查看: 5635|回复: 13
[求助] 请教下 esp32-c3 打开开关就异常重启的问题。
发表于 2024-4-11 09:06:13 | 显示全部楼层 |阅读模式
代码如下:
esphome:
  friendly_name: minitst
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: arduino
    #version: "recommended"
    #platform_version: "6.0.0"
  # framework:
  #   type: esp-idf
time:
  - platform: homeassistant
    timezone: UTC-8 #中国时区
debug:
  update_interval: 5s
text_sensor:
  - platform: debug
    device:
    reset_reason:
# sensor:
#   - platform: debug
#     free:
#       name: "Heap Free"
#     # fragmentation:
#     #   name: "Heap Fragmentation"
#     block:
#       name: "Heap Max Block"
#     loop_time:
#       name: "Loop Time"
#     # psram:
#     #   name: "Free PSRAM why"
logger:
  level: debug
api:
  encryption:
    key: "**************"
ota:
  password: "7da15bbb5ef897624e87873979dc5dad"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.50
    gateway: 192.168.1.18
    subnet: 255.255.255.0
    dns1: 114.114.114.114
  ap:
    ssid: "Esp32-mini Fallback Hotspot"
    password: "IBtfWK72DMrP"
captive_portal:
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    name: "JVC 开关机状态背景灯"
    pin:
     number: GPIO05
     inverted: true
    filters:
      - delayed_on_off: 100ms
  - platform: gpio
    pin:
     number: GPIO00
     mode:
       input: True
       pullup: true
     inverted: true
    filters:
    # on_double_click:
    #   then:
    #     - switch.turn_off: J1_JVC
    #     - delay: 1s
    #     - logger.log: "J1_JVC   <<<OFF>>"
    # on_press:
    #   then:
    #     - switch.turn_on: J1_JVC
    #     - delay: 1s
    #     - logger.log: "J1_JVC   <<<ON>>>"
  - platform: gpio
#原 MD实体按键 现在: 系统电源键
    pin:
     number: GPIO3
     inverted: True
     mode:
      input: True
      pullup: true
    filters:
    on_press:
      then:
       - switch.turn_on:
#######switch#######################
switch:
  - platform: gpio
    pin:
      number: GPIO4
      inverted: true
    restore_mode: ALWAYS_OFF
    on_turn_on:
      - logger.log: "J1_JVC 通电!"
    on_turn_off:
      - logger.log: "J1_JVC 断电!"
  - platform: gpio
    pin: GPIO10
    inverted: true
    on_turn_on:
      - logger.log: "J2_Q5 通电!"
    on_turn_off:
      - logger.log: "J2_Q5 断电!"
  - platform: gpio
    pin:
     number: GPIO07
     inverted: True
    on_turn_on:
      - logger.log: "JVC_On_Off_Tactswitch 按下!"
    on_turn_off:
      - logger.log: "JVC_On_Off_Tactswitch 释放!"
####HA虚拟开关##########
  - platform: template
    icon: "mdi:power"
#以下代码: esp32 会重启,待排查。
    turn_on_action:
      - lambda: |-
         if (id(JVC_Power_stats_sensor)){
          delay(2000);
          id(J2_Q5).turn_off();
          delay(2000);
          id(J1_JVC).turn_off();
          delay(2000);
         }else
          delay(2000);
          id(J1_JVC).turn_on();
          delay(2000);
          id(JVC_On_Off_Tactswitch).turn_on();
          delay(500);
          id(JVC_On_Off_Tactswitch).turn_off();
          delay(8000);
          id(J2_Q5).turn_on();
#         if (id(J1_JVC).state){   JVC_Power_stats_sensor
初始状态下JVC_Power_stats_sensor 为off状态,只要一打开开关,就ping不通 web :
发表于 2024-4-11 09:56:30 | 显示全部楼层
为啥设备延迟这么大?
 楼主| 发表于 2024-4-11 10:06:48 | 显示全部楼层
离路由器比较远。用另外一个c3 也一样重启,这个就接了些 led 和按钮其他都没接。-另外一套系统 HAOS + 最新版的ESPhome   ,之前是docker 的 ha + docker的esphome ,麻烦大佬用脚本测试下? ping 好像也是延迟比较大,也不知啥原因。ESP32 距离路由器1米的距离。
 楼主| 发表于 2024-4-11 10:23:55 | 显示全部楼层
kabala56 发表于 2024-4-11 10:06
离路由器比较远。用另外一个c3 也一样重启,这个就接了些 led 和按钮其他都没接。-另外一套系统 HAOS + 最 ...
后续的截图。异常重启后。
 楼主| 发表于 2024-4-11 10:33:17 | 显示全部楼层
后续的截图。异常重启后。
jjcs 手机认证
发表于 2024-4-11 11:05:26 | 显示全部楼层
你用的啥c3,单板最小代码尝试过了吗
发表于 2024-4-11 11:47:44 | 显示全部楼层
esp32-c3 用ESPhome 最新版本2024.3.2,好像是有这个问题,无限重启。
 楼主| 发表于 2024-4-11 16:42:25 | 显示全部楼层
分别用的图片中的两款,都是最小系统啊。
这是连接图,简陋测试用。
这是连接图,简陋测试用。
 楼主| 发表于 2024-4-11 16:44:41 | 显示全部楼层
jjcs 发表于 2024-4-11 11:05
你用的啥c3,单板最小代码尝试过了吗
测试过了,没问题啊。
#######加了个按钮,没接继电器,连续按了继续,就重启了。下面提示 连接错误
WARNING esp32-mini @ 192.168.1.50: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for esp32-mini @ 192.168.1.50
WARNING Disconnected from API
INFO Successfully connected to esp32-mini @ 192.168.1.50 in 0.003s
INFO Successful handshake with esp32-mini @ 192.168.1.50 in 0.174s
[15:56:23][D][api:102]: Accepted 192.168.1.104
[15:56:24][D][api.connection:1159]: Home Assistant 2024.4.2 (192.168.1.104): Connected successfully
[15:56:24][D][time:049]: Synchronized time: 2024-04-11 15:56:24
[16:00:41][I][ota:117]: Boot seems successful, resetting boot loop counter.
[16:00:41][D][esp32.preferences:114]: Saving 1 preferences to flash...
[16:00:41][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[16:09:23][D][time:049]: Synchronized time: 2024-04-11 16:09:23
发表于 2024-4-11 19:20:57 | 显示全部楼层
我有一个esp8266的插座也是这样,开或者关就有一定机率死机重启。
GMT+8, 2026-1-30 20:20 , Processed in 0.914918 second(s), 16 queries , MemCached On.
