楼主: maxims
[基础教程] 基于命令行ubuntu系统安装homeassistant、homebeidge系统……
发表于 2018-1-25 20:51:16 | 显示全部楼层
谢谢分享,改天买一个玩玩
发表于 2018-1-26 15:21:13 | 显示全部楼层
创建完config.json配置文件后,运行homebridge提示There was a problem reading your config.json file,该如何解决呢,谢谢
 楼主| 发表于 2018-1-29 09:22:57 | 显示全部楼层
imhaonan 发表于 2018-1-26 15:21
创建完config.json配置文件后,运行homebridge提示There was a problem reading your config.json file,该 ...
请用
https://jsonlint.com/
检测你的json文件是否有效
发表于 2018-2-7 16:51:25 | 显示全部楼层
谢谢分享
发表于 2018-2-10 23:09:49 | 显示全部楼层
root@pi-STCK1A32WFC:~/.homebridge# sudo systemctl daemon-reload
root@pi-STCK1A32WFC:~/.homebridge# sudo systemctl enable homebridge.service
root@pi-STCK1A32WFC:~/.homebridge# sudo systemctl start homebridge.service
root@pi-STCK1A32WFC:~/.homebridge# sudo systemctl status homebridge.service
● homebridge.service - Home Bridge
   Loaded: loaded (/etc/systemd/system/homebridge.service; enabled; vendor prese
   Active: failed (Result: exit-code) since 六 2018-02-10 23:07:19 CST; 5s ago
  Process: 2350 ExecStart=/usr/local/bin/homebridge (code=exited, status=1/FAILU
Main PID: 2350 (code=exited, status=1/FAILURE)
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at require (internal/module
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at Object.<anonymous> (/usr
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at Module._compile (module.
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at Object.Module._extension
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at Module.load (module.js:5
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at tryModuleLoad (module.js
2月 10 23:07:19 pi-STCK1A32WFC homebridge[2350]:     at Function.Module._load (m
2月 10 23:07:19 pi-STCK1A32WFC systemd[1]: homebridge.service: Main process exit
2月 10 23:07:19 pi-STCK1A32WFC systemd[1]: homebridge.service: Unit entered fail
2月 10 23:07:19 pi-STCK1A32WFC systemd[1]: homebridge.service: Failed with resul
lines 1-16/16 (END)
发表于 2018-2-10 23:10:52 | 显示全部楼层
这个错误是怎么解决呢?搞啦好久都没有头绪
 楼主| 发表于 2018-2-18 10:37:07 | 显示全部楼层
你这个,系统服务启动失败。首先检查你自己的启动配置文件是否正确,比如说路径、参数等配置。
发表于 2018-2-18 21:28:53 | 显示全部楼层
哪里买的?
 楼主| 发表于 2018-2-20 08:50:52 | 显示全部楼层
当然是假货宝咯
发表于 2018-2-21 23:52:07 | 显示全部楼层
感谢分享,树莓派太卡,先虚拟机玩玩
GMT+8, 2025-12-20 07:23 , Processed in 0.477039 second(s), 13 queries , MemCached On.
