查看: 10642|回复: 7
[已解决] hass升级到0.62后空净出错
发表于 2018-1-29 19:53:30 | 显示全部楼层 |阅读模式
xiaomi_miio: Error on device update!
下午7:42 components/fan/xiaomi_miio.py (ERROR)
以上是错误提示,求助
发表于 2018-1-29 23:49:08 | 显示全部楼层
删除 deps
发表于 2018-1-29 23:57:33 | 显示全部楼层
2018-01-29 23:57:12 ERROR (MainThread) [homeassistant.helpers.entity] Update for vacuum.robot fails
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 201, in async_update_ha_state
    yield from self.async_device_update()
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 308, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 297, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/vacuum/xiaomi_miio.py", line 368, in update
    state = self._vacuum.status()
  File "/srv/homeassistant/lib/python3.5/site-packages/miio/vacuum.py", line 108, in status
    return VacuumStatus(self.send("get_status")[0])
  File "/srv/homeassistant/lib/python3.5/site-packages/miio/device.py", line 216, in send
    m = Message.build(msg, ctx)
TypeError: build() takes 2 positional arguments but 3 were given
发表于 2018-1-29 23:58:36 | 显示全部楼层
上面是日志,我的扫地机和空净都不行了。怎么解决?之前升级62没问题。又升一下就出问题了。
发表于 2018-1-30 00:16:08 | 显示全部楼层
解决了
sudo /etc/init.d/hass-daemon stop
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/bin/activate
pip3 install construct==2.8.22
参与人数 1金钱 +10 收起 理由
+ 10 赠人玫瑰,手留余香!
发表于 2018-1-30 08:54:09 | 显示全部楼层
mark一下!
发表于 2018-1-30 11:57:38 | 显示全部楼层
construct降级了就好了,扫地机也是一样
 楼主| 发表于 2018-1-30 13:28:12 | 显示全部楼层
感谢大家,降级construct后可以了
GMT+8, 2025-12-25 09:52 , Processed in 0.051979 second(s), 7 queries , MemCached On.
