查看: 2165|回复: 1
[插件集成] 装了Portainer的addons,但是启动不成功,怎么打开Protection mode
发表于 2024-7-6 09:37:00 | 显示全部楼层 |阅读模式
Portainer addon成功安装了
但是没有启动成功
看log 有这么一段
[09:29:40] FATAL: PROTECTION MODE IS ENABLED![09:29:40] FATAL:
[09:29:40] FATAL: To be able to use this add-on, you'll need to disable
[09:29:40] FATAL: protection mode on this add-on. Without it, the add-on
[09:29:40] FATAL: is unable to access Docker.
[09:29:40] FATAL:
[09:29:40] FATAL: Steps:
[09:29:40] FATAL:  - Go to the Supervisor Panel.
[09:29:40] FATAL:  - Click on this add-on.
[09:29:40] FATAL:  - Set the 'Protection mode' switch to off.
[09:29:40] FATAL:  - Restart the add-on.
[09:29:40] FATAL:
[09:29:40] FATAL: Access to Docker allows you to do really powerful things
[09:29:40] FATAL: including complete destruction of your system.
[09:29:40] FATAL: Please, be sure you know what you are doing before
[09:29:40] FATAL: enabling this feature (and this add-on)!
[09:29:40] FATAL: [cont-init.d] 31-portainer.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
我的HAOS 信息如下。我找了半天没找到这个Protection mode switch的在哪里。有哪位大神能告知下么?
  • Core:2024.7.1
  • Supervisor:2024.06.2
  • Operating System:12.4
  • Frontend:20240705.0.
发表于 2024-10-23 15:20:10 | 显示全部楼层
关闭运行的安全保护就可以启动了:
Steps:
Restart the add-on.
GMT+8, 2025-12-16 00:02 , Processed in 0.972346 second(s), 11 queries , MemCached On.
