查看: 2850|回复: 5
[技术探讨] 有没有哪位大佬能够指导一下esphome,万分感谢
发表于 2024-5-18 14:49:08 | 显示全部楼层 |阅读模式
买了一台杂牌的电动升降桌,通过逻辑分析仪,分析得出,当控制器T口发出特定的信号,同时促发另外一个口为高电平的时候,升降桌能够控制。但是在不控制的时候,升降桌也会有数据不断的在传送。网上找了一段乐歌升降桌的控制代码。有没有哪位指导一下,怎样修改代码才能实现我想要的功能。 比如说升的时候,发送指令0x9b, 0x06, 0x02, 0x10, 0x00,这个指令需要每隔11ms发送一次,不间断的发送,桌子就会一直上升,同时把另外一口设置成高电平,就可以实现升。要停止上升的话,只要回复成默认的指令,但是esphome的代码不会写,有人能帮一下忙吗?
substitutions:
  device_name: Flexispot E5B
  min_height: "73.6" # Min height + 0.1
  max_height: "122.9" # Max height - 0.1
esphome:
  comment: ${device_name}
  platform: ESP8266 # TODO Change to your platform
  board: nodemcuv2 # TODO Change to your board
  includes:
    - desk_height_sensor.h
captive_portal:
# Enable logging
logger:
  #level: DEBUG
  baud_rate: 0
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: "NoNameHome"
  password: "abcdef790929"
  ap:
    ssid: "chuangkexiaoxian"
    password: "123456789"
uart:
  - id: desk_uart
    baud_rate: 9600
    tx_pin: D5
    rx_pin: D6
  - platform: wifi_signal
    update_interval: 60s
  - platform: uptime
  - platform: custom
    lambda: |-
      auto desk_height_sensor = new DeskHeightSensor(id(desk_uart));
      App.register_component(desk_height_sensor);
      return {desk_height_sensor};
    sensors:
      unit_of_measurement: cm
      accuracy_decimals: 1
      icon: "mdi:counter"
switch:
  - platform: gpio
    pin:
      number: D2
      mode: OUTPUT
    restore_mode: ALWAYS_ON
    internal: true
  - platform: uart
    icon: mdi:numeric-1-box
    data: [0x9b, 0x06, 0x02, 0x04, 0x00, 0xac, 0xa3, 0x9d]
    uart_id: desk_uart
  - platform: uart
    icon: mdi:numeric-2-box
    data: [0x9b, 0x06, 0x02, 0x08, 0x00, 0xac, 0xa6, 0x9d]
    uart_id: desk_uart
  - platform: uart
    icon: mdi:numeric-3-box
    data: [0x9b, 0x06, 0x02, 0x10, 0x00, 0xac, 0xac, 0x9d]
    uart_id: desk_uart
  - platform: uart
    icon: mdi:arrow-up-bold
    data: [0x9b, 0x06, 0x02, 0x01, 0x00, 0xfc, 0xa0, 0x9d]
    uart_id: desk_uart
    internal: true
  - platform: uart
    icon: mdi:arrow-down-bold
    data: [0x9b, 0x06, 0x02, 0x02, 0x00, 0x0c, 0xa0, 0x9d]
    uart_id: desk_uart
    internal: true
  - platform: uart
    icon: mdi:alpha-m-circle
    data: [0x9b, 0x06, 0x02, 0x20, 0x00, 0xac, 0xb8, 0x9d]
    uart_id: desk_uart
  - platform: uart
    name: "(wake up)" # Not available on all control panels
    icon: mdi:gesture-tap-button
    data: [0x9b, 0x06, 0x02, 0x00, 0x00, 0x6c, 0xa1, 0x9d]
    uart_id: desk_uart
cover:
  - platform: template
    # icon: mdi:table-chair
    # icon: mdi-human-male-height-variant
    assumed_state: true
    # Move desk up
    open_action:
      - while:
          condition:
            sensor.in_range:
              below: ${max_height}
          then:
          - logger.log: "Executing up command"
          - switch.turn_on: switch_up
          - delay: 10ms
    # Move desk down
    close_action:
      - while:
          condition:
            sensor.in_range:
              above: ${min_height}
          then:
          - logger.log: "Executing down command"
          - switch.turn_on: switch_down
          - delay: 10ms
    optimistic: true
发表于 2024-5-18 15:50:26 | 显示全部楼层
interval:
  - interval: 11ms
    then:
      - if:
          condition:
            lambda: 判断是否上升
          then:
            - uart.write:
                data: !lambda return 上升的数据
发表于 2024-5-18 15:55:13 | 显示全部楼层
阿斯蒂芬 发表于 2024-5-18 15:50
interval:
  - interval: 11ms
    then:
循环发送参考这个,
 楼主| 发表于 2024-5-18 19:06:29 | 显示全部楼层
阿斯蒂芬 发表于 2024-5-18 15:55
循环发送参考这个,
谢谢,回头我试试看。
发表于 2024-5-18 22:06:27 | 显示全部楼层
我的升降桌我还没研究,平常也不怎么升降
我不生产技术,我只是技术的搬运工。
 楼主| 发表于 2024-5-21 11:47:37 | 显示全部楼层
循环发送参考这个,
循环的知道了,不过现在调试的时候debug产生的内容不知道在哪里可以查看。
ESP_LOGD("DEBUG", "Height 2 is: 0x%02x", incomingByte);
比如说上面的这段,在homeassistant的日志里面就是找不到,也打开了调试模式。
上面的那段debug是在desk_height_sensor.h,中的
突然发现好像找到在哪里了。
GMT+8, 2025-11-30 02:05 , Processed in 0.563967 second(s), 6 queries , MemCached On.
