查看: 980|回复: 0
[求助] 8123报错,请大佬帮忙看看
发表于 2024-7-21 10:58:25 | 显示全部楼层 |阅读模式
s6-rc: info: service s6rc-oneshot-runner: startings6-rc: info: service s6rc-oneshot-runner successfully starteds6-rc: info: service fix-attrs: startings6-rc: info: service fix-attrs successfully starteds6-rc: info: service legacy-cont-init: startingcont-init: info: running /etc/cont-init.d/udev.shINFO: Using udev information from hostcont-init: info: /etc/cont-init.d/udev.sh exited 0s6-rc: info: service legacy-cont-init successfully starteds6-rc: info: service legacy-services: startingservices-up: info: copying legacy longrun supervisor (no readiness notification)services-up: info: copying legacy longrun watchdog (no readiness notification)INFO: Starting local supervisor watchdog...s6-rc: info: service legacy-services successfully started[__main__] Initializing Supervisor setup[supervisor.bootstrap] Setting up coresys for machine: qemux86-64[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.06.2[supervisor.docker.supervisor] Connecting Supervisor to hassio-network[supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2024.06.0'][supervisor.resolution.evaluate] Starting system evaluation with state initialize[supervisor.resolution.evaluate] System evaluation complete[__main__] Setting up Supervisor[supervisor.api] Starting API on 172.30.32.2[supervisor.hardware.monitor] Started Supervisor hardware monitor[supervisor.dbus.manager] Connected to system D-Bus.[supervisor.dbus.agent] Load dbus interface io.hass.os[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1[supervisor.host.services] Updating service information[supervisor.host.sound] Updating PulseAudio information[supervisor.host.network] Updating local network information[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}[supervisor.docker.monitor] Started docker events monitor[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.05.0[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0[supervisor.plugins.dns] Updated /etc/resolv.conf[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage[supervisor.homeassistant.core] Starting HomeAssistant landingpage[supervisor.os.manager] Detect Home Assistant Operating System 12.4 / BootSlot A[supervisor.store.git] Loading add-on /data/addons/core repository[supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository[supervisor.store.git] Cloning add-on https://github.com/music-assistant/home-assistant-addon repository[supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository[supervisor.store.git] Can't clone https://github.com/music-assistant/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/music-assistant/home-assistant-addon /data/addons/git/d5369777stderr: 'Cloning into '/data/addons/git/d5369777'...POST git-upload-pack (175 bytes)error: RPC failed; curl 28 Failed to connect to github.com port 443 after 134353 ms: Couldn't connect to serverfatal: expected flush after ref listing'.[supervisor.store] Can't retrieve data from https://github.com/music-assistant/home-assistant-addon due to[supervisor.resolution.module] Create new suggestion execute_remove - store / d5369777[supervisor.resolution.module] Create new issue fatal_error - store / d5369777[supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove[supervisor.addons.manager] Found 0 installed add-ons[supervisor.backups.manager] Found 0 backup files[supervisor.discovery] Loaded 0 messages[supervisor.ingress] Loaded 0 ingress sessions[supervisor.resolution.check] Starting system checks with state setup[supervisor.resolution.checks.base] Run check for multiple_data_disks/system[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon[supervisor.resolution.checks.base] Run check for disabled_data_disk/system[supervisor.resolution.check] System checks complete[supervisor.resolution.evaluate] Starting system evaluation with state setup[supervisor.resolution.evaluate] System evaluation complete[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup[supervisor.resolution.evaluate] Starting system evaluation with state setup[supervisor.resolution.evaluate] System evaluation complete[__main__] Running Supervisor[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons[supervisor.addons.manager] Phase 'system' starting 0 add-ons[supervisor.addons.manager] Phase 'services' starting 0 add-ons[supervisor.core] Skipping start of Home Assistant[supervisor.addons.manager] Phase 'application' starting 0 add-ons[supervisor.misc.tasks] All core tasks are scheduled[supervisor.core] Supervisor is up and running[supervisor.homeassistant.core] Home Assistant setup[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.3[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.7.3.[supervisor.host.info] Updating local host information[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json[supervisor.resolution.check] Starting system checks with state running[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server[supervisor.resolution.checks.base] Run check for docker_config/system[supervisor.resolution.checks.base] Run check for trust/supervisor[supervisor.resolution.checks.base] Run check for multiple_data_disks/system[supervisor.resolution.checks.base] Run check for security/core[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system[supervisor.resolution.checks.base] Run check for free_space/system[supervisor.resolution.checks.base] Run check for no_current_backup/system[supervisor.resolution.module] Create new suggestion create_full_backup - system / None[supervisor.resolution.module] Create new issue no_current_backup - system / None[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server[supervisor.host.services] Updating service information[supervisor.host.network] Updating local network information[supervisor.host.sound] Updating PulseAudio information[supervisor.host.manager] Host information reload completed[supervisor.resolution.checks.base] Run check for pwned/addon[supervisor.resolution.checks.base] Run check for disabled_data_disk/system[supervisor.resolution.check] System checks complete[supervisor.resolution.evaluate] Starting system evaluation with state running[supervisor.resolution.evaluate] System evaluation complete[supervisor.resolution.fixup] Starting system autofix at state running[supervisor.resolution.fixup] System autofix complete
GMT+8, 2025-12-17 08:20 , Processed in 0.335832 second(s), 10 queries , MemCached On.
