查看: 2540|回复: 3
[技术探讨] 分享,电动晾衣架改控制模块接入hass
发表于 2024-6-22 20:46:49 | 显示全部楼层 |阅读模式
我在网上买了个手摇晾衣架改电动晾衣架部件,24v直流供电,原控制是433遥控的继电器控制电机正反转模块,该模块尺寸和网上某款5-60v直流供电的esp32双路继电器二次开发板基本一致,用esp32模块替代433模块,二次开发板上IO引出口焊接KF128-2.54的螺钉式接线端子,接按钮和限位开关,2个继电器和电机的接线见图,配置文件抄了其他人的作业,接入hass。主要代码如下,又esp32的IO口较多,还可扩展接入人体存在、温湿度、照度等其他传感器。如有电机过载测量建议,望不吝赐教。
output:
  - platform: ledc
    pin: ${rtttl_buzzer_pin}
rtttl:
  output: rtttl_out
switch:
  - platform: gpio
    pin: ${relay_up_pin}
    interlock: [relay_down]
    interlock_wait_time: ${relay_interlock_wait_time}
#    name: up
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: gpio
    pin: ${relay_down_pin}
    interlock: [relay_up]
#    name: down
binary_sensor:
#上升限位
  - platform: gpio
    icon: mdi:arrow-collapse-up
    pin:
      number: ${up_limit_pin}
      mode:
        input: True
        pullup: True
      inverted: True
    filters:
      - delayed_on: ${delayed_time}
    on_press:
      then:
        - rtttl.play: 'scale_up:d=32,o=7,b=100:c,c#,d#,e,f#,g#,a#,b'
        - switch.turn_off: relay_up
#下降限位
  - platform: gpio
    icon: mdi:arrow-collapse-down
    pin:
      number: ${down_limit_pin}
      mode:
        input: True
        pullup: True
      inverted: True
    filters:
    on_press:
      then:
        - rtttl.play: 'scale_up:d=32,o=7,b=100:b,a#,g#,f#,e,d#,c#,c'
        - switch.turn_off: relay_down
#上升按钮
  - platform: gpio
    pin:
      number: ${btn_up_pin}
      mode:
        input: True
        pullup: True
      inverted: True
    filters:
    on_press:
      then:
        - if: #下降过程中按上升按钮,停止下降
            condition:
              switch.is_on: relay_down
            then:
              - cover.stop: drying_rack
            else:
              - if:
                  condition:
                    binary_sensor.is_off: up_limit
                  then:
                    - cover.open: drying_rack
#下降按钮
  - platform: gpio
    pin:
      number: ${btn_down_pin}
      mode:
        input: True
        pullup: True
      inverted: True
    filters:
    on_press:
      then:
        - if: #上升过程中按下降按钮,停止上升
            condition:
              switch.is_on: relay_up
            then:
            else:
              - if:
                  condition:
                    binary_sensor.is_off: down_limit
                  then:
                    - cover.close: drying_rack
cover:
  - platform: feedback
#up
    open_action:
      - switch.turn_on: relay_up
    open_duration: ${up_duration}
    open_endstop: up_limit
#down
    close_action:
      - switch.turn_on: relay_down
    close_duration: ${down_duration}
    close_endstop: down_limit
#stop
    stop_action:
      - rtttl.play: two_short:d=4,o=5,b=100:16e6,16e6
原433继电器模块
原433继电器模块
esp32继电器模块
esp32继电器模块
继电器和电机接线
继电器和电机接线
电动模块
电动模块
电机及限位调整
电机及限位调整
发表于 2024-6-22 21:24:16 | 显示全部楼层
我一直好奇
这种有行程限制的开关要怎么知道该关闭的时机
lz可以放张图看看吗
发表于 2024-6-22 23:36:37 | 显示全部楼层
kjjuhfv 发表于 2024-6-22 21:24
我一直好奇
lz可以放张图看看吗 ...
应该是有限位的,可能在电机行程上。
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2024-6-23 07:54:45 | 显示全部楼层
我一直好奇
lz可以放张图看看吗 ...
看最后一张图,电机旋转带动行程开关旁白色的上下限位旋转,限位位置通过调节限位片位置调节。
GMT+8, 2026-1-14 13:02 , Processed in 0.337846 second(s), 13 queries , MemCached On.
