查看: 2747|回复: 2
[技术探讨] 小米多模网关有可能通过 telnet 修改wifi(SSID) 吗?
发表于 2024-6-5 17:04:36 | 显示全部楼层 |阅读模式
起因:修改家里wifi名称后,米家多模网关只能重置重新连接,这样所有其下的zigbee设备虽然还在,但自定义名称及位置信息全部丢失,需要手动一一重新设置,很麻烦。就想是不是能通过 telnet 直接修改?
telnet 试过进去尝试过,但有些命令和配置文件没有,找到个配置文件感觉是的,但修改后未生效 vi /data/conf/wpa-wpa2.conf
wpa_supplicant -B -i wlan0 -c /data/conf/wpa-wpa2.conf 也报错,请教大佬!
# wpa_supplicant -B -i wlan0 -c /data/conf/wpa-wpa2.conf
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
nl80211: Could not re-add multicast membership for vendor events: -2 (No such file or directory)
ctrl_iface exists and seems to be in use - cannot override it
Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
Failed to initialize control interface '/var/run/wpa_supplicant'.
You may have another wpa_supplicant process already running or the file was
left by an unclean termination of wpa_supplicant in which case you will need
to manually remove this file before starting wpa_supplicant again.
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
发表于 2024-8-30 09:37:56 | 显示全部楼层
lumi.gateway.mgl03
cat /data/miio/wifi.conf
lumi.gateway.mcn001
agetprop | grep wifi
发表于 2024-10-10 16:49:43 | 显示全部楼层
有同样需求,多模网关2,原来连接的是2.4G,现在想换成连5G但不想重置网关。谢谢2楼的的方法,省了大麻烦
GMT+8, 2026-1-14 06:07 , Processed in 1.131252 second(s), 11 queries , MemCached On.
