查看: 2061|回复: 7
[求助] 威联通Virtualization Station安装的OS版本无法安装HACS
发表于 2024-8-20 11:05:01 | 显示全部楼层 |阅读模式
威联通TS264 安装HA OS,安装好OS后使用命令wget -O - https://hacs.vip/get | bash - 安装HACS,用了多种命令都无法安装成功,显示如下,请教大神如何解决,谢谢。
Welcome to the Home Assistant command line.
System information
  IPv4 addresses for enp0s4: 192.168.66.88/24
  IPv6 addresses for enp0s4: fe80::a342:cd98:cd77:9bb4/64
  OS Version:               Home Assistant OS 12.4
  Home Assistant Core:      2024.8.2
  Home Assistant URL:       http://homeassistant.local:8123
  Observer URL:             http://homeassistant.local:4357
➜  ~ wget -O - https://hacs.vip/get | bash -
--2024-08-20 11:10:39--  https://hacs.vip/get
Resolving hacs.vip (hacs.vip)... 172.67.164.28, 104.21.65.148, 2606:4700:3033::ac43:a41c, ...
Connecting to hacs.vip (hacs.vip)|172.67.164.28|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/plain]
Saving to: 'STDOUT'
-        [ <=>        ]   5.17K  --.-KB/s    in 0s
2024-08-20 11:10:40 (72.8 MB/s) - written to stdout [5295]
INFO: Archive URL: https://ghrp.hacs.vip/hacs-china/integration/releases/latest/download/hacs.zip
INFO: Trying to find the correct directory...
INFO: Found Home Assistant configuration directory at '/root/config'
INFO: Changing to the custom_components directory...
INFO: Downloading...
--2024-08-20 11:10:40--  https://ghrp.hacs.vip/hacs-china/integration/releases/latest/download/hacs.zip
Resolving ghrp.hacs.vip (ghrp.hacs.vip)... 198.23.254.39
Connecting to ghrp.hacs.vip (ghrp.hacs.vip)|198.23.254.39|:443... connected.
HTTP request sent, awaiting response... 502 Bad Gateway
2024-08-20 11:10:47 ERROR 502: Bad Gateway.
发表于 2024-8-20 18:52:16 | 显示全部楼层
OS版本不是一般都集成了?HTTP request sent, awaiting response... 502 Bad Gateway2024-08-20 11:10:47 ERROR 502: Bad Gateway.
上游服务器问题:你的请求被转发到另一个服务器(通常是反向代理或网关),但该服务器无法正常响应。
网络问题:网络连接不稳定或中断,导致服务器无法与上游服务器通信。
 楼主| 发表于 2024-8-21 10:02:19 | 显示全部楼层
home_assistant 发表于 2024-8-20 18:52
OS版本不是一般都集成了?HTTP request sent, awaiting response... 502 Bad Gateway2024-08-20 11:10:47 ER ...
谢谢您的回复,我是在官网下载的VMware ESXi/vSphere (.ova)这个版本。请给一个集成的版本我重新安装,谢谢。
发表于 2024-8-21 10:54:12 | 显示全部楼层
B!ueice 发表于 2024-8-21 10:02
谢谢您的回复,我是在官网下载的VMware ESXi/vSphere (.ova)这个版本。请给一个集成的版本我重新安装,谢 ...
你有科学上网环境吗?就是安装成功要安装里面的包,还是要有上网环境,或者你应该解决网络问题。
发表于 2024-8-21 14:02:14 | 显示全部楼层
我是威联通的453B mini,官网下载OVA,在虚拟机里安装后,再按照https://bbs.hassbian.com/forum.php?mod=viewthread&tid=14242里的步骤就可以安装、更新、使用HACS了:
一、修改默认下载源
二、设置定时自动更新docker中hosts文件
详细请参考上面链接里的帖子。
PS.我的环境是广东电信,有公网IP。但这个应该不是关键因素。
发表于 2024-8-21 16:54:41 | 显示全部楼层
这两年总是在os和docker反复横跳,也装过冬瓜的OS,威联通里存了一堆的配置文件。最近又搞了个N1旁路由,直接在N1里部署了。威联通453D升级到12G ,偶尔也是docker部署
 楼主| 发表于 2024-8-21 17:23:23 | 显示全部楼层
home_assistant 发表于 2024-8-21 10:54
你有科学上网环境吗?就是安装成功要安装里面的包,还是要有上网环境,或者你应该解决网络问题。 ...
NAS安装了openwrt,正在研究怎么设置FQ,买了JMS,还未设置成功。
 楼主| 发表于 2024-8-21 23:28:47 | 显示全部楼层
刚才没有用科学上网,用了
wget -O - https://get.hacs.xyz | bash -
居然安装成功了,速度20多K。
GMT+8, 2025-12-18 11:09 , Processed in 1.219937 second(s), 12 queries , MemCached On.
