查看: 2251|回复: 1
[求助] 求助大佬,esp32-s3串口有数据就是不连wifi
发表于 2024-9-10 21:02:37 | 显示全部楼层 |阅读模式
screenshot1.png 开机串口就一直提示这个
代码如下:
esphome:
  friendly_name: BL0910-4
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "O3B+BfSUEuATbwM7sl4IEs59N0J4nvkeAsAaF2malVQ="
ota:
  - platform: esphome
    password: "1c8f415f3a9af2b720db3578b951f478"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Bl0910-4 Fallback Hotspot"
    password: "UmkuBY1HlTLM"
captive_portal:
external_components:
  - source: BL0910
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 19200
  - platform: BL0910
    update_interval: 1s                     ##传给HA状态间隔
    Frequency:
    Temperature:
    Voltage:
    Current_1:
    Current_2:
    Current_3:
    Current_4:
    Current_5:
    Current_6:
    Current_7:
    Current_8:
    Current_9:
    Current_10:
    Power_1:
    Power_2:
    Power_3:
    Power_4:
    Power_5:
    Power_6:
    Power_7:
    Power_8:
    Power_9:
    Power_10:
    Power_sum:
    Energy_1:
    Energy_2:
    Energy_3:
    Energy_4:
    Energy_5:
    Energy_6:
    Energy_7:
    Energy_8:
    Energy_9:
    Energy_10:
    Energy_sum:
 楼主| 发表于 2024-9-12 00:54:01 | 显示全部楼层
https://bbs.hassbian.com/thread-24269-1-1.html
已解决和电路图一样接烧录就没有报错了
GMT+8, 2025-12-17 15:11 , Processed in 0.123519 second(s), 12 queries , MemCached On.
