查看: 2979|回复: 2
[技术探讨] 坛友们 xiaomi_gateway3.py 配置双色温灯怎么配置呢
发表于 2024-5-23 02:07:41 | 显示全部楼层 |阅读模式
现在默认把我的双色温成开关switch 下面我修改xiaomi_gateway3.py的外部设备配置但是没有效果 应该什么修改呢  设备的型号是 mesh:17964
from custom_components.xiaomi_gateway3.core.devices import *
DEVICES = [{
    "17964": ["Xiaomi", "双色温灯", "Dual Color Temperature Light"],
    "spec": [
        ZOnOffConv("light", "light"),  # 开关控制
        ZBrightnessConv("brightness", parent="light"),  # 亮度控制
        ZColorTempConv("color_temp", parent="light")  # 色温控制
}] + DEVICES
发表于 2024-5-23 09:06:55 | 显示全部楼层
https://home.miot-spec.com/这个网页找到你的设备,找到对应 SIID PIID ,然后参照类似的改一下就OK,论坛有很多人分享过教程的比如:
# https://home.miot-spec.com/spec/jymc.light.falmp
    # https://home.miot-spec.com/spec/ftd.light.ftdlmp
    10729: [None, "Mesh Light", "jymc.light.falmp"],
    12066: [None, "Mesh Light", "ftd.light.ftdlmp"],
    "spec": [
        BaseConv("light", "light", mi="2.p.1"),
        BrightnessConv("brightness", mi="2.p.2", max=100),
        ColorTempKelvin("color_temp", mi="2.p.3", mink=3000, maxk=6500),
        BoolConv("flex_switch", "switch", mi="2.p.4"),  # config
        MapConv("mode", "select", mi="2.p.5", map={0: "温馨", 1: "影院", 2: "阅读", 3: "月光", 4: "会客", 5: "休闲", 6: "办公", 255: "默认"}),
里面的“mi=2.p.1”,意思就是SIID是2,PIID是1
没有指定这个是没办法加载出来的
发表于 2024-5-23 09:12:41 | 显示全部楼层
既然型号是mesh,那么你用zigbee的converters肯定不行。
但是你这个型号在https://home.miot-spec.com找不到,需要提供日志了
GMT+8, 2026-1-14 20:29 , Processed in 0.828314 second(s), 8 queries , MemCached On.
