查看: 1364|回复: 0
[求助] 错误 :Custom element doesn't exist: config-template-card.
发表于 2024-7-27 10:40:41 | 显示全部楼层 |阅读模式
明明安装了  config-template-card还是出现 Custom element doesn't exist: config-template-card. 换了几个浏览器都这样群晖docker安装ha,hacs安装插件后在这个目录
kiosk_mode:
  hide_header: true
  hide_sidebar: true
####################      Floor plan 家庭总览                 ############################
  - theme: Backend-selected
    title: Plan
    path: plan
    icon: mdi:floor-plan
    type: panel
    badges: []
    cards:
      - type: custom:config-template-card
        entities:
          - switch.lumi_ctrl_neutral1_v1_a84c_switch
          - switch.sonoff_4
          - switch.sonoff_1001db6d08_1
        card:
          type: picture-elements
          image: /local/home/1-Q-A.png
          elements:
###################################        灯光控制 | light       ###################################
            - type: image
              entity: switch.lumi_ctrl_neutral1_v1_a84c_switch
              tap_action:
                action: none
              style:
                pointer-events: none
                top: 50%
                left: 50%
                width: 100%
                mix-blend-mode: lighten
              state_image:
                'off': /local/home/K.png
                'on': /local/home/1-CT.png
            - type: image
              tap_action:
                action: toggle
              style:
                top: 45%
                left: 70.6%
                width: 7%
              state_image:
                'off': /local/home/light_off.png
                'on': /local/home/light_on.png
            - type: image
              entity: switch.sonoff_1001db6d08_1
              tap_action:
                action: none
              style:
                top: 50%
                left: 50%
                width: 100%
              state_image:
                'on': /local/home/1-W2.png
            - type: image
              tap_action:
                action: toggle
              style:
                top: 35.6%
                left: 39.5%
                width: 7%
              state_image:
            - type: image
              entity: switch.sonoff_4
              tap_action:
                action: none
              style:
                top: 50%
                left: 50%
                width: 100%
              state_image:
                'on': /local/home/1-MT
            - type: image
              tap_action:
                action: toggle
              style:
                top: 40%
                left: 55%
                width: 7%
              state_image:
GMT+8, 2025-12-17 08:20 , Processed in 0.049426 second(s), 6 queries , MemCached On.
