查看: 2294|回复: 1
[求助] 使用官网TUYA集成,总是报错。求助大神指导。
9 金钱 回复本帖可获得 1 金钱奖励! 每人限 1 次(中奖概率 50%)
发表于 2024-5-15 20:18:30 | 显示全部楼层 |阅读模式
正确填入代码后,提示错误Unknown error occurred
查看log日志。忙活了好久了,一直有问题。麻烦大神帮忙指导下。谢谢!
Traceback (most recent call last):  File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 174, in _new_conn    conn = connection.create_connection(           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 95, in create_connection    raise err  File "/usr/local/lib/python3.12/site-packages/urllib3/util/connection.py", line 85, in create_connection    sock.connect(sa)ConnectionRefusedError: [Errno 111] Connection refusedDuring handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 712, in urlopen    self._prepare_proxy(conn)  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 1012, in _prepare_proxy    conn.connect()  File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 363, in connect    self.sock = conn = self._new_conn()                       ^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/connection.py", line 186, in _new_conn    raise NewConnectionError(urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x6c279540>: Failed to establish a new connection: [Errno 111] Connection refusedDuring handling of the above exception, another exception occurred:Traceback (most recent call last):  File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 486, in send    resp = conn.urlopen(           ^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen    retries = retries.increment(              ^^^^^^^^^^^^^^^^^^  File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 592, in increment    raise MaxRetryError(_pool, url, error or ResponseError(cause))urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='apigw.iotbing.com', port=443): Max retries exceeded with url:
发表于 2024-5-16 18:31:47 | 显示全部楼层
回帖奖励 +1 金钱
使用的是tuya插件,还是localtuya本地化插件呢?ha的版本是多少
GMT+8, 2025-12-13 10:17 , Processed in 0.311460 second(s), 10 queries , MemCached On.
