楼主: hungheo
[技术探讨] 领普平开窗推窗器WD2,gateway3配置分享
发表于 2024-5-6 16:15:39 | 显示全部楼层
gateway3:V4.0.3 可以接入所有的米家设备麽?
 楼主| 发表于 2024-5-6 16:47:13 | 显示全部楼层
gateway3,只针对zigbee或者是蓝牙网关,走WiFi的用miot_auto ,gateway3支不支持,要看devices.py里面有没有你想接入的设备,当然devices.py里面没有,可以自己参照类似的,自己写
发表于 2024-5-6 21:21:48 | 显示全部楼层
    13203: ["Linptech", "Casement Window Driver WD2", "linp.wopener.wd2lb"],
    "spec": [
        MapConv("motor", "cover", mi="2.p.1", map={0: "stop", 1: "open", 2: "close"}),
        BaseConv("target_position", mi="2.p.3"),
        CurtainPosConv("position", mi="2.p.2"),
        BaseConv("battery", "sensor", mi="3.p.1", entity=ENTITY_LAZY),
        MapConv("battery_status", "sensor", mi="3.p.3", map={0: "Idle", 1: "Adapter", 2: "Solar", 3: "Protected", 4: "Adapter-float"}),
        MapConv("anti_pinch_sensitivity", "select", mi="4.p.2", map={0: "Very_low", 1: "Low", 2: "Medium", 3:"High"}),
        MathConv("target-position", "number", mi="2.p.3", min=0, max=100, entity=ENTITY_CONFIG),
这样才能控制百分比开合,同时输入也可以
我也不知道为什么
但是反正这样才可以
发表于 2024-8-14 11:50:14 | 显示全部楼层
wd2 motor的状态是不是未知啊
 楼主| 发表于 2024-8-14 12:43:50 | 显示全部楼层
jdchen 发表于 2024-8-14 11:50
wd2 motor的状态是不是未知啊
并没有呀,操作一下开关就能同步上了
发表于 2024-8-14 13:53:08 | 显示全部楼层
刚刚确实又好了
GMT+8, 2026-1-14 01:17 , Processed in 0.058481 second(s), 11 queries , MemCached On.
