楼主: jyz_0501
开帖记录我的Docker+Hassio 打造历程【2月17日再更新】
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-2-1 22:12:42 | 显示全部楼层
liyang3083377 发表于 2018-1-31 19:15
xiaomi_aqara:
  gateways:
   - mac: 34:CE:00:8D:66:E3
把报错信息发上来啊   log记录
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-2-1 22:13:56 | 显示全部楼层
xiaomi_aqara:
  gateways:
gateways:
     key: tykttklsyyw1f6nx
你这个mac必须要把:去掉,我帖子里说了吧,然后key肯定是不对的,你在看看去
发表于 2018-2-9 19:46:59 | 显示全部楼层
安装楼主的教程安装很顺利,谢谢楼主
另外,1:安装完之后,手机能搜到homebridge,但是过了一会就搜不到了。
2:树莓派不小心断电,上电之后hass界面就进不去了,求解答
发表于 2018-2-9 19:49:15 | 显示全部楼层
也按照楼主的教程在左侧添加了homebridge菜单,但是有时候会打不开,提示拒绝请求,然后在hass.io的homebridge里查看log日志发现提示如下:
[2018-2-9 19:37:33] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2018-2-9 19:37:38] [HomeAssistant] Fetching HomeAssistant devices.
[2018-2-9 19:37:38] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
[2018-2-9 19:37:43] [HomeAssistant] Fetching HomeAssistant devices.
[2018-2-9 19:37:43] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
WARNING: Failed to contact D-Bus daemon.avahi-daemon 0.6.32 exiting.Failed to start message bus: The pid file "/var/run/dbus.pid" exists, if the message bus is not running, remove this fileFound user 'avahi' (UID 86) and group 'avahi' (GID 86).Successfully dropped root privileges.avahi-daemon 0.6.32 starting up.WARNING: No NSS support for mDNS detected, consider installing nss-mdns!dbus_bus_get_private(): Failed to connect to socket /var/run/dbus/system_bus_socket: Permission deniedWARNING: Failed to contact D-Bus daemon.avahi-daemon 0.6.32 exiting.Failed to start message bus: The pid file "/var/run/dbus.pid" exists, if the message bus is not running, remove this fileFound user 'avahi' (UID 86) and group 'avahi' (GID 86).Successfully dropped root privileges.avahi-daemon 0.6.32 starting up.WARNING: No NSS support for mDNS detected, consider installing nss-mdns!dbus_bus_get_private(): Failed to connect to socket /var/run/dbus/system_bus_socket: Permission deniedWARNING: Failed to contact D-Bus daemon.avahi-daemon 0.6.32 exiting.Failed to start message bus: The pid file "/var/run/dbus.pid" exists, if the message bus is not running, remove this file[2018-2-9 19:49:42] [HomeAssistant] Fetching HomeAssistant devices.[2018-2-9 19:49:42] [HomeAssistant] Failed getting devices: Error: You are not authenticated. Retrying...
发表于 2018-2-12 20:45:13 | 显示全部楼层
请问esxi虚拟机可以吗
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-2-12 22:55:25 | 显示全部楼层
lyndtao 发表于 2018-2-9 19:49
也按照楼主的教程在左侧添加了homebridge菜单,但是有时候会打不开,提示拒绝请求,然后在hass.io的homebri ...
删除左侧HB面板好使吗?? 如果是可以的话,看看config.json 文件的配置是不是不对, 或者看看HB的options里面的HB插件加的对吗?
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-2-12 22:57:10 | 显示全部楼层
lyndtao 发表于 2018-2-9 19:46
安装楼主的教程安装很顺利,谢谢楼主
另外,1:安装完之后,手机能搜到homebridge,但是过了一会就搜不到了 ...
hassio 如果进不去可以用Samba进到根目录去看看HA的log文件,看看是哪里的问题,一般不会这种情况。
最近HA更新频繁,建议先不要升级那么快。
发表于 2018-2-15 18:20:36 | 显示全部楼层
正好要重新安裝
這篇好像就可以完全解決我所需要的
謝謝大大滴分享
发表于 2018-2-28 06:50:01 | 显示全部楼层
多谢分享~
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-3-4 11:47:45 | 显示全部楼层
顽皮小痴 发表于 2018-2-12 20:45
请问esxi虚拟机可以吗
没有研究这个 你搜下论坛教程吧~~
GMT+8, 2026-1-18 03:46 , Processed in 0.054815 second(s), 11 queries , MemCached On.
