查看: 2680|回复: 2
[硬件DIY] pwm风扇怎么设置淡入淡出效果
发表于 2024-8-3 07:31:39 | 显示全部楼层 |阅读模式
关闭风扇时候直接从100变成0.电机会惯性震荡.按不住啊.在触发关闭动作时候缓慢调到低至关闭而不是直接关闭防止引起抖动.等大佬作业output:
  - platform: ledc
    pin: GPIO5
    frequency: 15000 Hz
    max_power: "0.7"
    inverted: true
fan:
  - platform: speed
    output: output_1
    name: "DC Move Fan"
    on_turn_on:
      then:
        - lambda: |-
            for (int i = 0; i <= 100; i += 10) {
              fan.set_speed(id(fan_speed), i);
              delay(100);  // 延迟100ms,调整以改变淡入速度
    on_turn_off:
      then:
        - lambda: |-
            for (int i = 100; i >= 0; i -= 10) {
              delay(100);  // 延迟100ms,调整以改变淡出速度
switch:
  - platform: gpio
    pin:
      number: GPIO6
      inverted: true
      mode:
        output: true
        open_drain: true
    restore_mode: ALWAYS_ON
  - platform: gpio
    pin:
      number: GPIO4
      mode:
        output: true
        open_drain: true
    restore_mode: ALWAYS_OFF
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      #inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_on: 1000ms
      - delayed_off: 1000ms
    on_press:
      - fan.turn_on:
          speed: 80
  # - platform: gpio
  #   pin:
  #     number: GPIO1
  #     inverted: true
  #     mode:
  #       input: true
  #       pullup: true
  #   name: "1"
  - platform: gpio
    pin:
      number: GPIO2
      #inverted: true
      mode:
        input: true
        pullup: true
    filters:
    on_press:
      - fan.turn_on:
          speed: 99
  - platform: gpio
    pin:
      number: GPIO3
      #inverted: true
      mode:
        input: true
        pullup: true
    filters:
    on_press:
      - fan.turn_on:
          speed: 70
  # - platform: gpio
  #   pin:
  #     number: GPIO7
  #     inverted: true
  #     mode:
  #       input: true
  #       pullup: true
  #   name: "7"
  # - platform: gpio
  #   pin: GPIO10
  #   name: 10
  - platform: gpio
    pin:
      number: GPIO21
      #inverted: true
      mode:
        input: true
        pullup: true
发表于 2024-8-3 09:08:16 | 显示全部楼层
output:
  - platform: ledc
    frequency: 40000Hz
    pin: 0
fan:
  - platform: speed
    output: ${device_name}_ledc
发表于 2024-8-3 12:05:00 | 显示全部楼层
可以用自动化,100-10可以设置成1分钟甚至10分钟,随心所欲。
GMT+8, 2026-1-23 15:39 , Processed in 0.049630 second(s), 8 queries , MemCached On.
