查看: 5752|回复: 13
[UI界面]
发表于 2024-6-8 12:29:28 | 显示全部楼层 |阅读模式
参与人数 1金钱 +1 收起 理由
summ99111 + 1 感谢楼主分享!
 楼主| 发表于 2024-6-8 12:42:41 | 显示全部楼层
例如
<div class="flex flex-col">
  <div class="form-control h-12 justify-center w-full">
    <label class="cursor-pointer label justify-between items-center">
      <span class="label-text text-center w-full">厨房灯</span>
      <input type="checkbox" class="toggle toggle-primary"
        {{ iif(is_state('light.xiaomi_mesh_triple_wall_switch_channel_2', 'on'), "checked", "") }}
        onChange="this.checked ? hass.callService('light', 'turn_on', { entity_id: 'light.xiaomi_mesh_triple_wall_switch_channel_2' }) : hass.callService('light', 'turn_off', { entity_id: 'light.xiaomi_mesh_triple_wall_switch_channel_2' })"
    </label>
  </div>
</div>
 楼主| 发表于 2024-6-8 12:50:50 | 显示全部楼层
<!-- The button to open modal -->
<label for="my_modal_6" class="btn">open modal</label>
<!-- Put this part before </body> tag -->
<input type="checkbox" id="my_modal_6" class="modal-toggle" />
<div class="modal" role="dialog">
  <div class="modal-box">
    <h3 class="font-bold text-lg">Hello!</h3>
    <p class="py-4">测试下</p>
    <div class="modal-action">
      <label for="my_modal_6" class="btn">关掉</label>
    </div>
  </div>
</div>
弹窗方式,抛弃mod插件臃肿
发表于 2024-6-8 14:01:24 | 显示全部楼层
确实很强大,就是需要有css基础
发表于 2024-6-8 15:02:47 | 显示全部楼层
期待有教程
发表于 2024-6-9 09:28:39 | 显示全部楼层
习惯mod那种了。。。。
发表于 2024-6-12 14:06:55 | 显示全部楼层
持续关注
发表于 2024-6-13 09:43:01 | 显示全部楼层
测试下,看看好不好使
发表于 2024-6-13 09:57:02 来自手机 | 显示全部楼层
好看,但是纯代码有难度了
发表于 2024-6-14 08:43:55 | 显示全部楼层
nuknoop 发表于 2024-6-8 12:50
弹窗方式,抛弃mod插件臃肿
弹出可以不需要安装mod了?
GMT+8, 2026-1-14 13:02 , Processed in 1.120750 second(s), 12 queries , MemCached On.
