查看: 3717|回复: 6
[技术探讨] 小米智能开关pro 转无线开关怎么触发
发表于 2024-5-25 22:42:45 | 显示全部楼层 |阅读模式
用的xiaomi gateway3接入的开关,多模网关2也正常工作。在米家把开关配置成无线模式之后,action的事件还是触发不了,请问有大神了解吗
 楼主| 发表于 2024-5-25 22:43:54 | 显示全部楼层
配置如下:
    14469: ["Xiaomi", "Xiaomi Smart Wall Switch Pro (3 Gang)", "XMQBKG06LM", "xiaomi.switch.wpro3"],
    "spec": [
        BaseConv("channel_1", "switch", mi="2.p.1"),
        BaseConv("channel_2", "switch", mi="3.p.1"),
        BaseConv("channel_3", "switch", mi="4.p.1"),
        BaseConv("action", "sensor", entity=ENTITY_DISABLED),
        ConstConv("action", mi="5.e.1", value=BUTTON_1_SINGLE),
        ConstConv("action", mi="6.e.1", value=BUTTON_2_SINGLE),
        ConstConv("action", mi="7.e.1", value=BUTTON_3_SINGLE),
        MapConv("fault", "sensor", mi="2.p.3", map={0: "No Faults", 1: "Over Temperature", 2: "Overload", 3: "Overload And Overheat"}),
        MathConv("power", "sensor", mi="8.p.2", round=1),
        BaseConv("led", "switch", mi="9.p.1"),
发表于 2024-6-12 11:36:49 | 显示全部楼层
好难啊  不知道怎么设置。 小米智能开关pro。。如: 单火双键,接了L和L1,但L2不接线,那么L1,L2这两个按键都是可以转成无线开关使用吗?
发表于 2024-8-14 14:25:48 | 显示全部楼层
同样的问题,有解决吗?
发表于 2024-8-30 10:07:55 | 显示全部楼层
同问 楼主解决了吗
发表于 2024-8-30 10:44:19 | 显示全部楼层
guanbuyu002 发表于 2024-8-30 10:07
同问 楼主解决了吗
我后面可以了,单机开关后action里会检测到单击,但是长按和双击还是没有,我双开的设置是这样
    14432: ["Xiaomi", "Xiaomi Smart Wall Switch Pro (2 Gang)", "xiaomi.switch.pro2"],
    "spec": [
        ConstConv("action", mi="4.e.1", value=BUTTON_1_SINGLE),
        ConstConv("action", mi="4.e.2", value=BUTTON_1_DOUBLE),
        ConstConv("action", mi="4.e.3", value=BUTTON_1_HOLD),
        ConstConv("action", mi="5.e.1", value=BUTTON_2_SINGLE),
        ConstConv("action", mi="5.e.2", value=BUTTON_2_DOUBLE),
        ConstConv("action", mi="5.e.3", value=BUTTON_2_HOLD),
        MapConv("mode_1","select", mi="2.p.2", map={0: "Wired And Wireless", 1: "Wireless"}),
        MapConv("mode_2","select", mi="3.p.2", map={0: "Wired And Wireless", 1: "Wireless"}),
        MathConv("power", "sensor", mi="6.p.2", round=1),
        BaseConv("led", "switch", mi="7.p.1"),
        MapConv("wiring_method","sensor", mi="2.p.5", map={0: "No Neutral", 1: "Neutral Wire"}),
发表于 2024-8-30 14:01:55 | 显示全部楼层
非常感谢 我试一下
GMT+8, 2026-1-14 02:51 , Processed in 0.115069 second(s), 13 queries , MemCached On.
