查看: 2193|回复: 0
[技术探讨] 重启会自动开灯
发表于 2024-8-11 10:07:57 来自手机 | 显示全部楼层 |阅读模式
03:02:59.198 MQT: test/LWT = Online (retained)
03:02:59.200 MQT: test/cmnd/POWER =
03:02:59.206 MQT: test/INFO1 = {"Info1":{"Module":"Generic","Version":"14.1.0(release-sensors)","FallbackTopic":"cmnd/tas_fb/","GroupTopic":"test/cmnd/"}}
03:02:59.214 MQT: test/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"test-3648","IPAddress":"192.168.12.21"}}
03:02:59.224 MQT: test/INFO3 = {"Info3":{"RestartReason":"Software/System restart","BootCount":82}}
03:02:59.232 MQT: test/RESULT = {"POWER":"OFF"}
03:02:59.235 MQT: test/POWER = OFF
03:03:00.002 MQT: test/RESULT = {"RfSend":"Done"}
03:03:03.250 MQT: test/STATE = {"Time":"2024-08-11T03:03:03","Uptime":"0T00:00:44","UptimeSec":44,"Heap":20,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"3hf0","BSSId":"76:7D:A3:D5","Channel":6,"Mode":"11n","RSSI":98,"Signal":-51,"LinkCount":1,"Downtime":"0T00:00:04"}}
03:03:03.276 MQT: test/SENSOR = {"Time":"2024-08-11T03:03:03","DHT11":{"Temperature":28.5,"Humidity":74.0,"DewPoint":23.4},"TempUnit":"C"}
03:03:11.038 MQT: test/RESULT = {"POWER":"ON"}
03:03:11.041 MQT: test/POWER = ON
03:03:12.047 MQT: test/RESULT = {"POWER":"OFF"}
03:03:12.050 MQT: test/POWER = OFF
我用8266刷了tasmota,接入rfsend,每次重启8266或者mqtt服务器,就会发射一次开灯信号,这个怎么回事?如何修正呢
GMT+8, 2026-1-14 01:20 , Processed in 1.468422 second(s), 6 queries , MemCached On.
