查看: 3216|回复: 2
[基础教程] 学了几天的switch.mqtt,分享一下刚刚翻译的一页switch.mqtt文档
发表于 2024-9-8 11:44:24 | 显示全部楼层 |阅读模式
翻译自:https://www.home-assistant.io/integrations/switch.mqtt/
翻译基本上就是用gpt翻译的, 有需要的朋友可以自取。
这个网页的文档,附件一个是图片版, 一个是html版(解开zip文件)
以后如果还有其他翻译的, 会考虑合并做成chm文件
加上自己学了几天的配置文件
单路
  - switch:
      unique_id: s128
      state_topic: "s128/status"
      command_topic: "s128/set"
      availability:
        - topic: "s128/available"
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
多路
  - switch:
      unique_id: s131_led
      state_topic: "s131/status/led"
      command_topic: "s131/set/led"
      availability:
        - topic: "s131/available/led"
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
  - switch:
      unique_id: s131_switch
      state_topic: "s131/status/switch"
      command_topic: "s131/set/switch"
      availability:
        - topic: "s131/available/switch"
      payload_on: "ON"
      payload_off: "OFF"
      state_on: "ON"
      state_off: "OFF"
      optimistic: false
      qos: 0
      retain: true
MQTT Switch - Home Assistant.zip
10.47 KB, 下载次数: 10
发表于 2024-10-12 16:12:47 | 显示全部楼层
谢谢,非常不错的,
 楼主| 发表于 2024-10-13 14:23:53 | 显示全部楼层
tettr 发表于 2024-10-12 16:12
谢谢,非常不错的,
GMT+8, 2026-1-14 06:20 , Processed in 0.519825 second(s), 11 queries , MemCached On.
