查看: 2006|回复: 2
[求助] 部署开发容器
发表于 2024-7-4 00:04:50 | 显示全部楼层 |阅读模式
昨天手贱,无意中删除了之前部署的容器
到现在部署不回来了
哪位大佬给点思路呢?
用Codespace能打开,但是,总所周知的原因,想部署在本地。
VSCode通过SSH连接Ubuntu的docker
在部署的时候
一直报错:
Resolved 89 packages in 951ms
Audited 89 packages in 0.23ms
An error has occurred: FatalError: git failed. Is it installed, and are you in a Git repository directory?
Check the log at /home/vscode/.cache/pre-commit/pre-commit.log
[36491 ms] postCreateCommand failed with exit code 1. Skipping any further user-provided commands.
jjcs 手机认证
发表于 2024-7-4 10:32:03 | 显示全部楼层
日志很明确了
 楼主| 发表于 2024-7-4 14:56:15 | 显示全部楼层
这是HA生成的容器,容器环境都是HA配置的。我进入到docker里面查看,也有git
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/git.py", line 58, in get_root
    cmd_output('git', 'rev-parse', '--show-cdup')[1].strip(),
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/util.py", line 117, in cmd_output
    returncode, stdout_b, stderr_b = cmd_output_b(*cmd, **kwargs)
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/util.py", line 111, in cmd_output_b
    raise CalledProcessError(returncode, cmd, stdout_b, stderr_b)
pre_commit.util.CalledProcessError: command: ('/usr/local/bin/git', 'rev-parse', '--show-cdup')
return code: 128
stdout: (none)
stderr:
    fatal: not a git repository (or any parent up to mount point /workspaces)
    Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/error_handler.py", line 73, in error_handler
    yield
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/main.py", line 373, in main
    _adjust_args_and_chdir(args)
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/main.py", line 183, in _adjust_args_and_chdir
    toplevel = git.get_root()
  File "/home/vscode/.local/ha-venv/lib/python3.12/site-packages/pre_commit/git.py", line 64, in get_root
    raise FatalError(
pre_commit.errors.FatalError: git failed. Is it installed, and are you in a Git repository directory?
GMT+8, 2025-12-17 02:06 , Processed in 0.053209 second(s), 8 queries , MemCached On.
