查看: 2827|回复: 2
[技术探讨] 请教ESPHome 如何点亮ST7789V显示屏
发表于 2024-6-18 09:43:10 | 显示全部楼层 |阅读模式
color:
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
spi:
  clk_pin: GPIO2
  mosi_pin: GPIO3
display:
  - platform: ili9xxx
    model: st7789v
    dimensions:
      height: 170
      width: 320
      offset_height: 35
      offset_width: 0
    transform:
      swap_xy: true
      mirror_x: false
      mirror_y: true
    color_order: bgr
    data_rate: 10MHz
    cs_pin: GPIO7
    dc_pin: GPIO11
    reset_pin: GPIO5
    lambda: |-
      it.rectangle(0,  0, it.get_width(), it.get_height(), id(my_blue));
      it.rectangle(0, 20, it.get_width(), it.get_height(), id(my_blue));
上面是我的示例代码,主控是ESP32C3,显示屏上什么也没有显示,硬件接线是对的,请问是我哪里没设置好吗?
论坛风云人物
发表于 2024-6-18 11:21:49 | 显示全部楼层
GPIO针脚接线对的,点亮应该没问题,只是这个没有任何内容显示
 楼主| 发表于 2024-6-18 11:22:15 | 显示全部楼层
color:
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
spi:
  clk_pin: 2
  mosi_pin: 3
font:
  - file: "gfonts://Roboto"
display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    data_rate: 20MHz #oringal device uses 20mhz - 40 is default and works - does not work at 80mhz
    # cs_pin: # 直接接地
    dc_pin: 8
    reset_pin: 9
    spi_mode: MODE2   #since no cs pin default is mode0
    dimensions:
      width: 240
      height: 240
      offset_height: 0
      offset_width: 0
    invert_colors: true
    # update_interval: never
    # auto_clear_enabled: false
    lambda: |-
      it.strftime(5, 5, id(font_12), id(my_blue), TextAlign::TOP_LEFT, "%H:%M:%S", id(time_comp).now());
time:
  - platform: sntp
问题解决
主要是修改了这3个参数
dc_pin: 8
reset_pin: 9
spi_mode: MODE2
GMT+8, 2025-12-28 15:01 , Processed in 0.899892 second(s), 10 queries , MemCached On.
