楼主: wuyouning
[教程系列] 如何将屏幕开关的无线开关接入HA-NR曲线救家
 楼主| 发表于 2024-6-12 02:57:50 | 显示全部楼层
nikk 发表于 2024-6-6 19:53
上面的无线开关我想拿来做场景的,按下无线开关之后debug获取不到参数吗?需要这样绕一圈,我都想退货了刚 ...
我也是想来做场景,但是的局限性很大,有大神把它给刷了,可以自定义壁纸就更好看点,其他的,真的还是咬咬牙买小米亲儿子屏幕开关吧
nikk 手机认证
发表于 2024-6-12 11:18:51 | 显示全部楼层
wuyouning 发表于 2024-6-12 02:53
没搞明白 nodered里面并没有找到无线开关的触发,哥们你怎么做到的可以告诉我吗 ...
        "id": "7ecb21c0c56a63f1",
        "type": "server-state-changed",
        "z": "98594f1076b2a8ce",
        "name": "绿米无线开关1",
        "server": "bd882a3b.f05ae8",
        "version": 5,
        "outputs": 1,
        "exposeAsEntityConfig": "",
        "entityId": "event.magic_switch_s1e_2f0e_button_1",
        "entityIdType": "exact",
        "outputInitially": false,
        "stateType": "str",
        "ifState": "",
        "ifStateType": "str",
        "ifStateOperator": "is",
        "outputOnlyOnStateChange": true,
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 220,
        "y": 180,
        "wires": [
        "id": "bd882a3b.f05ae8",
        "type": "server",
        "name": "Home Assistant",
        "addon": true
发表于 2024-6-19 00:38:42 | 显示全部楼层
s1e可以mqtt接入的,3个继电器6个无线开关。ptx米家集成能接入吗?
https://bbs.hassbian.com/thread-19462-1-1.html
另外s1e用Home反接我记得也能拿到6个无线开关状态的,s1e的无线开关状态能直接反馈进ha,你是不是s1e使用了米家模式?试试用aqara自己的app接入,多点主题也能用HomeKit反接进去带出无线开关,理论上你的需求都能实现不需要跳板中继,截图一张是在HomeKit集成的s1e和mqtt接入的同一个s1e IMG_20240619_005848.jpg IMG_20240619_005901.jpg
 楼主| 发表于 2024-6-19 12:49:28 | 显示全部楼层
https://bbs.hassbian.com/thread-19462 ...
是的,我用了米家模式,所以接入存在问题,确实六个button会好用点,感谢提示吖
发表于 2024-8-5 14:45:51 | 显示全部楼层
所以S1E米家模式下用mi-auto接入HA没有无线按钮对吗,我本来是计划把海尔的空调通过HA接入,然后用S1E控制空调的,6个无线开关,不够用啊
 楼主| 发表于 2024-10-3 23:05:29 | 显示全部楼层
hua125666 发表于 2024-8-5 14:45
所以S1E米家模式下用mi-auto接入HA没有无线按钮对吗,我本来是计划把海尔的空调通过HA接入,然后用S1E控制 ...
有的,但我不推荐,实在不够用。我现在这个办法挺好用的,中转的话几乎等于无限。要不再买其他面板吧。。。。
GMT+8, 2025-9-6 03:09 , Processed in 0.476810 second(s), 13 queries , MemCached On.
