查看: 2424|回复: 7
[求助] docker部署homeassistant,容器无法停止
发表于 2024-6-6 09:14:00 | 显示全部楼层 |阅读模式
docker部署homeassistant,容器无法停止,使用xftp向homeassistant的custom_components文件夹添加海尔集成后,homeassistant重启后无法访问,并且容器不能停止
 楼主| 发表于 2024-6-6 09:27:44 | 显示全部楼层
2024-06-06 08:55:55.854 ERROR (MainThread) [custom_components.xiaomi_miot.sensor] Unexpected error fetching xiaomi_miot-mihome-message-892897776 data
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 315, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 271, in _async_update_data
    return await self.update_method()
  File "/config/custom_components/xiaomi_miot/sensor.py", line 703, in fetch_latest_message
    res = await self.cloud.async_request_api('v2/message/v2/typelist', data={}) or {}
  File "/config/custom_components/xiaomi_miot/core/xiaomi_cloud.py", line 179, in async_request_api
    return await self.hass.async_add_executor_job(
  File "/usr/src/homeassistant/homeassistant/core.py", line 887, in async_add_executor_job
    task = self.loop.run_in_executor(None, target, *args)
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 854, in run_in_executor
    self._check_default_executor()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 544, in _check_default_executor
    raise RuntimeError('Executor shutdown has been called')
RuntimeError: Executor shutdown has been called
发表于 2024-6-6 14:12:35 | 显示全部楼层
把xiaomi_miot  这个库备份删除 重启试试
发表于 2024-6-6 15:23:57 | 显示全部楼层
AriesIce 发表于 2024-6-6 09:27
2024-06-06 08:55:55.854 ERROR (MainThread) [custom_components.xiaomi_miot.sensor] Unexpected error f ...
docker run -d --security-opt seccomp:unconfined --name myha --net=host -v /opt/docker/ssd/practice/sync_ha_file:/config homeassistant/home-assistant     这是我启动HA的语句,你可以修改一下使用,
 楼主| 发表于 2024-6-6 15:58:53 | 显示全部楼层
删除之后也不行,感觉很可能是我小米灯总离线的原因
 楼主| 发表于 2024-6-6 16:01:32 | 显示全部楼层
mobility 发表于 2024-6-6 15:23
docker run -d --security-opt seccomp:unconfined --name myha --net=host -v /opt/docker/ssd/practice ...
好的 谢谢 有机会试一下
发表于 2024-6-7 10:38:23 | 显示全部楼层
删除之后,重新启动看日志  看看还有什么报错
 楼主| 发表于 2024-6-18 09:07:02 | 显示全部楼层
就是小米灯离线小米插件报错导致无法关闭homeassistant,这个小米插件还是有点问题
GMT+8, 2026-1-14 17:08 , Processed in 0.068225 second(s), 12 queries , MemCached On.
