查看: 3246|回复: 9
[技术探讨] 奥克斯A+ app 空调抓包数据接口
发表于 2024-8-23 14:30:48 | 显示全部楼层 |阅读模式
家中使用的奥克斯空调,论坛的MQTT方案不适用,无奈手动抓包,小黄鸟抓包接口数据如下:
1.登录为短信验证,短信请求接口如下:
https://smthomeav.aux-home.com/app/login_sms_code
方法为 POST,请求体为 phone:13xxxxx   手机号
2.短信验证请求接口:
https://smthomeav.aux-home.com/app/wechatMini/loginBySms
方法为 POST,请求体为 phone:13xxxxx   手机号;code:xxxx 验证码
3.登录后获取到Authorization 参数=token值 并包含到请求头中,expireAt应为token有效期时间参数:
    "openApiToken": {
      "token": "bc18c3b217a34c7b9dfXXXXXXXXXXXXXXXXX",
      "expireAt": 1726762443
4.获取设备列表接口,确保请求头中包含 Authorization 参数值
https://smthomeav.aux-home.com/app/device_bindings?getStatus=true
获取到的设备列表JSON数据如下(部分私人参数和谐):
  "code": 200,
  "message": "OK",
  "data": [
      "deviceId": "f57cb83f-e9c5-4251-b98e-a81fXXXXXXXXXXX",
      "source": 1,
      "productKey": "000100XXXXX",
      "mac": "E8165XXXXXXXX",
      "did": "d500010001XXXXXXX",
      "alias": "主卧空调",
      "type": null,
      "deviceKey": null,
      "deviceLock": null,
      "password": "b7beXXXXXXXX",
      "terminalId": 1,
      "subDevice": 0,
      "dataOne": "42",
      "dataTwo": "90",
      "dataThree": "06",
      "city": null,
      "cityCode": null,
      "sn": "",
      "longitude": "113.XXXXX",
      "latitude": "30.XXXXX",
      "modelId": "ea47d0fc-e9f1-4589-8f9d-4XXXXXXXXXXX",
      "suitType": 0,
      "useType": 0,
      "feature": "{\"coolType\":[\"1\",\"0\"],\"frenquency\":[\"1\",\"0\"],\"tempInterval\":[\"0\",\"0\"],\"roomTempDisplay\":[\"1\",\"0\"],\"screen\":[\"2\",\"0\"],\"windSpeed\":[\"2\",\"0\"],\"faultSupport\":[\"0\",\"0\"],\"timing\":[\"0\",\"0\"],\"mode\":[\"0,1,2,3,4\",\"1\"],\"deviceSupport\":[\"0,1,2,3,4,5,6,7,9,10\",\"1\"],\"appSupport\":[\"0,1,2,3,4,5\",\"1\"]}",
      "deviceMainUri": "https://smart-home-saas.oss-cn-hangzhou.aliyuncs.com/20181108/img/a2f1873e-c7a8-49ea-bd2c-7005ccf921e3.png",
      "entityUri": null,
      "userTag": 0,
      "wash": true,
      "deviceKind": null,
      "mcuType": 0,
      "sftype": false,
      "zeroWindFeel": false,
      "address": null,
      "transport": null,
      "customerFuncs": null,
      "thirdDid": null,
      "online": true,
      "data": {
        "wind_child": 0,
        "ventilate": 0,
        "half": 0,
        "wind_speed_1": 6,
        "air_con_func": 1,
        "power_limit_percent": 0,
        "support_heat": 1,
        "type": "control_status",
        "auto_screen": 0,
        "eco": 0,
        "temperature_decimal": 0,
        "up_down_swing": 7,
        "power_limit": 0,
        "electric_lock": 0,
        "anti_fungus": 0,
        "temperature": 29,
        "left_right_swing": 1,
        "wind_smart": 0,
        "ventilate_heap_notify": 0,
        "fahrenheit": 0,
        "addr": 1,
        "wind_far": 0,
        "sleep_mode": 0,
        "ver": 0,
        "electric_heating": 0,
        "src": 1,
        "comfort_wind": 0,
        "freshing": 0,
        "wind_ring": 0,
        "on_off": 1,
        "clean": 0,
        "zero_wind_feeling": 0,
        "sleep_diy": 0,
        "ventilate_auxiliary": 0,
        "auto_following_code": 0,
        "human_detection": 0,
        "screen_on_off": 0,
        "healthy": 0,
        "following": 0,
        "wind_light": 0,
        "turbo_silence": 0,
        "air_q_light": 0,
        "hanging": 1
      "wifi_hard_version": "2C007100",
      "wifi_soft_version": "00071061",
      "passcode": "b7beXXXXXX"
5.控制接口和部分控制代码值(请确保请求头中包含 Authorization 参数值):
https://smthomeav.aux-home.com/app/wechatMini/new_device_control
例,空调调整到29.5度:
  "did": "d500010001e816566b4b98",
  "uart": "bb00068000010f000101af2080a0002000002000000000de9b",
  "pk": "00010001",
  "action": {
    "temperature": 295
参与人数 2金钱 +20 收起 理由
q873139535 + 8 感谢楼主分享!
隔壁的王叔叔 + 12 感谢楼主分享!
发表于 2024-8-23 18:31:28 | 显示全部楼层
我也是奥克斯空调,有没有接入到hass?接入的话具体怎样做?
发表于 2024-8-23 21:32:37 | 显示全部楼层
伸手党表示有nodered流程就完美了
发表于 2024-8-23 21:33:58 | 显示全部楼层
虽然我用空调伴侣,但是APP可以控制到0.5度,更适合实际感受
 楼主| 发表于 2024-8-25 16:34:10 | 显示全部楼层
dengxiao 发表于 2024-8-23 21:32
伸手党表示有nodered流程就完美了
抛砖引玉,留给大神们发挥,看哪位大神心情好直接改写程插件~
发表于 2025-1-23 22:52:21 | 显示全部楼层
同样的是奥克斯A+ app 有大佬写好了吗?
 楼主| 发表于 2025-2-4 21:24:00 | 显示全部楼层
伸手党表示有nodered流程就完美了
 JSON 代码,可直接导入到 Node - RED 中。请确保在实际使用时,将占位的手机号、验证码、设备 `did` 和 `pk` 等信息替换为真实有效的值。
```json
        "id": "c29c1697.56e9e8",
        "type": "inject",
        "z": "2797f4c1.8b059e",
        "name": "发送短信验证码",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{"phone":"13xxxxx"}",
        "payloadType": "json",
        "x": 110,
        "y": 140,
        "wires": [
                "56c98c0f.d009d4"
        "id": "56c98c0f.d009d4",
        "type": "http request",
        "name": "",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "url": "https://smthomeav.aux-home.com/app/login_sms_code",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": {},
        "x": 300,
        "y": 140,
        "wires": [
                "7c9c0f01.15c28c"
        "id": "7c9c0f01.15c28c",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 480,
        "y": 140,
        "wires": []
        "id": "f0e75b33.8d0798",
        "type": "inject",
        "name": "登录",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{"phone":"13xxxxx","code":"xxxx"}",
        "x": 110,
        "y": 200,
        "wires": [
                "6c978c13.16c99c"
        "id": "6c978c13.16c99c",
        "name": "",
        "method": "POST",
        "ret": "json",
        "paytoqs": false,
        "url": "https://smthomeav.aux-home.com/app/wechatMini/loginBySms",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": {},
        "x": 300,
        "y": 200,
        "wires": [
                "a58d9725.5c102"
        "id": "a58d9725.5c102",
        "type": "function",
        "name": "提取并存储token",
        "func": "global.set("aux_token", msg.payload.openApiToken.token);\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 480,
        "y": 200,
        "wires": [
                "d1b4a72d.75529"
        "id": "d1b4a72d.75529",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 650,
        "y": 200,
        "wires": []
        "id": "d806b960.10c92",
        "type": "inject",
        "name": "获取设备列表",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 110,
        "y": 260,
        "wires": [
                "c0700d94.9b2768"
        "id": "c0700d94.9b2768",
        "name": "",
        "method": "GET",
        "ret": "json",
        "paytoqs": false,
        "url": "https://smthomeav.aux-home.com/app/device_bindings?getStatus=true",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": {
            "Authorization": "{{global.aux_token}}"
        "x": 300,
        "y": 260,
        "wires": [
                "e9d7c00d.7c4918"
        "id": "e9d7c00d.7c4918",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 480,
        "y": 260,
        "wires": []
        "id": "a59c9b99.99962",
        "type": "inject",
        "name": "控制设备",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 110,
        "y": 320,
        "wires": [
                "b37c9d02.990988"
        "id": "b37c9d02.990988",
        "type": "function",
        "name": "构建控制请求",
        "func": "let did = "d500010001e816566b4b98";\nlet pk = "00010001";\nlet action = {"temperature":295};\nmsg.payload = {\n    "did": did,\n    "uart": "bb00068000010f000101af2080a0002000002000000000de9b",\n    "pk": pk,\n    "action": action\n};\nmsg.headers = {\n    "Authorization": global.get("aux_token")\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "x": 300,
        "y": 320,
        "wires": [
                "c17c9e14.99311"
        "id": "c17c9e14.99311",
        "name": "",
        "method": "POST",
        "ret": "txt",
        "paytoqs": false,
        "url": "https://smthomeav.aux-home.com/app/wechatMini/new_device_control",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": {},
        "x": 480,
        "y": 320,
        "wires": [
                "7c9c0f01.15c28c1"
        "id": "7c9c0f01.15c28c1",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 650,
        "y": 320,
        "wires": []
 **导入流程**:
   - 在 Node - RED 界面中,点击菜单中的 `Import` -> `Clipboard`。
   - 将上述 JSON 代码粘贴到弹出的对话框中,然后点击 `Import` 按钮,即可导入该流程。
请记住,在实际使用中要根据你的奥克斯账号和设备信息正确配置手机号、验证码、设备 `did` 和 `pk` 等参数,以确保流程能够正常运行。
发表于 2025-6-6 14:12:27 | 显示全部楼层
多谢大佬,但是这个流导入报错,能否直接给文件,伸手党再次感谢
发表于 2025-7-4 10:27:45 | 显示全部楼层
官方给我换了新模块,没办法接入这个HA了
发表于 2025-9-3 15:55:30 | 显示全部楼层
你的这个API还能用吗?我刚试了第一步短信验证码的请求就回复"code":400,"message":"Bad Request!",是不是官方修改了API?
GMT+8, 2025-12-16 15:49 , Processed in 1.300634 second(s), 15 queries , MemCached On.
