查看: 1342|回复: 1
[技术探讨] haos 添加 Owntone AddOn 启动不起来,求助
发表于 2024-4-11 19:57:20 | 显示全部楼层 |阅读模式
[2024-04-11 19:57:57] [  LOG]     main: Built with:
[2024-04-11 19:57:57] [  LOG]     main: - ffmpeg
[2024-04-11 19:57:57] [  LOG]     main: - Spotify
[2024-04-11 19:57:57] [  LOG]     main: - librespot-c
[2024-04-11 19:57:57] [  LOG]     main: - LastFM
[2024-04-11 19:57:57] [  LOG]     main: - Chromecast
[2024-04-11 19:57:57] [  LOG]     main: - MPD
[2024-04-11 19:57:57] [  LOG]     main: - Websockets
[2024-04-11 19:57:57] [  LOG]     main: - ALSA
[2024-04-11 19:57:57] [  LOG]     main: - Webinterface
[2024-04-11 19:57:57] [  LOG]     main: - Regex
[2024-04-11 19:57:57] [  LOG]     main: mDNS init
[2024-04-11 19:57:57] [  LOG]     mdns: Avahi state change: Client running
[2024-04-11 19:57:57] [  LOG]       db: Configured to use database file '/share/owntone/dbase_and_logs/songs3.db'
[2024-04-11 19:57:57] [  LOG]       db: Now vacuuming database, this may take some time...
[2024-04-11 19:57:57] [  LOG]       db: Database OK with 0 active files and 6 active playlists
[2024-04-11 19:57:57] [  LOG]      web: LWS OOM allocating 1073741816 fds
[2024-04-11 19:57:57] [  LOG]      web: LWS ZERO RANDOM FD
[2024-04-11 19:57:57] [  LOG]      web: Failed to create websocket context
[2024-04-11 19:57:57] [FATAL]    httpd: Websocket init failed
[2024-04-11 19:57:57] [FATAL]     main: HTTPd thread failed to start
[2024-04-11 19:57:57] [  LOG]     main: Player deinit
[2024-04-11 19:57:57] [  LOG]     scan: Bulk library scan completed in 0 sec
[2024-04-11 19:57:57] [  LOG]  spotify: No spotify refresh token found
[2024-04-11 19:57:57] [  LOG]  spotify: Spotify webapi token refresh failed. In order to use Spotify, authorize the server to access your saved tracks by visiting http://owntone.local:3689
[2024-04-11 19:57:57] [  LOG]     main: Library scanner deinit
[2024-04-11 19:57:57] [  LOG]      lib: Library init scan completed in 0 sec (0 changes)
[2024-04-11 19:57:57] [  LOG]     main: Cache deinit
[2024-04-11 19:57:57] [  LOG]     main: Worker deinit
[2024-04-11 19:57:57] [  LOG]     main: Database deinit
[2024-04-11 19:57:57] [  LOG]     main: mDNS deinit
[2024-04-11 19:57:57] [  LOG]     main: Exiting.
Failed to set ownership on logfile: Operation not permitted
[2024-04-11 19:57:58] [  LOG]     main: OwnTone version 28.2 taking off
[2024-04-11 19:57:58] [  LOG]     main: Built with:
[2024-04-11 19:57:58] [  LOG]     main: - ffmpeg
[2024-04-11 19:57:58] [  LOG]     main: - Spotify
[2024-04-11 19:57:58] [  LOG]     main: - librespot-c
[2024-04-11 19:57:58] [  LOG]     main: - LastFM
[2024-04-11 19:57:58] [  LOG]     main: - Chromecast
[2024-04-11 19:57:58] [  LOG]     main: - MPD
[2024-04-11 19:57:58] [  LOG]     main: - Websockets
[2024-04-11 19:57:58] [  LOG]     main: - ALSA
[2024-04-11 19:57:58] [  LOG]     main: - Webinterface
[2024-04-11 19:57:58] [  LOG]     main: - Regex
[2024-04-11 19:57:58] [  LOG]     main: mDNS init
[2024-04-11 19:57:58] [  LOG]     mdns: Avahi state change: Client running
[2024-04-11 19:57:58] [  LOG]       db: Configured to use database file '/share/owntone/dbase_and_logs/songs3.db'
[2024-04-11 19:57:58] [  LOG]       db: Now vacuuming database, this may take some time...
[2024-04-11 19:57:58] [  LOG]       db: Database OK with 0 active files and 6 active playlists
[2024-04-11 19:57:58] [  LOG]      web: LWS OOM allocating 1073741816 fds
[2024-04-11 19:57:58] [  LOG]      web: LWS ZERO RANDOM FD
[2024-04-11 19:57:58] [  LOG]      web: Failed to create websocket context
[2024-04-11 19:57:58] [FATAL]    httpd: Websocket init failed
[2024-04-11 19:57:58] [FATAL]     main: HTTPd thread failed to start
[2024-04-11 19:57:58] [  LOG]     main: Player deinit
[2024-04-11 19:57:58] [  LOG]     scan: Bulk library scan completed in 0 sec
[2024-04-11 19:57:58] [  LOG]  spotify: No spotify refresh token found
[2024-04-11 19:57:58] [  LOG]  spotify: Spotify webapi token refresh failed. In order to use Spotify, authorize the server to access your saved tracks by visiting http://owntone.local:3689
[2024-04-11 19:57:58] [  LOG]     main: Library scanner deinit
[2024-04-11 19:57:58] [  LOG]      lib: Library init scan completed in 0 sec (0 changes)
[2024-04-11 19:57:58] [  LOG]     main: Cache deinit
[2024-04-11 19:57:58] [  LOG]     main: Worker deinit
[2024-04-11 19:57:58] [  LOG]     main: Database deinit
[2024-04-11 19:57:58] [  LOG]     main: mDNS deinit
[2024-04-11 19:57:58] [  LOG]     main: Exiting.
[2024-04-11 19:57:59] [  LOG]     main: OwnTone version 28.2 taking off
[2024-04-11 19:57:59] [  LOG]     main: Built with:
[2024-04-11 19:57:59] [  LOG]     main: - ffmpeg
[2024-04-11 19:57:59] [  LOG]     main: - Spotify
[2024-04-11 19:57:59] [  LOG]     main: - librespot-c
[2024-04-11 19:57:59] [  LOG]     main: - LastFM
[2024-04-11 19:57:59] [  LOG]     main: - Chromecast
[2024-04-11 19:57:59] [  LOG]     main: - MPD
[2024-04-11 19:57:59] [  LOG]     main: - Websockets
[2024-04-11 19:57:59] [  LOG]     main: - ALSA
[2024-04-11 19:57:59] [  LOG]     main: - Webinterface
[2024-04-11 19:57:59] [  LOG]     main: - Regex
[2024-04-11 19:57:59] [  LOG]     main: mDNS init
[2024-04-11 19:57:59] [  LOG]     mdns: Avahi state change: Client running
[2024-04-11 19:57:59] [  LOG]       db: Configured to use database file '/share/owntone/dbase_and_logs/songs3.db'
[2024-04-11 19:57:59] [  LOG]       db: Now vacuuming database, this may take some time...
[2024-04-11 19:57:59] [  LOG]       db: Database OK with 0 active files and 6 active playlists
[2024-04-11 19:57:59] [  LOG]      web: LWS OOM allocating 1073741816 fds
[2024-04-11 19:57:59] [  LOG]      web: LWS ZERO RANDOM FD
[2024-04-11 19:57:59] [  LOG]      web: Failed to create websocket context
[2024-04-11 19:57:59] [FATAL]    httpd: Websocket init failed
[2024-04-11 19:57:59] [FATAL]     main: HTTPd thread failed to start
[2024-04-11 19:57:59] [  LOG]     main: Player deinit
[2024-04-11 19:57:59] [  LOG]     scan: Bulk library scan completed in 0 sec
[2024-04-11 19:57:59] [  LOG]  spotify: No spotify refresh token found
[2024-04-11 19:57:59] [  LOG]  spotify: Spotify webapi token refresh failed. In order to use Spotify, authorize the server to access your saved tracks by visiting http://owntone.local:3689
[2024-04-11 19:57:59] [  LOG]      lib: Library init scan completed in 0 sec (0 changes)
[2024-04-11 19:57:59] [  LOG]     main: Library scanner deinit
[2024-04-11 19:57:59] [  LOG]     main: Cache deinit
[2024-04-11 19:57:59] [  LOG]     main: Worker deinit
[2024-04-11 19:57:59] [  LOG]     main: Database deinit
[2024-04-11 19:57:59] [  LOG]     main: mDNS deinit
[2024-04-11 19:57:59] [  LOG]     main: Exiting.
我就想用这个软件,高手们,帮帮忙
 楼主| 发表于 2024-4-11 21:43:27 | 显示全部楼层
打开admin  ,里面还有个beta版,可以使用。
GMT+8, 2026-1-15 03:31 , Processed in 0.391091 second(s), 12 queries , MemCached On.
