查看: 2873|回复: 6
[技术探讨] 小米空调的字体颜色跟格力的不一样,这个有办法自己改?
发表于 2024-7-17 16:13:29 | 显示全部楼层 |阅读模式
在ha这里,小米是蓝色字体,格力是黑色字体。同样的在homekit也是这个样子。如下面的图
发表于 2024-7-17 20:46:21 | 显示全部楼层
mod card可以修改 css
发表于 2024-7-18 01:56:53 | 显示全部楼层
开了就是蓝色的了,关了就是黑色的。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2024-7-18 09:01:53 | 显示全部楼层
zxyny1989 发表于 2024-7-18 01:56
开了就是蓝色的了,关了就是黑色的。
格力的开了也是黑色
发表于 2024-7-19 00:11:39 | 显示全部楼层
guangidan 发表于 2024-7-18 09:01
格力的开了也是黑色
我刚看了下,温度确实是黑的
我不生产技术,我只是技术的搬运工。
发表于 2024-7-19 12:39:40 | 显示全部楼层
homekit   怎么链接到手机的  苹果手机扫码链接不上 怎么回事  是哪里不对
发表于 2024-7-28 01:19:12 | 显示全部楼层
There are two characteristics at play here: CurrentHeatingCoolingState and TargetHeatingCoolingState. Your thermostat accessory provides the value for the current state, while you provide it with the target value.
"Heat to xx" implies the target state is set to HEAT, while the current state is not there yet (it's busy turning on) or you've reached your target temperature so the current state is OFF.
"Heating to xx" on the other hand means the current state is HEAT, thus actively heating up your place. The colors are indicative of the current state as well. Black = off, Orange = HEAT, Blue = COOL.
Source: I've hacked together a homekit enabled smart thermostat
看起来是跟状态有关系
GMT+8, 2026-1-14 04:36 , Processed in 0.962833 second(s), 16 queries , MemCached On.
