查看: 1764|回复: 1
[已解决] 关于两个传感器(开关)同时判断关灯无法实现的问题
发表于 2024-8-15 01:13:35 | 显示全部楼层 |阅读模式
目前浴室有两个人体存在传感器,买的传感器是个自制牌子,通过xiaomi gateway3接入,显示是两个开关,有人就开没人就关。目前都装在卫生间(由于卫生间形状奇怪需要两个传感器前两个是传感器,后两个是灯):
现在想写一个自动化流程,两个传感器都关闭才关灯,写成这样,单个传感器关闭后,且的条件根本不判断就直接关灯了,求助应该如何判断另一个开关目前状态呢?谢谢大佬。
description: ""
trigger:
  - platform: device
    type: turned_off
    device_id: 6f44168d1434fcbf5aef5c1289c27a4a
    entity_id: 3388d14fb3e19ad05729e8c3fcbd9abb
    domain: switch
condition:
  - condition: device
    type: is_off
    device_id: c8d360e12573b220a0edd5d6b815434c
    entity_id: 52d7c2789d53cbc3d2f7e1ef7252cfe9
    domain: switch
action:
  - type: turn_off
    device_id: ae714c6e592daa77166e549b5a229839
    entity_id: 9df03046bf240d362b5a4fe518ad4c2f
    domain: switch
mode: single
以下是另一种写法,也不行:
description: ""
trigger:
  - platform: device
    type: turned_off
    domain: switch
condition:
  - condition: state
    state: "off"
    entity_id: select.7cc2944ea15e_command
action:
  - type: turn_off
    domain: switch
mode: single
已解决,不能用command,要直接用设备状态:如下段:
alias: 新建自动化
description: ""
trigger:
  - platform: device
    type: turned_off
    domain: switch
condition:
  - condition: state
    state: "off"
    entity_id: switch.7cc2944ea15e_switch
action:
  - type: turn_off
    domain: switch
mode: single
发表于 2024-8-15 22:44:09 | 显示全部楼层
我的自动化基本都调用的服务
我不生产技术,我只是技术的搬运工。
GMT+8, 2025-12-14 08:06 , Processed in 0.617589 second(s), 15 queries , MemCached On.
