查看: 14098|回复: 9
[求助] homeassistan 无法连接上bridge?
发表于 2018-1-29 19:24:31 | 显示全部楼层 |阅读模式
hass.io装的 homebridge。在log出现了一下错误,这是什么情况,端口不对吗?哪里可以改
[2018-1-29 19:21:01] [HomeAssistant] Failed getting devices: Error: connect ECONNREFUSED 192.168.1.138:80. Retrying...[2018-1-29 19:21:06] [HomeAssistant] Fetching HomeAssistant devices.[2018-1-29 19:21:06] [HomeAssistant] Failed getting devices: Error: connect ECONNREFUSED 192.168.1.138:80. Retrying...
发表于 2018-1-29 20:03:23 来自手机 | 显示全部楼层
检查homeassistant地址和端口跟错误信息里一样
 楼主| 发表于 2018-1-29 20:31:04 | 显示全部楼层
        "bridge": {
                "name": "Home Assistant",
                "username": "00:15:5D:C7:75:14",
                "port": 51826,
                "pin": "681-29-591"
        "description": "Homebridge for Home Assistant",
        "accessories": [],
        "platforms": [{
                "platform": "HomeAssistant",
                "name": "HomeAssistant",
                "host": "http://192.168.1.138/8123",
                "password": "",
                "default_visibility": "visible",
                "supported_types": [
                        "automation",
                        "binary_sensor",
                        "climate",
                        "cover",
                        "device_tracker",
                        "fan",
                        "group",
                        "input_boolean",
                        "light",
                        "lock",
                        "media_player",
                        "remote",
                        "scene",
                        "script",
                        "sensor",
                        "switch",
                        "vacuum"
                "logging": true,
                "verify_ssl": true
hassio ,IP 是上面的192.168.1.138:8123
发表于 2018-1-29 23:48:09 来自手机 | 显示全部楼层
Username 是主机物理地址拿吗
 楼主| 发表于 2018-1-29 23:58:08 | 显示全部楼层
是的,是装着hassio的虚拟机ubuntu的mac,在路由器上确认过了
发表于 2018-1-30 09:46:56 | 显示全部楼层
        "bridge": {
                "port": 51826,
                "pin": "681-29-591"
        "accessories": [],
        "platforms": [{
                "host": "http://192.168.1.138:8123",
                "password": "",
                        "automation",
                        "binary_sensor",
                        "climate",
                        "cover",
                        "device_tracker",
                        "fan",
                        "group",
                        "input_boolean",
                        "light",
                        "lock",
                        "media_player",
                        "remote",
                        "scene",
                        "script",
                        "sensor",
                        "switch",
                        "vacuum"
                "logging": true,
                "verify_ssl": true
 楼主| 发表于 2018-1-30 10:33:27 | 显示全部楼层
jaccy 发表于 2018-1-30 09:46
        "bridge": {
这个需要改成80吗?
发表于 2018-1-30 10:58:48 | 显示全部楼层
你写错了                  "host": "http://192.168.1.138/8123",
改去这个                 "host": "http://192.168.1.138:8123",
不要放80,用回8123
 楼主| 发表于 2018-1-30 11:46:46 | 显示全部楼层
改去这个                 "host": "htt ...
好的,谢谢大佬
发表于 2018-2-11 09:17:59 | 显示全部楼层
        "bridge": {
homekit连上ha后发现不了下面的开关是什么问题??
GMT+8, 2025-11-7 21:30 , Processed in 0.062434 second(s), 8 queries , MemCached On.
