查看: 8197|回复: 0
[求助] sonoff刷入Sonoff-Tasmota固件
发表于 2018-1-31 23:34:01 | 显示全部楼层 |阅读模式
刷的时候出现了Arduino:1.8.4 (Windows 7), 开发板:"Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 1M (no SPIFFS), ck, Disabled, None"
F:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware F:\Arduino\hardware -hardware F:\Arduino\portable\packages -tools F:\Arduino\tools-builder -tools F:\Arduino\hardware\tools\avr -tools F:\Arduino\portable\packages -built-in-libraries F:\Arduino\libraries -libraries F:\Arduino\portable\sketchbook\libraries -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=1M0,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10804 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_776841 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_280814 -prefs=build.warn_data_percentage=75 -verbose F:\Sonoff-Tasmota-master\sonoff\sonoff.ino
F:\Arduino\arduino-builder -compile -logger=machine -hardware F:\Arduino\hardware -hardware F:\Arduino\portable\packages -tools F:\Arduino\tools-builder -tools F:\Arduino\hardware\tools\avr -tools F:\Arduino\portable\packages -built-in-libraries F:\Arduino\libraries -libraries F:\Arduino\portable\sketchbook\libraries -fqbn=esp8266:esp8266:generic:UploadTool=esptool,CpuFrequency=80,FlashFreq=40,FlashMode=dio,UploadSpeed=115200,FlashSize=1M0,ResetMethod=ck,Debug=Disabled,DebugLevel=None____ -ide-version=10804 -build-path C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_776841 -warnings=none -build-cache C:\Users\ADMINI~1\AppData\Local\Temp\arduino_cache_280814 -prefs=build.warn_data_percentage=75 -verbose F:\Sonoff-Tasmota-master\sonoff\sonoff.ino
Using board 'generic' from platform in folder: F:\Arduino\portable\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: F:\Arduino\portable\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
缺少 recipe.preproc.macros 模式
为开发板 Generic ESP8266 Module 编译时出错。
想请问是什么原因
GMT+8, 2025-12-25 09:52 , Processed in 0.067790 second(s), 7 queries , MemCached On.
