查看: 17680|回复: 11
[技术探讨] 更新了HA0.62后登陆UI一直显示Loading data问题(已解决)
发表于 2018-1-29 13:56:47 | 显示全部楼层 |阅读模式
我是由0.61更新到0.62的,更新后登陆输入密码后一直处于Loading data不进入网页(如下图),试图删除broadlink还是无果。求助,谢谢! CHC}_H}IDBC[HZYIFJ6FI}W.png
1月 29 14:01:20 Z hass[2042]: 2018-01-29 14:01:20 ERROR (MainThread) [homeassistant.components.sensor] CaiyunweatherSE: Error on device update!
1月 29 14:01:20 Z hass[2042]: Traceback (most recent call last):
1月 29 14:01:20 Z hass[2042]:   File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 397, in _async_add_entity
1月 29 14:01:20 Z hass[2042]:     yield from entity.async_device_update(warning=False)
1月 29 14:01:20 Z hass[2042]:   File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity.py", line 308, in async_device_update
1月 29 14:01:20 Z hass[2042]:     yield from self.hass.async_add_job(self.update)
1月 29 14:01:20 Z hass[2042]:   File "/usr/lib/python3.5/asyncio/futures.py", line 361, in __iter__
1月 29 14:01:20 Z hass[2042]:     yield self  # This tells Task to wait for completion.
1月 29 14:01:20 Z hass[2042]:   File "/usr/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
1月 29 14:01:20 Z hass[2042]:     future.result()
1月 29 14:01:20 Z hass[2042]:   File "/usr/lib/python3.5/asyncio/futures.py", line 274, in result
1月 29 14:01:20 Z hass[2042]:     raise self._exception
1月 29 14:01:20 Z hass[2042]:   File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
1月 29 14:01:20 Z hass[2042]:     result = self.fn(*self.args, **self.kwargs)
1月 29 14:01:20 Z hass[2042]:   File "/home/homeassistant/.homeassistant/custom_components/sensor/CaiyunweatherSE.py", line 844, in update
1月 29 14:01:20 Z hass[2042]:     prec8h_data = {str(i):self.get_entityid_data(self.entityid_filepath) ['result']['hourly']['precipitation']['value']}
1月 29 14:01:20 Z hass[2042]: TypeError: 'NoneType' object is not subscriptable
hugo
发表于 2018-1-29 14:11:36 | 显示全部楼层
更新后UI登陆不上问题一般跟设备配置不大的,最简单就是换个浏览器试试
发表于 2018-1-29 14:13:28 | 显示全部楼层
看看日志吧
 楼主| 发表于 2018-1-29 14:20:33 | 显示全部楼层
27hh
教程狂人论坛风云人物
发表于 2018-1-29 14:27:56 | 显示全部楼层
日志写得很明白,彩云天气有问题
发表于 2018-1-29 14:28:05 | 显示全部楼层
先把才有删了吧
发表于 2018-1-29 14:43:29 | 显示全部楼层
彩云的帖子已经修复问题,你是太久没更新彩云吧
 楼主| 发表于 2018-1-29 14:46:56 | 显示全部楼层
删除彩云了,问题依旧
1月 29 14:42:01 Z hass[2443]: 2018-01-29 14:42:01 INFO (MainThread) [homeassistant.components.http] Serving / to 192.168.1.146 (auth: False)
1月 29 14:42:01 Z hass[2443]: 2018-01-29 14:42:01 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 192.168.1.146 (auth: False)
1月 29 14:42:01 Z hass[2443]: 2018-01-29 14:42:01 ERROR (MainThread) [homeassistant.loader] Unable to find component downloader2
1月 29 14:42:01 Z hass[2443]: 2018-01-29 14:42:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
1月 29 14:42:01 Z hass[2443]: Traceback (most recent call last):
1月 29 14:42:01 Z hass[2443]:   File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
1月 29 14:42:01 Z hass[2443]:     result = coro.send(None)
1月 29 14:42:01 Z hass[2443]:   File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/websocket_api.py", line 473, in get_services_helper
1月 29 14:42:01 Z hass[2443]:     descriptions = yield from async_get_all_descriptions(self.hass)
1月 29 14:42:01 Z hass[2443]:   File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 154, in async_get_all_descriptions
1月 29 14:42:01 Z hass[2443]:     missing.add(domain_yaml_file(domain))
1月 29 14:42:01 Z hass[2443]:   File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 133, in domain_yaml_file
1月 29 14:42:01 Z hass[2443]:     component_path = path.dirname(get_component(domain).__file__)
1月 29 14:42:01 Z hass[2443]: AttributeError: 'NoneType' object has no attribute '__file__'
1月 29 14:42:02 Z hass[2443]: 2018-01-29 14:42:02 INFO (MainThread) [homeassistant.components.http] Serving /api/themes to 192.168.1.146 (auth: True)
 楼主| 发表于 2018-1-29 14:48:32 | 显示全部楼层
是呢,基础差,有些内容一知半解就跳过了。
 楼主| 发表于 2018-1-29 15:01:43 | 显示全部楼层
感谢各位解答,困扰两天问题解决了。是彩云引起,更新了就没事了。再次谢谢,谢谢!
GMT+8, 2026-1-8 08:10 , Processed in 0.735664 second(s), 10 queries , MemCached On.
