查看: 2495|回复: 4
[学习笔记] 记录一下 GY-BME280-5V 地址是0x76
发表于 2024-4-9 23:03:05 | 显示全部楼层 |阅读模式
注意GY-BME280-5V 地址是0x76,不是官网例程里面的0x77
###BME280 温度 + 压力 + 湿度传感器 地址0x76
  - platform: bme280_i2c
    i2c_id: bus_a
    temperature:
      name: "BME280 Temperature"
    pressure:
      name: "BME280 Pressure"
    humidity:
      name: "BME280 Relative Humidity"
    address: 0x76
    update_interval: 1s
  - platform: template
    lambda: |-
      const float STANDARD_SEA_LEVEL_PRESSURE = 1013.25; //in hPa, see note
      return ((id(bme280_temperature).state + 273.15) / 0.0065) *
        (powf((STANDARD_SEA_LEVEL_PRESSURE / id(bme280_pressure).state), 0.190234) - 1); // in meter
    update_interval: 1s
    icon: 'mdi:signal'
    unit_of_measurement: 'm'
  - platform: absolute_humidity
    name: "Absolute Humidity"
    temperature: bme280_temperature
    humidity: bme280_humidity
    lambda: |-
      return (243.5*(log(id(bme280_humidity).state/100)+((17.67*id(bme280_temperature).state)/
      (243.5+id(bme280_temperature).state)))/(17.67-log(id(bme280_humidity).state/100)-
      ((17.67*id(bme280_temperature).state)/(243.5+id(bme280_temperature).state))));
    unit_of_measurement: °C
    icon: 'mdi:thermometer-alert'
发表于 2024-4-10 04:09:49 | 显示全部楼层
我用BMP280  代碼是0x77
  - platform: aht10
  #  address: 0x38
    temperature:
      name: "AHT20 Temperature"
    humidity:
      name: "AHT20 Humidity"
    update_interval: 15s
  - platform: bmp280
    temperature:
      name: "BMP280 Temperature"
      oversampling: 16x
    pressure:
      name: "BMP280 Pressure"
    address: 0x77
发表于 2024-4-12 10:10:44 | 显示全部楼层
模块的图片上,BMP280附近有个3个焊盘,那是个跳线,默认接到GND,i2c地址就是0x76,如果接VDD,就是0X77
参与人数 1金钱 +5 收起 理由
qxdnzx + 5 论坛有你更精彩!
发表于 2024-5-19 21:38:09 | 显示全部楼层
謝謝摟主  請問一下那個Altitude 和dew point 公式其實是怎麼樣的呢
发表于 2025-6-4 14:56:09 | 显示全部楼层
我刚开始用0想76不行,换0x77就可以,不行来回换,再读数
GMT+8, 2025-12-31 07:00 , Processed in 1.347022 second(s), 17 queries , MemCached On.
