查看: 9468|回复: 4
[已解决] 博联黑豆接入HB,为何在HK中,电视开关是反着显示的?
发表于 2018-1-23 21:16:32 | 显示全部楼层 |阅读模式
博联黑豆接入HB,将电视的开、关机的数据配置到config.json,正常启动,但在HomeKit中,电视机的显示状态与实际相反,在HK中显示的是打状态,实际电视是关闭的;如果将HK中的电视状态改为关闭,则电视机的实际状态为打开。用Siri进行调试,也要反着来,告诉Siri,关闭电视机,则打开电视,很是奇怪,不知道是哪里配置错了,请各位大神帮忙,谢谢。config.json的配置如下:
                    "name": "客厅电视",
                    "host": "192.168.2.244",
                    "type": "switch",
                    "data": {
                        "on": "26008c0096911534134515341510161014111510151015341534153415101510160f15101510160f153515101510151015101510151015341510153415351435153415341534150005f695911336133713361510151013121510131213361336133714111312131213121312131215341312131213121510131213121336131214361336132613361337123713000d05000000000000000000000000",
                        "off": "26008c0096911534134515341510161014111510151015341534153415101510160f15101510160f153515101510151015101510151015341510153415351435153415341534150005f695911336133713361510151013121510131213361336133714111312131213121312131215341312131213121510131213121336131214361336132613361337123713000d05000000000000000000000000"
发表于 2018-1-23 22:29:24 | 显示全部楼层
没有状态反馈就这样了,论坛有带状态反馈的教程
 楼主| 发表于 2018-1-23 22:31:43 | 显示全部楼层
能给个具体的链接吗?新人小白,找了半天没找到,谢谢了
发表于 2018-1-23 22:35:45 | 显示全部楼层
用RM做一个带状态检测的开关
https://bbs.hassbian.com/thread-169-1-1.html
 楼主| 发表于 2018-1-23 22:37:04 | 显示全部楼层
kay7758 发表于 2018-1-23 22:35
用RM做一个带状态检测的开关
收到,谢谢
GMT+8, 2025-12-18 03:43 , Processed in 0.883709 second(s), 8 queries , MemCached On.
