查看: 1469|回复: 2
[求助] ha侧边栏没有能源,历史,日志等
发表于 2024-7-27 23:55:33 | 显示全部楼层 |阅读模式
悬赏100金钱未解决
具体是之前有段时间闲置了ha,最近又重新拾起来了,用的旧版本的备份文件,备份到新系统。然后能源之类的就不显示了。寻找大佬,跪求解决。愿奉上200红包。 1a603bf86cc6aadd7d9ab8faab5afd7.jpg 4b93b23846694ce74aae619750b5905.jpg a5de423623a80b869414829c35a23be.jpg 日志记录器: homeassistant.components.recorder.core来源: components/recorder/core.py:951
集成: recorder (文档, 问题)
首次出现: 20:15:39 (10 次总计出现)
上次记录: 20:16:06
Error during connection setup: (retrying in 3 seconds)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 146, in __init__
    self._dbapi_connection = engine.raw_connection()
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 3300, in raw_connection
    return self.pool.connect()
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 449, in connect
    return _ConnectionFairy._checkout(self)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 1263, in _checkout
    fairy = _ConnectionRecord.checkout(pool)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 712, in checkout
    rec = pool._do_get()
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/impl.py", line 179, in _do_get
    with util.safe_reraise():
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/util/langhelpers.py", line 146, in __exit__
    raise exc_value.with_traceback(exc_tb)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/impl.py", line 177, in _do_get
    return self._create_connection()
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 390, in _create_connection
    return _ConnectionRecord(self)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 674, in __init__
    self.__connect()
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 900, in __connect
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/pool/base.py", line 896, in __connect
    self.dbapi_connection = connection = pool._invoke_creator(self)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/create.py", line 643, in connect
    return dialect.connect(*cargs, **cparams)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 620, in connect
    return self.loaded_dbapi.connect(*cargs, **cparams)
  File "/usr/local/lib/python3.12/site-packages/MySQLdb/__init__.py", line 121, in Connect
    return Connection(*args, **kwargs)
  File "/usr/local/lib/python3.12/site-packages/MySQLdb/connections.py", line 195, in __init__
    super().__init__(*args, **kwargs2)
MySQLdb.OperationalError: (2002, "Can't connect to server on 'core-mariadb' (115)")
The above exception was the direct cause of the following exception:
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 951, in _setup_recorder
    self._setup_connection()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1466, in _setup_connection
    Base.metadata.create_all(self.engine)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/sql/schema.py", line 5871, in create_all
    bind._run_ddl_visitor(
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 3250, in _run_ddl_visitor
    with self.begin() as conn:
  File "/usr/local/lib/python3.12/contextlib.py", line 137, in __enter__
    return next(self.gen)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 3240, in begin
    with self.connect() as conn:
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 3276, in connect
    return self._connection_cls(self)
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 148, in __init__
    Connection._handle_dbapi_exception_noconnection(
  File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2440, in _handle_dbapi_exception_noconnection
    raise sqlalchemy_exception.with_traceback(exc_info[2]) from e
    self.__connect()
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (2002, "Can't connect to server on 'core-mariadb' (115)")
(Background on this error at: https://sqlalche.me/e/20/e3q8)
发表于 2024-7-28 07:58:24 来自手机 | 显示全部楼层
版本更新,重新配置一下就行了
发表于 2024-7-29 00:41:34 | 显示全部楼层
重新配置下就好了。跨版本太大的话,是要修一堆东西。
我不生产技术,我只是技术的搬运工。
GMT+8, 2025-12-16 07:21 , Processed in 0.137161 second(s), 13 queries , MemCached On.
