查看: 1919|回复: 3
[求助] 新版本加载项Nodered启动失败
发表于 2024-9-11 15:50:17 | 显示全部楼层 |阅读模式
Home Assistant
  • Home Assistant
    • Core                         2024.9.1
    • Supervisor               2024.08.0
    • Operating System   13.1
    • Frontend                  20240906.0
日志如下,卸载重装也无法启动。。。。
11 Sep 15:44:45 - [error] [server-state-changed:5581fe47ec4190e6] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-switch:d05ceb07422a0905] Error: Invalid entity config
11 Sep 15:44:45 - [error] [server-state-changed:d1a83b4389910f8c] Error: Invalid server config
11 Sep 15:44:45 - [error] [server-state-changed:5ff902b9820c68af] Error: Invalid server config
11 Sep 15:44:45 - [error] [server-state-changed:9877a2e95cf3516c] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:064b8fd4b7bf093b] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:e325583960626692] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-sensor:57da8b6bf0fef597] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:8710adafb491b74a] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:476d031f6f228dba] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:a95663445ee3718c] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:45eb031e49602838] Error: Invalid entity config
11 Sep 15:44:45 - [error] [api-current-state:c8a60c84331a4430] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:dc28336ea5e5b613] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:01b5b816b798c18c] Error: Invalid server config
11 Sep 15:44:45 - [error] [server-state-changed:7697f33f30c0e105] Error: Invalid server config
11 Sep 15:44:45 - [error] [server-state-changed:f5bb2b28bb381057] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:742b94cae689a4ac] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:ca6abc6fdcc84a7e] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:e14c1eb8d5339b8f] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:1709befc5cb11475] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-switch:c4f6cb3dfef60ca4] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-api:6fd3823009d0c040] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:2747532b3a4301dd] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:e64e87365246dc05] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:148d101c8783b2f6] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:aadf523be8d681e9] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:131ab4dfa439fcd6] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-api:5517a1aee31f6f20] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:621782fbade903e1] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-call-service:744457acba46a3ce] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-call-service:bf2c1877af5645c8] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:20f42b7b3cee56e7] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:acf017a06801e5ef] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:804c383f6264be57] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:0c33d77b6ebe0665] Error: Invalid server config
11 Sep 15:44:45 - [error] [api-current-state:e9f63448be984d85] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-update-config:eea35390a398f2f1] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-api:a540e2081f9615ea] Error: Invalid server config
11 Sep 15:44:45 - [error] [ha-sensor:461c425dfa8031e7] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:5bb29568e2723ad5] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:ddaba78e31a49284] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:f585488593419c24] Error: Invalid entity config
11 Sep 15:44:45 - [error] [ha-sensor:6954210cb73254f1] Error: Invalid entity config
11 Sep 15:44:45 - [red] Uncaught Exception:
11 Sep 15:44:45 - [error] Error: spawn python ENOENT
    at Process.ChildProcess._handle.onexit (node:internal/child_process:284:19)
    at onErrorNT (node:internal/child_process:477:16)
    at processTicksAndRejections (node:internal/process/task_queues:82:21)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service base-addon-banner: starting
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 18.0.5
 You are running the latest version of this add-on.
 System: Home Assistant OS 13.1  (amd64 / qemux86-64)
 Home Assistant Core: 2024.9.1
 Home Assistant Supervisor: 2024.08.0
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
Log level is set to ERROR
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
发表于 2024-9-11 17:25:55 | 显示全部楼层
新版本Nodered加载项,启动确实很慢,我启动都要2分钟这个加载项,之前老版比较快
 楼主| 发表于 2024-9-11 18:12:07 | 显示全部楼层
bugensui 发表于 2024-9-11 17:25
新版本Nodered加载项,启动确实很慢,我启动都要2分钟这个加载项,之前老版比较快 ...
启动以后打开web界面提示错误502: Bad Gateway,请问你遇到过吗?
发表于 2024-9-11 23:08:22 | 显示全部楼层
没有,没有遇到过这个报错,是不是你没有配置好,你看下加载项的日志,找下原因
GMT+8, 2025-12-17 18:45 , Processed in 0.934901 second(s), 7 queries , MemCached On.
