查看: 2121|回复: 16
升级supervisor出错了。
发表于 2024-8-16 16:10:32 | 显示全部楼层 |阅读模式
不小心点了升级,折腾了一天了,还是无法回复,求大神帮忙指导。谢谢!
  _parts_pattern = "^cpe:2.3:{0}\:{1}\:{2}\:{3}\:{4}\:{5}\:{6}\:{7}\:{8}\:{9}\:{10}$".format(
2024-08-16 15:19:05.457 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.3 / BootSlot A
2024-08-16 15:19:07.571 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/b9a594eb repository
2024-08-16 15:19:07.572 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/df2164f9 repository
2024-08-16 15:19:07.574 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-08-16 15:19:07.578 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/7eca76cc repository
2024-08-16 15:19:07.583 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2024-08-16 15:19:07.586 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/fb59d657 repository
2024-08-16 15:19:09.148 INFO (MainThread) [supervisor.store] Loading add-ons from store: 122 all - 122 new - 0 remove
2024-08-16 15:19:09.252 INFO (MainThread) [supervisor.addons.manager] Found 16 installed add-ons
2024-08-16 15:19:09.346 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.fastgh.com/hassio-addons/node-red/aarch64 with version 18.0.4
2024-08-16 15:19:09.392 INFO (MainThread) [supervisor.addons.addon] No b9a594eb_esphome-beta addon Docker image m.fashgh.com/esphome/esphome-hassio found
2024-08-16 15:19:09.392 INFO (MainThread) [supervisor.docker.interface] Downloading docker image m.fashgh.com/esphome/esphome-hassio with tag 2024.7.3.
2024-08-16 15:19:09.400 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-ssh with version 9.14.0
2024-08-16 15:19:09.432 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_addonDataMigrate addon Docker image wghaos/addon-data-migrate found
2024-08-16 15:19:09.432 INFO (MainThread) [supervisor.docker.interface] Downloading docker image wghaos/addon-data-migrate with tag 0.2.1.
2024-08-16 15:19:09.435 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-configurator with version 5.8.0
2024-08-16 15:19:09.452 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_cpolar addon Docker image wghaos/addon-wghaos-cpolar found
2024-08-16 15:19:09.452 INFO (MainThread) [supervisor.docker.interface] Downloading docker image wghaos/addon-wghaos-cpolar with tag 3.3.18.
2024-08-16 15:19:09.454 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/aarch64-addon-samba with version 12.3.2
2024-08-16 15:19:09.456 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/funkeyflo/ps5-mqtt/aarch64 with version 1.4.0
2024-08-16 15:19:09.458 INFO (MainThread) [supervisor.docker.interface] Attaching to wghaos/addon-data-clean with version 0.1.5
2024-08-16 15:19:09.483 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_MyIP addon Docker image jason5ng32/myip found
2024-08-16 15:19:09.484 INFO (MainThread) [supervisor.docker.interface] Downloading docker image jason5ng32/myip with tag latest.
2024-08-16 15:19:09.485 INFO (MainThread) [supervisor.docker.interface] Attaching to wghaos/wga-boost with version 1.0.1
2024-08-16 15:19:09.505 INFO (MainThread) [supervisor.addons.addon] No b9a594eb_esphome addon Docker image m.fashgh.com/esphome/esphome-hassio found
2024-08-16 15:19:09.506 INFO (MainThread) [supervisor.docker.interface] Downloading docker image m.fashgh.com/esphome/esphome-hassio with tag 2024.7.3.
2024-08-16 15:19:09.513 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_onelist addon Docker image wghaos/onelist found
2024-08-16 15:19:09.514 INFO (MainThread) [supervisor.docker.interface] Downloading docker image wghaos/onelist with tag 2.0.5.
2024-08-16 15:19:09.520 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_portainerZH addon Docker image wghaos/portainer-zh found
2024-08-16 15:19:09.521 INFO (MainThread) [supervisor.docker.interface] Downloading docker image wghaos/portainer-zh with tag 2.19.1.
2024-08-16 15:19:09.548 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_haos_turbo addon Docker image xyyyhtl/haos-turbo found
2024-08-16 15:19:09.550 INFO (MainThread) [supervisor.docker.interface] Downloading docker image xyyyhtl/haos-turbo with tag 2.2.5.1-2.
2024-08-16 15:19:09.563 INFO (MainThread) [supervisor.addons.addon] No 7eca76cc_haos_turbo2 addon Docker image xyyyhtl/haos-turbo2 found
2024-08-16 15:19:09.564 INFO (MainThread) [supervisor.docker.interface] Downloading docker image xyyyhtl/haos-turbo2 with tag 2.2.5.1.
2024-08-16 15:51:17.046 ERROR (MainThread) [supervisor.docker.interface] Can't install m.fashgh.com/esphome/esphome-hassio:2024.7.3: 404 Client Error for http+docker://localhost/v1.44/images/m.fashgh.com/esphome/esphome-hassio:2024.7.3/json: Not Found ("No such image: m.fashgh.com/esphome/esphome-hassio:2024.7.3")
2024-08-16 15:51:17.134 ERROR (MainThread) [supervisor.docker.interface] Can't install m.fashgh.com/esphome/esphome-hassio:2024.7.3: 404 Client Error for http+docker://localhost/v1.44/images/m.fashgh.com/esphome/esphome-hassio:2024.7.3/json: Not Found ("No such image: m.fashgh.com/esphome/esphome-hassio:2024.7.3")
发表于 2024-8-16 22:51:57 | 显示全部楼层
回帖奖励 +1 金钱
想办法提供科学环境。
 楼主| 发表于 2024-8-17 10:31:36 | 显示全部楼层
zfgjy2005 发表于 2024-8-16 22:51
想办法提供科学环境。
我的openwrt软路由是有科学环境的,但是不知道怎么把它连接上
发表于 2024-8-17 20:10:04 | 显示全部楼层
你这会启动的时候,把路由开全局模式,简单粗暴,等ha启动以后再改回来。
Awe7 手机认证
发表于 2024-8-17 21:16:54 | 显示全部楼层
回帖奖励 +1 金钱
zfgjy2005 发表于 2024-8-17 20:10
你这会启动的时候,把路由开全局模式,简单粗暴,等ha启动以后再改回来。 ...
ha不能启动如何在冬瓜大佬的ha 7681  端口内设置网关地址为旁路路由器网关地址呢??
Awe7 手机认证
发表于 2024-8-17 21:18:03 | 显示全部楼层
Awe7 发表于 2024-8-17 21:16
ha不能启动如何在冬瓜大佬的ha 7681  端口内设置网关地址为旁路路由器网关地址呢?? ...
Waiting for the Home Assistant CLI 内设置
发表于 2024-8-17 22:11:06 | 显示全部楼层
https://bbs.hassbian.com/thread-21456-1-1.html
网关和dns 改成 旁路由
发表于 2024-8-20 13:43:10 | 显示全部楼层
wgtubro autoscan 命令
第一步:wgturbo autoscan -A 查看测速列表(那个加速站可用,至少测2次,第一次可能因为dns问题而测速不准)
第二步:wgturbo autoscan -S 1 全部测速并选用最快站点
第三步:wgturbo source change 命令快速换源
更新addons仓库(webui)
冬瓜已经把addons仓库中的镜像全部移到dockerhub上了,可以用系统加速。
 楼主| 发表于 2024-8-22 12:23:06 | 显示全部楼层
网关和dns 改成 旁路由
直接在设置网络那里改就行了,之前我改了,好像有效果。
 楼主| 发表于 2024-8-22 12:24:08 | 显示全部楼层
我小白,旁路由,不太清楚怎么打开
GMT+8, 2025-8-2 16:19 , Processed in 0.154671 second(s), 15 queries , MemCached On.
