size=0x20000 max_scan_blk=44, start_blk=40
ndtb : phy_blk_addr=40, ec=2, phy_page_addr=0, timestamp=7
ndtb free list:
blockN=41, ec=2, dirty_flag=1
blockN=42, ec=-1, dirty_flag=0
blockN=43, ec=-1, dirty_flag=0
aml_nand_scan_rsv_info 1251: page_num=64
ndtb valid addr: 500000
tpl: off 8388608, size 8388608
NAND bbt detect factory Bad block at 6000000
aml_nand_add_partition:1794 factory bad addr=300
Creating 6 MTD partitions on "A revision NAND 1Gib TC58BVG0S3HTA00 ":
0x000000800000-0x000001000000 : "tpl"
0x000001000000-0x000001600000 : "boot0"
0x000001600000-0x000001c00000 : "boot1"
0x000001c00000-0x000004400000 : "system0"
0x000004400000-0x000006c20000 : "system1"
0x000006c20000-0x000008000000 : "data"
aml_key_init 170
MMC:
uboot env amlnf_env_read : ####
aml_nand_read_rsv_info:397,read nenv info to 330000
In:    serial
Out:   serial
Err:   serial
[KM]Error:f[keymanage_dts_parse]L287:not a fdt at 0x0000000001000000
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
no need detect now.
Saving Environment to aml-storage...
uboot env amlnf_env_save : ####
aml_nand_save_rsv_info:656, nenv: valid=1, pages=32
release_free_node 61: bitmap=1fffff
release_free_node 74: bitmap=1ffff7
aml_nand_save_rsv_info:716,save info to 300000
aml_nand_write_rsv:520,write info to 300000
save_power_post ...
## Booting Android Image at 0x01080000 ...
reloc_addr =f034410
copy done
load dtb from 0x1000000 ......
      Amlogic multi-dtb tool
      Cannot find legal dtb!
ERROR: image is not a fdt - must RESET the board to recover.
load dtb from 0xf524410 ......
      Multi dtb detected
      Multi dtb tool version: v2 .
      Support 3 dtbs.
        aml_dt soc: xiaomi platform: lx06 variant: v01
        dtb 0 soc: xiaomi   plat: lx06   vari: v01
        dtb 1 soc: xiaomi   plat: lx06   vari: v02
        dtb 2 soc: xiaomi   plat: lx06   vari: v03
      Find match dtb: 0
amlkey_init() enter!
amlnf_key_read key data len too much
aml_nand_read_rsv_info:397,read nkey info to 418000
[EFUSE_MSG]keynum is 4
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x0185c008
   Loading Ramdisk to 0eea1000, end 0f004507 ... OK
   Loading Device Tree to 000000000ee95000, end 000000000eea0036 ... OK
Starting kernel ...
uboot time: 1743624 us
domain-0 init dvfs: 4
[    0.299516@0] ff803000.serial: clock gate not found
[    0.306914@0] amlogic-new-usb3 ffe09080.usb3phy: This phy has no usb port
[    1.206558@0] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
LED AW20054
L06A
curr_boot is boot0
Booting from boot0
/dev/mtdblock4 is ready now.
[    2.780483@0] meson-pinctrl pinctrl@ff634480: function 'gpioa_20' not supported
[    2.782156@0] meson-pinctrl pinctrl@ff634480: invalid function gpioa_20 in map table
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Please press Enter to activate this console.
micocfg[1115]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1115]: cfg get: success: /usr/share/mico/system.cfg k:model vX06
micocfg[1115]: UNLOCK fd: 3.
micocfg[1115]: cfg update success: /data/mico/system.cfg k:model v06A
micocfg[1135]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1135]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1135]: UNLOCK fd: 3.
micocfg[1135]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[1135]: cfg get: success: /data/etc/device.info k:sn v:25297/A9U168371
micocfg[1136]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1136]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1136]: UNLOCK fd: 3.
micocfg[1136]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[1136]: cfg get: success: /data/etc/device.info k:mac_w[    7.432883@2] name: deviceid, size 15
ifi v:EC:41:18:6A:6F5
micocfg[1137]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1137]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1137]: UNLOCK fd: 3.
micocfg[1137]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[1137]: cfg get: success: /data/etc/device.info k:mac_bt v:EC:41:18:6A:6F6
micocfg[1138]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1138]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1138]: UNLOCK fd: 3.
micocfg[1138]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[1138]: cfg get: success: /data/etc/device.info k:miio_did v:266287324
micocfg[1139]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1139]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1139]: UNLOCK fd: 3.
micocfg[1139]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[1139]: cfg get: success: /data/etc/device.info k:miio_key v:7C1eVnMSFk709CM7
micocfg[1140]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1140]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1140]: UNLOCK fd: 3.
micocfg[1140]: LOCK:ret(0) fd(3), path(26): /var/lock/device.info.lock.
micocfg[1140]: cfg get: success: /data/etc/device.info k:board_id v:11
micocfg[1153]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1153]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1153]: UNLOCK fd: 3.
micocfg[1153]: cfg get: success: /usr/share/mico/system.cfg k:buildts v:1691669398
micocfg[1155]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1155]: cfg get: success: /usr/share/mico/system.cfg k:model v06A
micocfg[1155]: UNLOCK fd: 3.
micocfg[1155]: cfg get: success: /usr/share/mico/system.cfg k:model v:L06A
micocfg[1156]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1156]: cfg get: success: /usr/share/mico/system.cfg k:model v:L06A
micocfg[1156]: UNLOCK fd: 3.
micocfg[1156]: bt_enable_set  argv[1] 1
micocfg[1156]: LOCK:ret(0) fd(3), path(28): /var/lock/bluetooth.cfg.lock.
micocfg[1156]: cfg update success: /data/bt/bluetooth.cfg k:enable v:1
micocfg[1157]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1157]: cfg get: success: /usr/share/mico/system.cfg k:model v:L06A
micocfg[1157]: UNLOCK fd: 3.
micocfg[1157]: funtion uid result empty
micocfg[1159]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1159]: cfg get: success: /usr/share/mico/system.cfg k:model v:L06A
micocfg[1159]: UNLOCK fd: 3.
micocfg[1159]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
ledserver[1206]: Build Time: Aug 10 2023 12:37:52
ledserver[1206]: starting
ledserver[1206]: pipe try (fw_env -g board_id)
ledserver[1206]: info pipe (fw_env -g board_id) exited, exit code: 0 buf:12.
ledserver[1206]: pipe (fw_env -g board_id) exited, exit code: 0 buf:12.
ledserver[1206]: current model L06A.
ledserver[1206]: LEDSBAK EXISITS
ledserver[1206]: LOCK:ret(0) fd(8), path(28): /var/lock/nightmode.cfg.lock.
ledserver[1206]: No 'sleep_mode_flag' setting in configuration file '/data/etc/nightmode.cfg'
ledserver[1206]: UNLOCK fd: 8.
ledserver[1206]: No 'sleep_mode' setting in configuration file '/data/etc/nightmode.cfg'
ledserver[1206]: cfg get: success: /data/etc/nightmode.cfg k:total v:night
ledserver[1206]: cfg get: success: /data/etc/nightmode.cfg k:light v:night
ledserver[1206]: cfg get: success: /data/etc/nightmode.cfg k:volume v:night
ledserver[1206]: cfg get: success: /data/etc/nightmode.cfg k:start v:22:00
ledserver[1206]: cfg get: success: /data/etc/nightmode.cfg k:stop v:06:00
crond[1230]: crond (busybox 1.27.2) started, log level 5
micocfg[1239]: LOCK:ret(0) fd(3), path(25): /var/lock/system.cfg.lock.
micocfg[1239]: cfg get: success: /usr/share/mico/system.cfg k:model v:L06A
micocfg[1239]: UNLOCK fd: 3.
micocfg[1239]: cfg get: success: /usr/share/mico/system.cfg k:channel v:release
[   10.503753@1] wlan: Loading MWLAN driver
[   10.504395@2] wlan: Driver loaded successfully
[   12.987996@3] HCI UART driver ver 2.2-M2614100[   12.988252@1] HCI H4 protocol initialized
[   13.302463@3] pdm_dclk is : 0
[   14.710406@0] invalid toddr src
[   15.465859@3] ps_init_work...
[   15.465888@3] ps_init_timer...
[   15.466965@0] ps_init...
[   17.471742@2] Bluetooth: hci0 command 0x1003 tx timeout
[   19.487748@0] Bluetooth: hci0 command 0x1001 tx timeout
[   21.503798@1] Bluetooth: hci0 command 0x1009 tx timeout
[   25.567796@3] ps_init...
[   27.583758@0] Bluetooth: hci0 command 0x1003 tx timeout
[   29.599751@1] Bluetooth: hci0 command 0x1001 tx timeout
[   31.615742@2] Bluetooth: hci0 command 0x1009 tx timeout
GMT+8, 2025-12-16 02:05 , Processed in 1.058410 second(s), 14 queries , MemCached On.
