查看: 2859|回复: 6
[求助] esphome中使用mqtt.publish发布消息
yjl 手机认证
发表于 2024-5-7 15:16:52 | 显示全部楼层 |阅读模式
大佬求救,esphome中esp32的配置文件如下,其中定义了一个switch,在on_turn_on和off的两个动作中想加入mqtt发布主题的动作,但是mqtt中对应的主题死活接收不到消息,不知道是接收消息的主题名称不对,还是消息压根就没发出,请求解答,NR中代码图也附上
esphome:
friendly_name: esp32
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "kxM7Yn6/ea38KhP8VHhR+uCb3WAdvLQDda19OygwkuE="
ota:
password: "c0304138ad69dd675ba8ab7d591d17bc"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp32 Fallback Hotspot"
password: "aKy5SQIaWcNF"
captive_portal:
switch:
- platform: gpio
pin:
number: 13
inverted: true
on_turn_on:
- mqtt.publish:
topic: "some/topic"
payload: "turn on"
qos: 0
on_turn_off:
- mqtt.publish:
topic: "some/topic"
payload: "turn off"
qos: 0
mqtt:
broker: 192.168.30.201
username: daner
password: a
NR中mqtt节点可以正常收到esp32自动注册的状态主题,也可以使用自动注册的控制主题,但是就是接收不到上面代码中自定义的这个“some/topic”的主题,我把主题的前缀是换了一个遍,都无法收到消息,所以现在不确定是接收消息的主题名称不对,还是压根esp32的switch在动作的时候根本没有发出mqtt消息 微信图片_20240507151534.png
总为浮云能避日,长安不见使人愁
发表于 2024-5-7 17:21:12 | 显示全部楼层
主题名字搞错了,主题是some/topic,而不是NodeRed中的esp32/some/topic
发表于 2024-5-7 17:43:16 | 显示全部楼层
on_turn_on:
- mqtt.publish:
topic: "some/topic"
payload: "turn on"
qos: 0
on_turn_off:
- mqtt.publish:
topic: "some/topic"
payload: "turn off"
qos: 0
这几行不用写试试,
只要配置好服务器、帐号密码,上电后连接上MQTT服务端,HA里面MQTT页面下自己就找到设备了,可以看ESP32的日志,没连接上MQTT会有报错
发表于 2024-5-7 17:45:01 | 显示全部楼层
格式是这样的
[17:34:24][C][mqtt.switch:041]: MQTT Switch 'Wireless AP':
[17:34:24][C][mqtt.switch:042]:   State Topic: 'esp32-s--lan8720/switch/wireless_ap/state'
[17:34:24][C][mqtt.switch:042]:   Command Topic: 'esp32-s--lan8720/switch/wireless_ap/command'
yjl 手机认证
 楼主| 发表于 2024-5-8 09:30:07 | 显示全部楼层
跪谢大佬,确实主题用some/topic就可以了,不用加任何前缀。我把官方文档意思理解错了,官方文档中如此描述“topic_prefix (Optional, string): The prefix used for all MQTT messages. Should not contain trailing slash. Defaults to <APP_NAME>.Use null to disable publishing or subscribing of any MQTT topic unless it is explicitly configured.”,我误解了 Defaults to <APP_NAME>的正确意思,所以才在接收消息的时候给topic前加了esp32前缀
万分感谢,万分感谢!!
总为浮云能避日,长安不见使人愁
yjl 手机认证
 楼主| 发表于 2024-5-8 09:38:43 | 显示全部楼层
qxdnzx 发表于 2024-5-7 17:45
格式是这样的
谢谢大佬帮忙,已经解决了,万分感谢
总为浮云能避日,长安不见使人愁
yjl 手机认证
 楼主| 发表于 2024-5-8 09:40:53 | 显示全部楼层
qxdnzx 发表于 2024-5-7 17:43
on_turn_on:
- mqtt.publish:
topic: "some/topic"
谢谢大佬,问题已经解决了,万分感谢
总为浮云能避日,长安不见使人愁
GMT+8, 2025-12-17 08:06 , Processed in 0.129874 second(s), 8 queries , MemCached On.
