查看: 4164|回复: 10
[技术探讨] esphome pwm控制风扇转速 怎么配置呢
发表于 2024-4-20 00:07:33 | 显示全部楼层 |阅读模式
esphome:
  friendly_name: jin_yu_fan
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
web_server:
  port: 80
wifi:
  reboot_timeout: 180s
  ssid: "JDCwifi_404"
  password: "adminadmin"
  ap:
    ssid: "esp_fan"
    password: "12345678"
captive_portal:
api:
ota:
button: #重启
  - platform: restart
    # inverted: true
fan:
  - platform: speed
    output: fan_output
output:
  - platform: esp8266_pwm
    pin: GPIO02
    frequency: "19531Hz"
上面配置可以正常 但是在使用百分比操作。40%以下基本是关闭的状态了。上面的代码应该怎么配置呢
发表于 2024-4-20 09:01:03 | 显示全部楼层
是不是和风扇本身性能有关,研究下pwm风扇的死区
发表于 2024-4-20 11:45:05 | 显示全部楼层
用ESP32,8266不是硬件PWM会受WIFI信号干扰
发表于 2024-4-20 17:32:37 | 显示全部楼层
风扇有pwm死区
 楼主| 发表于 2024-4-20 18:38:43 | 显示全部楼层
led灯也是吗。我弄一个双色的台灯的,pwm控制 低于20%以下 就没有亮度了   什么照亮度传感器  触控传感器 雷达2410b雷达 都添加进去了
esphome:
  friendly_name: tai deng
  on_boot:
    priority: 700
    then:
      - wait_until:
          api.connected:
      - lambda: id(config_mode).turn_on();
      - script.execute: get_all_params
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x63,0x00,0x04,0x03,0x02,0x01] #ĬÈϹرչ¤³Ìģʽ
      - delay: 1s
      - lambda: id(config_mode).turn_off();
  includes:
    - ld2410h.h
esp32:
  board: esp32dev
  framework:
    type: arduino
script:
  - id: get_all_params
    then:
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x61,0x00,0x04,0x03,0x02,0x01]
      - delay: 1s
# Enable logging
logger:
web_server:
  port: 80
wifi:
  ssid: "JDCwifi_404"
  ap:
    ssid: "esp_台灯"
captive_portal:
api:
ota:
button: #重启
  - platform: restart
    # inverted: true
  - platform: template
    on_press:
    on_press:
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0xA2,0x00,0x04,0x03,0x02,0x01]
      - delay: 1s
      - delay: 1s
output:
  - platform: ledc
    pin: GPIO18
  - platform: ledc
    pin: GPIO19
switch:
  - platform: gpio
    pin: GPIO33
    optimistic: true
    on_turn_on:
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x04,0x00,0xFF,0x00,0x01,0x00,0x04,0x03,0x02,0x01]
      - delay: 1s
    on_turn_off:
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0xFE,0x00,0x04,0x03,0x02,0x01]
      - delay: 1s
    name: run_RTA    #´ò¿ªÊµÊ±¼à¿Ø
    optimistic: true
    optimistic: true
    on_turn_on:
      - uart.write: [0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x62,0x00,0x04,0x03,0x02,0x01]
      - delay: 1s
    on_turn_off:
      - delay: 1s
light:
  - platform: cwww
    cold_white: output_component_warm
    warm_white: output_component_cool
    cold_white_color_temperature: 6536 K
    warm_white_color_temperature: 2000 K
    constant_brightness: true
    on_turn_on:
      then:
        - switch.turn_on: lightlan
    on_turn_off:
      then:
        - switch.turn_off: lightlan
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO25
      mode: INPUT_PULLUP
      inverted: true
  - platform: gpio
    pin:
      number: GPIO26
      mode: INPUT_PULLDOWN
    on_press:
      then:
        - light.toggle: light_output
    on_release:
      then:
i2c:
  sda: GPIO15
  scl: GPIO02
  scan: True
  - platform: bh1750
    address: 0x23
    update_interval: 1s
  - platform: custom
    lambda: |-
      auto s = new ld2410(id(uart_bus1));
      App.register_component(s);
      return {s->mov_distance_sensor, s->occ_distance_sensor, s->detect_distance_sensor, s->en_mov_0, s->en_mov_1, s->en_mov_3, s->en_mov_3, s->en_mov_4, s->en_mov_5, s->en_mov_6, s->en_mov_7, s->en_mov_8, s->en_occ_0, s->en_occ_1, s->en_occ_2, s->en_occ_3, s->en_occ_4, s->en_occ_5, s->en_occ_6, s->en_occ_7, s->en_occ_8};
    sensors:
      - name: mov_distance_sensor
        #internal: true
        unit_of_measurement: m
        accuracy_decimals: 2
        filters:
          - lambda: return x/100;
      - name: occ_distance_sensor
        #internal: true
        filters:
      - name: detect_distance_sensor
        #internal: true
        filters:
      # ¸÷¸ö¾àÀëÃÅÄÜÁ¿Öµ
      - name: en_mov_0
      - name: en_mov_1
      - name: en_mov_2
      - name: en_mov_3
      - name: en_mov_4
      - name: en_mov_5
      - name: en_mov_6
      - name: en_mov_7
      - name: en_mov_8
      - name: en_occ_0
      - name: en_occ_1
      - name: en_occ_2
      - name: en_occ_3
      - name: en_occ_4
      - name: en_occ_5
      - name: en_occ_6
      - name: en_occ_7
      - name: en_occ_8
text_sensor:
number:
    name: max_distance  #×î´ó̽²â¾àÀë
    min_value: 0.75
    max_value: 6
    initial_value: 6
    step: 0.75
    #restore_value: true
    optimistic: true
    unit_of_measurement: m   #ÊÖ²áûÓÐÅäÖÃÃüÁ£¿·þÁË
    name: max_mov_distance  #×î´óÒÆ¶¯Ì½²â¾àÀë
    min_value: 0.75
    max_value: 6
    initial_value: 6
    step: 0.75
    optimistic: true
    set_action:
      - uart.write: !lambda
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x60, 0x00, 0x00, 0x00, (unsigned char)(int)(x/0.75), 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)(int)(id(max_occ_distance).state/0.75), 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(none_duration).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    name: max_occ_distance  #×î´ó¾²Ö¹Ì½²â¾àÀë
    min_value: 0.75
    max_value: 6
    initial_value: 6
    step: 0.75
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x60, 0x00, 0x00, 0x00, (unsigned char)(int)(id(max_mov_distance).state/0.75), 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)(int)(x/0.75), 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(none_duration).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    name: none_duration  #ÎÞÈ˳ÖÐøÊ±¼ä
    min_value: 0
    max_value: 120
    initial_value: 5
    step: 1
    optimistic: true
    unit_of_measurement: s
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x60, 0x00, 0x00, 0x00, (unsigned char)(int)(id(max_mov_distance).state/0.75), 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)(int)(id(max_occ_distance).state/0.75), 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)0, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_0).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)1, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_1).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)2, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_2).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)3, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_3).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)4, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_4).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)5, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_5).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)6, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_6).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)7, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_7).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)8, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)id(occ_sn_distance_8).state, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)0, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_0).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)1, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_1).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)2, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_2).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)3, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_3).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)4, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_4).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)5, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_5).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)6, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_6).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)7, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_7).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    min_value: 0
    max_value: 100
    initial_value: 40
    step: 1
    optimistic: true
    set_action:
          return {0xFD,0xFC,0xFB,0xFA, 0x14, 0x00, 0x64, 0x00, 0x00, 0x00, (unsigned char)8, 0x00, 0x00, 0x00, 0x01, 0x00, (unsigned char)id(mov_sn_distance_8).state, 0x00, 0x00, 0x00, 0x02, 0x00, (unsigned char)x, 0x00, 0x00, 0x00, 0x04, 0x03, 0x02, 0x01};
    name: update_interval  #ʵʱ¼à¿ØË¢Ð¼ä¸ô£¬Ô½´óÔ½Âý£¬´ó¸Å500¼ä¸ôΪ1Ãë
    min_value: 100
    max_value: 5000
    initial_value: 500
    step: 100
    restore_value: true
    optimistic: true
uart:
  tx_pin: GPIO01
  rx_pin: GPIO03
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
参与人数 1金钱 +12 收起 理由
隔壁的王叔叔 + 12 超级棒,又有作业抄啦
发表于 2024-4-21 07:52:55 | 显示全部楼层
gmshiwoge 发表于 2024-4-20 18:38
led灯也是吗。我弄一个双色的台灯的,pwm控制 低于20%以下 就没有亮度了   什么照亮度传感器  触控传感器 ...
一样的,亮太短眼睛看不到,或者转dc电压不够
发表于 2024-4-21 19:13:31 | 显示全部楼层
运算符自己重写一个滑块从百分40开始计算就完事了.问gpt要代码
发表于 2024-4-21 19:29:33 | 显示全部楼层
发表于 2024-4-22 12:43:53 | 显示全部楼层
我搞了一个,直接ha控制设定启动,停止温度。强制转速。可以检测风扇的转速以及风扇的故障。暂时用在机柜上面在,感觉非常方便
发表于 2024-8-25 15:04:43 | 显示全部楼层
qiu_yang 发表于 2024-4-22 12:43
我搞了一个,直接ha控制设定启动,停止温度。强制转速。可以检测风扇的转速以及风扇的故障。暂时用在机柜上 ...
老哥方便看一下硬件连接和程序吗
GMT+8, 2025-12-16 15:50 , Processed in 1.293770 second(s), 13 queries , MemCached On.
