查看: 4308|回复: 7
[插件集成] adguard插件启动不成功
发表于 2024-6-3 00:09:40 | 显示全部楼层 |阅读模式
最近adguard插件启动不成功,提示couldn't start forwarding DNS server: starting listeners: listening on udp addr 127.0.0.1:53: listening to udp socket: listen udp 127.0.0.1:53: bind: address already in use坛友们是否有遇到这种情况,有什么办法解决?
发表于 2024-6-3 09:47:55 | 显示全部楼层
你的53端口被其他程序占用了,命令行里输入lsof -i :53,看看是哪个程序占用了,调整一下。
发表于 2024-6-11 11:17:11 | 显示全部楼层
遇到了相同的问题, lsof -i :53看起来会返回一大串信息:
lsof -i :53
1        /package/admin/s6-2.12.0.2/command/s6-svscan        0        /dev/null
1        /package/admin/s6-2.12.0.2/command/s6-svscan        1        pipe:[2782646]
1        /package/admin/s6-2.12.0.2/command/s6-svscan        2        pipe:[2782647]
1        /package/admin/s6-2.12.0.2/command/s6-svscan        3        /run/service/.s6-svscan/lock
1        /package/admin/s6-2.12.0.2/command/s6-svscan        5        /run/service/.s6-svscan/control
1        /package/admin/s6-2.12.0.2/command/s6-svscan        6        /run/service/.s6-svscan/control
1        /package/admin/s6-2.12.0.2/command/s6-svscan        7        anon_inode:[signalfd]
16        /package/admin/s6-2.12.0.2/command/s6-supervise        0        /dev/null
16        /package/admin/s6-2.12.0.2/command/s6-supervise        1        pipe:[2782646]
16        /package/admin/s6-2.12.0.2/command/s6-supervise        2        pipe:[2782647]
16        /package/admin/s6-2.12.0.2/command/s6-supervise        3        /run/service/s6-linux-init-shutdownd/supervise/lock
16        /package/admin/s6-2.12.0.2/command/s6-supervise        4        /run/service/s6-linux-init-shutdownd/supervise/control
16        /package/admin/s6-2.12.0.2/command/s6-supervise        5        /run/service/s6-linux-init-shutdownd/supervise/control
16        /package/admin/s6-2.12.0.2/command/s6-supervise        6        anon_inode:[signalfd]
18        /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd        0        /dev/null
18        /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd        1        pipe:[2782646]
18        /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd        2        pipe:[2782647]
18        /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd        4        /run/service/s6-linux-init-shutdownd/fifo
18        /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd        5        /run/service/s6-linux-init-shutdownd/fifo
25        /package/admin/s6-2.12.0.2/command/s6-supervise        0        /dev/null
25        /package/admin/s6-2.12.0.2/command/s6-supervise        1        pipe:[2782646]
25        /package/admin/s6-2.12.0.2/command/s6-supervise        2        pipe:[2782647]
25        /package/admin/s6-2.12.0.2/command/s6-supervise        3        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/s6rc-fdholder/supervise/lock
25        /package/admin/s6-2.12.0.2/command/s6-supervise        4        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/s6rc-fdholder/supervise/control
25        /package/admin/s6-2.12.0.2/command/s6-supervise        5        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/s6rc-fdholder/supervise/control
25        /package/admin/s6-2.12.0.2/command/s6-supervise        6        anon_inode:[signalfd]
26        /package/admin/s6-2.12.0.2/command/s6-supervise        0        /dev/null
26        /package/admin/s6-2.12.0.2/command/s6-supervise        1        pipe:[2782646]
26        /package/admin/s6-2.12.0.2/command/s6-supervise        2        pipe:[2782647]
26        /package/admin/s6-2.12.0.2/command/s6-supervise        3        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/sshd/supervise/lock
26        /package/admin/s6-2.12.0.2/command/s6-supervise        4        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/sshd/supervise/control
26        /package/admin/s6-2.12.0.2/command/s6-supervise        5        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/sshd/supervise/control
26        /package/admin/s6-2.12.0.2/command/s6-supervise        6        anon_inode:[signalfd]
27        /package/admin/s6-2.12.0.2/command/s6-supervise        0        /dev/null
27        /package/admin/s6-2.12.0.2/command/s6-supervise        1        pipe:[2782646]
27        /package/admin/s6-2.12.0.2/command/s6-supervise        2        pipe:[2782647]
27        /package/admin/s6-2.12.0.2/command/s6-supervise        3        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/s6rc-oneshot-runner/supervise/lock
27        /package/admin/s6-2.12.0.2/command/s6-supervise        4        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/s6rc-oneshot-runner/supervise/control
27        /package/admin/s6-2.12.0.2/command/s6-supervise        5        /run/s6-rc:s6-rc-init:MOhjAf/servicedirs/s6rc-oneshot-runner/supervise/control
 楼主| 发表于 2024-6-17 20:35:20 | 显示全部楼层
lsof -i :53
1        /package/admin/s6-2.12.0.2/comman ...
我找到原因了,doh-client用了53端口与其冲突,关闭即可。
发表于 2024-6-18 14:39:12 | 显示全部楼层
我这边加载项没有doh-client, 也没有查明具体是哪个应用占用的端口, 将其暂时部署到其他的设备上了
发表于 2024-11-2 20:29:45 | 显示全部楼层
命令行里输入login,然后输入netstat -tulnp | grep :53,查看哪个程序占用了53端口,然后使用systemctl stop “程序名”关闭,再启动即可
发表于 2024-11-20 15:54:06 | 显示全部楼层
swordsu 发表于 2024-11-2 20:29
命令行里输入login,然后输入netstat -tulnp | grep :53,查看哪个程序占用了53端口,然后使用systemctl st ...
管用,是一个doh客户端的程序占用的,但是这个doh好像又是个很好的东西,但是用不了
发表于 2024-12-21 16:43:03 | 显示全部楼层
每次重启都需要手动关闭才可以,怎么能让他直接就不启动呢
GMT+8, 2026-1-14 14:37 , Processed in 0.556684 second(s), 13 queries , MemCached On.
