楼主: yxl150985
[硬件DIY] 小米摄像头开启rtsp(需要拆机修改,spiflash编程器)
发表于 2025-2-16 03:26:05 | 显示全部楼层
学习一下,看看自己动手,还是再买一个摄像头更方便。
发表于 2025-2-16 19:02:59 | 显示全部楼层
楼主可以帮我看下系统分区吗,CMSXJ36C @yxl150985
DECIMAL       HEXADECIMAL     DESCRIPTION
216940        0x34F6C         CRC32 polynomial table, little endian
221404        0x360DC         LZO compressed data
224864        0x36E60         Android bootimg, kernel size: 0 bytes, kernel addr: 0x70657250, ramdisk size: 543519329 bytes, ramdisk addr: 0x6E72656B, product name: "mem boot start"
327680        0x50000         Squashfs filesystem, little endian, version 4.0, compression:xz, size: 2201396 bytes, 865 inodes, blocksize: 131072 bytes, created: 2023-07-05 06:36:42
3080192       0x2F0000        uImage header, header size: 64 bytes, header CRC: 0x30211D78, created: 2023-06-15 06:55:25, image size: 1684202 bytes, Data Address: 0x80010000, Entry Point: 0x80396AF0, data CRC: 0x7E8F01DA, OS: Linux, CPU: MIPS, image type: OS Kernel Image, compression type: lzma, image name: "Linux-3.10.14__isvp_swan_1.0__"
3080256       0x2F0040        LZMA compressed data, properties: 0x5D, dictionary size: 67108864 bytes, uncompressed size: -1 bytes
4784128       0x490000        Squashfs filesystem, little endian, version 4.0, compression:xz, size: 4427510 bytes, 625 inodes, blocksize: 131072 bytes, created: 2023-07-05 06:36:43
9437184       0x900000        uImage header, header size: 64 bytes, header CRC: 0x30211D78, created: 2023-06-15 06:55:25, image size: 1684202 bytes, Data Address: 0x80010000, Entry Point: 0x80396AF0, data CRC: 0x7E8F01DA, OS: Linux, CPU: MIPS, image type: OS Kernel Image, compression type: lzma, image name: "Linux-3.10.14__isvp_swan_1.0__"
9437248       0x900040        LZMA compressed data, properties: 0x5D, dictionary size: 67108864 bytes, uncompressed size: -1 bytes
11141120      0xAA0000        Squashfs filesystem, little endian, version 4.0, compression:xz, size: 4427510 bytes, 625 inodes, blocksize: 131072 bytes, created: 2023-07-05 06:36:43
15794176      0xF10000        JFFS2 filesystem, little endian
15892632      0xF28098        Zlib compressed data, compressed
15893320      0xF28348        JFFS2 filesystem, little endian
15893704      0xF284C8        Zlib compressed data, compressed
15893904      0xF28590        Zlib compressed data, compressed
15894700      0xF288AC        Zlib compressed data, compressed
15894936      0xF28998        Zlib compressed data, compressed
15895624      0xF28C48        JFFS2 filesystem, little endian
15896836      0xF29104        Zlib compressed data, compressed
15897024      0xF291C0        Zlib compressed data, compressed
15897804      0xF294CC        Zlib compressed data, compressed
15898040      0xF295B8        Zlib compressed data, compressed
15898932      0xF29934        Zlib compressed data, compressed
15899208      0xF29A48        Zlib compressed data, compressed
15900080      0xF29DB0        Zlib compressed data, compressed
15900316      0xF29E9C        Zlib compressed data, compressed
15901208      0xF2A218        Zlib compressed data, compressed
15901496      0xF2A338        Zlib compressed data, compressed
15902376      0xF2A6A8        Zlib compressed data, compressed
15902612      0xF2A794        Zlib compressed data, compressed
15903504      0xF2AB10        Zlib compressed data, compressed
15903776      0xF2AC20        Zlib compressed data, compressed
15904648      0xF2AF88        Zlib compressed data, compressed
15904884      0xF2B074        Zlib compressed data, compressed
15905776      0xF2B3F0        Zlib compressed data, compressed
15906048      0xF2B500        Zlib compressed data, compressed
15906920      0xF2B868        Zlib compressed data, compressed
15907156      0xF2B954        Zlib compressed data, compressed
15908060      0xF2BCDC        Zlib compressed data, compressed
15908248      0xF2BD98        Zlib compressed data, compressed
15908564      0xF2BED4        Zlib compressed data, compressed
15908800      0xF2BFC0        Zlib compressed data, compressed
15909236      0xF2C174        Zlib compressed data, compressed
15909460      0xF2C254        Zlib compressed data, compressed
15909820      0xF2C3BC        Zlib compressed data, compressed
15910056      0xF2C4A8        Zlib compressed data, compressed
15910492      0xF2C65C        Zlib compressed data, compressed
15910720      0xF2C740        Zlib compressed data, compressed
15911080      0xF2C8A8        Zlib compressed data, compressed
15911248      0xF2C950        JFFS2 filesystem, little endian
15911752      0xF2CB48        Zlib compressed data, compressed
15912024      0xF2CC58        Zlib compressed data, compressed
15912428      0xF2CDEC        Zlib compressed data, compressed
15912596      0xF2CE94        JFFS2 filesystem, little endian
15913088      0xF2D080        Zlib compressed data, compressed
15913376      0xF2D1A0        Zlib compressed data, compressed
15914260      0xF2D514        Zlib compressed data, compressed
15914496      0xF2D600        Zlib compressed data, compressed
15915388      0xF2D97C        Zlib compressed data, compressed
15915680      0xF2DAA0        Zlib compressed data, compressed
15916564      0xF2DE14        Zlib compressed data, compressed
15916800      0xF2DF00        Zlib compressed data, compressed
15917692      0xF2E27C        Zlib compressed data, compressed
15917984      0xF2E3A0        Zlib compressed data, compressed
15918868      0xF2E714        Zlib compressed data, compressed
15919104      0xF2E800        Zlib compressed data, compressed
15919996      0xF2EB7C        Zlib compressed data, compressed
15920284      0xF2EC9C        Zlib compressed data, compressed
15921168      0xF2F010        Zlib compressed data, compressed
15921404      0xF2F0FC        Zlib compressed data, compressed
15922296      0xF2F478        Zlib compressed data, compressed
15922588      0xF2F59C        Zlib compressed data, compressed
15923468      0xF2F90C        Zlib compressed data, compressed
15923704      0xF2F9F8        Zlib compressed data, compressed
15924604      0xF2FD7C        Zlib compressed data, compressed
15924896      0xF2FEA0        Zlib compressed data, compressed
15925328      0xF30050        Zlib compressed data, compressed
15926016      0xF30300        JFFS2 filesystem, little endian
15927884      0xF30A4C        Zlib compressed data, compressed
15928172      0xF30B6C        Zlib compressed data, compressed
15929052      0xF30EDC        Zlib compressed data, compressed
15929288      0xF30FC8        Zlib compressed data, compressed
15930180      0xF31344        Zlib compressed data, compressed
15930468      0xF31464        Zlib compressed data, compressed
15931348      0xF317D4        Zlib compressed data, compressed
15931584      0xF318C0        Zlib compressed data, compressed
15932476      0xF31C3C        Zlib compressed data, compressed
15932664      0xF31CF8        Zlib compressed data, compressed
15933444      0xF32004        Zlib compressed data, compressed
15933680      0xF320F0        Zlib compressed data, compressed
15934572      0xF3246C        Zlib compressed data, compressed
15934760      0xF32528        Zlib compressed data, compressed
15935540      0xF32834        Zlib compressed data, compressed
15935776      0xF32920        Zlib compressed data, compressed
15936668      0xF32C9C        Zlib compressed data, compressed
15937040      0xF32E10        Zlib compressed data, compressed
15937964      0xF331AC        Zlib compressed data, compressed
15938200      0xF33298        Zlib compressed data, compressed
15939092      0xF33614        Zlib compressed data, compressed
15939468      0xF3378C        Zlib compressed data, compressed
15940396      0xF33B2C        Zlib compressed data, compressed
15940632      0xF33C18        Zlib compressed data, compressed
15941524      0xF33F94        Zlib compressed data, compressed
15941724      0xF3405C        Zlib compressed data, compressed
15942516      0xF34374        Zlib compressed data, compressed
15942684      0xF3441C        JFFS2 filesystem, little endian
15990864      0xF40050        Zlib compressed data, compressed
15991440      0xF40290        Zlib compressed data, compressed
15991676      0xF4037C        Zlib compressed data, compressed
15992364      0xF4062C        JFFS2 filesystem, little endian
15997320      0xF41988        Zlib compressed data, compressed
15997672      0xF41AE8        Zlib compressed data, compressed
15998592      0xF41E80        Zlib compressed data, compressed
15998828      0xF41F6C        Zlib compressed data, compressed
15999720      0xF422E8        Zlib compressed data, compressed
16000060      0xF4243C        Zlib compressed data, compressed
16000976      0xF427D0        Zlib compressed data, compressed
16001212      0xF428BC        Zlib compressed data, compressed
16002104      0xF42C38        Zlib compressed data, compressed
16002412      0xF42D6C        Zlib compressed data, compressed
16003296      0xF430E0        Zlib compressed data, compressed
16003532      0xF431CC        Zlib compressed data, compressed
16004424      0xF43548        Zlib compressed data, compressed
16004740      0xF43684        Zlib compressed data, compressed
16005628      0xF439FC        Zlib compressed data, compressed
16005864      0xF43AE8        Zlib compressed data, compressed
16006756      0xF43E64        Zlib compressed data, compressed
16007120      0xF43FD0        Zlib compressed data, compressed
16008036      0xF44364        Zlib compressed data, compressed
16008272      0xF44450        Zlib compressed data, compressed
16009164      0xF447CC        Zlib compressed data, compressed
16009484      0xF4490C        Zlib compressed data, compressed
16010380      0xF44C8C        Zlib compressed data, compressed
16010616      0xF44D78        Zlib compressed data, compressed
16011508      0xF450F4        Zlib compressed data, compressed
16011828      0xF45234        Zlib compressed data, compressed
16012720      0xF455B0        Zlib compressed data, compressed
16012956      0xF4569C        Zlib compressed data, compressed
16013848      0xF45A18        Zlib compressed data, compressed
16014172      0xF45B5C        Zlib compressed data, compressed
16015072      0xF45EE0        Zlib compressed data, compressed
16015308      0xF45FCC        Zlib compressed data, compressed
16016200      0xF46348        Zlib compressed data, compressed
16016520      0xF46488        Zlib compressed data, compressed
16017412      0xF46804        Zlib compressed data, compressed
16017648      0xF468F0        Zlib compressed data, compressed
16018540      0xF46C6C        Zlib compressed data, compressed
16018860      0xF46DAC        Zlib compressed data, compressed
16019752      0xF47128        Zlib compressed data, compressed
16019988      0xF47214        Zlib compressed data, compressed
16020880      0xF47590        Zlib compressed data, compressed
16021072      0xF47650        Zlib compressed data, compressed
16021856      0xF47960        Zlib compressed data, compressed
16022092      0xF47A4C        Zlib compressed data, compressed
16022992      0xF47DD0        Zlib compressed data, compressed
16023200      0xF47EA0        Zlib compressed data, compressed
16023632      0xF48050        Zlib compressed data, compressed
16024208      0xF48290        Zlib compressed data, compressed
16024444      0xF4837C        Zlib compressed data, compressed
16025132      0xF4862C        JFFS2 filesystem, little endian
16030192      0xF499F0        Zlib compressed data, compressed
16030484      0xF49B14        Zlib compressed data, compressed
16031368      0xF49E88        Zlib compressed data, compressed
16031604      0xF49F74        Zlib compressed data, compressed
16032496      0xF4A2F0        Zlib compressed data, compressed
16032788      0xF4A414        Zlib compressed data, compressed
16033672      0xF4A788        Zlib compressed data, compressed
16033908      0xF4A874        Zlib compressed data, compressed
16034800      0xF4ABF0        Zlib compressed data, compressed
16035092      0xF4AD14        Zlib compressed data, compressed
16035976      0xF4B088        Zlib compressed data, compressed
16036212      0xF4B174        Zlib compressed data, compressed
16037104      0xF4B4F0        Zlib compressed data, compressed
16037292      0xF4B5AC        Zlib compressed data, compressed
16038072      0xF4B8B8        Zlib compressed data, compressed
16038308      0xF4B9A4        Zlib compressed data, compressed
16039200      0xF4BD20        Zlib compressed data, compressed
16039388      0xF4BDDC        Zlib compressed data, compressed
16040168      0xF4C0E8        Zlib compressed data, compressed
16040404      0xF4C1D4        Zlib compressed data, compressed
16042632      0xF4CA88        Zlib compressed data, compressed
16042828      0xF4CB4C        Zlib compressed data, compressed
16043616      0xF4CE60        Zlib compressed data, compressed
16043852      0xF4CF4C        Zlib compressed data, compressed
16044608      0xF4D240        JFFS2 filesystem, little endian
16046080      0xF4D800        Zlib compressed data, compressed
16046268      0xF4D8BC        Zlib compressed data, compressed
16047048      0xF4DBC8        Zlib compressed data, compressed
16047284      0xF4DCB4        Zlib compressed data, compressed
16048176      0xF4E030        Zlib compressed data, compressed
16048364      0xF4E0EC        Zlib compressed data, compressed
16049144      0xF4E3F8        Zlib compressed data, compressed
16049380      0xF4E4E4        Zlib compressed data, compressed
16050272      0xF4E860        Zlib compressed data, compressed
16050548      0xF4E974        Zlib compressed data, compressed
16051420      0xF4ECDC        Zlib compressed data, compressed
16051656      0xF4EDC8        Zlib compressed data, compressed
16052548      0xF4F144        Zlib compressed data, compressed
16052836      0xF4F264        Zlib compressed data, compressed
16053712      0xF4F5D0        Zlib compressed data, compressed
16053948      0xF4F6BC        Zlib compressed data, compressed
16054844      0xF4FA3C        Zlib compressed data, compressed
16055124      0xF4FB54        Zlib compressed data, compressed
16056016      0xF4FED0        Zlib compressed data, compressed
16056320      0xF50000        Squashfs filesystem, little endian, version 4.0, compression:xz, size: 448366 bytes, 62 inodes, blocksize: 131072 bytes, created: 2023-07-05 06:36:44
16711821      0xFF008D        Unix path: /sys/class/gpio/gpio11/value
发表于 2025-2-16 20:35:17 | 显示全部楼层
需要拆机修改,spiflash编程器
发表于 2025-2-17 02:20:21 | 显示全部楼层
学习学习
发表于 2025-2-17 03:11:27 | 显示全部楼层
学习一下
发表于 2025-2-19 22:40:08 | 显示全部楼层
感谢大佬
lixx 手机认证
发表于 2025-2-19 23:06:57 | 显示全部楼层
回帖看一下
发表于 2025-2-20 09:49:46 | 显示全部楼层
发表于 2025-3-7 22:07:48 | 显示全部楼层
这个高端啊
发表于 2025-3-8 15:49:15 | 显示全部楼层
不知道小白的能不能行
GMT+8, 2026-1-16 09:51 , Processed in 0.437808 second(s), 10 queries , MemCached On.
