查看: 9096|回复: 3
安装好 HomeBridge,遇到 Host name conflict 的解决方法
发表于 2018-2-2 15:49:05 | 显示全部楼层 |阅读模式
如果你安装完 HomeBridge,在 iOS 设备上怎么也找不到 HomeBridge,而且报错如下:
Host name conflict, retrying with hassio-19
Registering new address record for fe80::473e:1cc1:fccc:1af7 on vetha58f892..
Registering new address record for 169.254.70.152 on vetha58f892.IPv4.
Registering new address record for fe80::786e:31ff:fec6:1b78 on veth175236b..
Registering new address record for 169.254.104.131 on veth175236b.IPv4.
Registering new address record for fe80::a1db:7d77:9e6f:9e14 on docker0..
Registering new address record for 169.254.1.224 on docker0.IPv4.
Registering new address record for 172.17.0.1 on docker0.IPv4.
Registering new address record for fe80::3802:117a:5c87:c173 on hassio..
Registering new address record for 169.254.52.243 on hassio.IPv4.
Registering new address record for 172.30.32.1 on hassio.IPv4.
Registering new address record for fe80::d435:ef2d:f54a:aaa2 on wlan0..
Registering new address record for 192.168.1.102 on wlan0.IPv4.
Registering new address record for fe80::a5e3:9aca:38b3:2173 on eth0..
Withdrawing address record for fe80::473e:1cc1:fccc:1af7 on vetha58f892.
Withdrawing address record for fe80::786e:31ff:fec6:1b78 on veth175236b.
Withdrawing address record for 169.254.104.131 on veth175236b.
Withdrawing address record for fe80::a1db:7d77:9e6f:9e14 on docker0.
Withdrawing address record for 169.254.1.224 on docker0.
Withdrawing address record for 172.17.0.1 on docker0.
Withdrawing address record for fe80::3802:117a:5c87:c173 on hassio.
Withdrawing address record for 169.254.52.243 on hassio.
Withdrawing address record for 172.30.32.1 on hassio.
Withdrawing address record for fe80::d435:ef2d:f54a:aaa2 on wlan0.
Withdrawing address record for 192.168.1.102 on wlan0.
Withdrawing address record for fe80::a5e3:9aca:38b3:2173 on eth0.
Host name conflict, retrying with hassio-20
可以试试这个解决方法:
sudo nano /etc/avahi/avahi-daemon.conf
把里面的 hostname 改成 hassio,并去掉 # 注释,然后
systemctl restart avahi-daemon
重启下服务就好了。
参与人数 1金钱 +10 收起 理由
+ 10 分享是一种美德!
发表于 2018-2-2 15:51:55 | 显示全部楼层
我看行!
发表于 2018-2-6 10:26:56 | 显示全部楼层
我装了N次,每次安装完成iOS都是找不到设备。
贼尴尬啊。  郁闷
 楼主| 发表于 2018-2-7 12:12:42 | 显示全部楼层
贼尴尬啊。  郁闷
你看看 log,找不到设备删除 persist 还有配件缓存再试试。
GMT+8, 2025-12-25 09:49 , Processed in 0.051093 second(s), 11 queries , MemCached On.
