查看: 1972|回复: 1
[求助] 求助:Error installing Home Assistant
发表于 2024-4-9 22:52:10 | 显示全部楼层 |阅读模式
各位大神帮帮忙,今天手贱升级,好像没成功,就重新启动了,刚开始也没什么问题,又更新了几个加载项,需要重启,就重启了一下,结果就进不去了,提示如下:PS真的是不想重新安装
[13:41:53] INFO: Using udev information from host
[13:41:53] INFO: Starting local supervisor watchdog...
2024-04-09 13:42:00.901 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-04-09 21:42:01.072 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: qemux86-64
2024-04-09 21:42:01.079 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.04.0
2024-04-09 21:42:01.079 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-04-09 21:42:03.446 INFO (SyncWorker_1) [supervisor.docker.manager] Cleanup images: []
2024-04-09 21:42:05.940 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-04-09 21:42:05.944 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-09 21:42:05.946 INFO (MainThread) [__main__] Setting up Supervisor
2024-04-09 21:42:06.904 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-04-09 21:42:07.002 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-04-09 21:42:07.005 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-04-09 21:42:07.007 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-04-09 21:42:07.008 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-04-09 21:42:07.016 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-04-09 21:42:07.024 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-04-09 21:42:07.034 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-04-09 21:42:07.037 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-04-09 21:42:07.039 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-04-09 21:42:07.041 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-04-09 21:42:07.684 INFO (MainThread) [supervisor.host.services] Updating service information
2024-04-09 21:42:07.694 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-04-09 21:42:07.706 WARNING (SyncWorker_1) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2024-04-09 21:42:08.883 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-04-09 21:42:08.932 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-04-09 21:42:08.954 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-04-09 21:42:08.956 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-04-09 21:42:12.477 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.03.1
2024-04-09 21:42:13.923 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2024-04-09 21:42:13.940 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
2024-04-09 21:42:21.573 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.03.1 - 172.30.32.5
2024-04-09 21:42:21.621 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.03.0
2024-04-09 21:42:24.276 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2024-04-09 21:42:24.285 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_dns application
2024-04-09 21:42:35.638 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.03.0 - 172.30.32.3
2024-04-09 21:42:35.641 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-04-09 21:42:36.668 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
2024-04-09 21:42:37.665 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2024-04-09 21:42:38.571 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_audio application
2024-04-09 21:42:50.784 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
2024-04-09 21:42:50.803 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
2024-04-09 21:42:51.526 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
2024-04-09 21:42:52.203 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2024-04-09 21:42:52.213 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
2024-04-09 21:43:02.873 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
2024-04-09 21:43:02.874 INFO (MainThread) [supervisor.plugins.manager] dns does not have the latest version 2024.04.0, updating
2024-04-09 21:43:02.878 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/amd64-hassio-dns:2024.03.0 to ghcr.io/home-assistant/amd64-hassio-dns:2024.04.0
2024-04-09 21:43:02.880 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-dns with tag 2024.04.0.
2024-04-09 22:14:07.728 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping hassio_dns application
2024-04-09 22:14:16.568 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
2024-04-09 22:14:18.209 INFO (SyncWorker_1) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-dns:2024.03.0']
2024-04-09 22:14:19.241 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2024-04-09 22:14:25.458 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3
2024-04-09 22:14:25.729 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
2024-04-09 22:14:25.735 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
2024-04-09 22:14:25.742 INFO (MainThread) [supervisor.homeassistant.core] Setting up Home Assistant landingpage
2024-04-09 22:14:25.744 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag landingpage.
2024-04-09 22:17:51.951 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2024-04-09 22:17:52.445 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-04-09 22:17:56.161 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
2024-04-09 22:17:56.255 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 10.5 / BootSlot B
2024-04-09 22:17:57.706 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2024-04-09 22:17:57.708 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/45df7312 repository
2024-04-09 22:17:57.710 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2024-04-09 22:17:57.710 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-04-09 22:17:58.239 INFO (MainThread) [supervisor.store] Loading add-ons from store: 80 all - 80 new - 0 remove
2024-04-09 22:17:58.292 INFO (MainThread) [supervisor.addons.manager] Found 5 installed add-ons
2024-04-09 22:17:58.338 INFO (MainThread) [supervisor.backups.manager] Found 35 backup files
2024-04-09 22:17:58.880 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2024-04-09 22:17:58.880 INFO (MainThread) [supervisor.ingress] Loaded 2 ingress sessions
2024-04-09 22:17:58.880 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-04-09 22:17:58.881 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-04-09 22:17:58.881 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-04-09 22:17:58.881 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-09 22:17:58.885 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-04-09 22:17:58.886 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-04-09 22:17:58.886 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-09 22:17:58.887 INFO (MainThread) [__main__] Running Supervisor
2024-04-09 22:17:58.997 INFO (MainThread) [supervisor.os.manager] Rauc: B - marked slot kernel.1 as good
2024-04-09 22:17:59.017 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-04-09 22:17:59.487 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 1 add-ons
2024-04-09 22:18:00.502 ERROR (SyncWorker_2) [supervisor.docker.manager] Image homeassistant/amd64-addon-mosquitto:6.4.0 does not exist for addon_core_mosquitto
2024-04-09 22:18:00.505 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - addon / core_mosquitto
2024-04-09 22:18:00.505 INFO (MainThread) [supervisor.resolution.module] Create new issue missing_image - addon / core_mosquitto
2024-04-09 22:18:00.992 WARNING (MainThread) [supervisor.addons.manager] Can't start Add-on core_mosquitto
2024-04-09 22:18:05.996 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 1 add-ons
2024-04-09 22:18:07.104 ERROR (SyncWorker_0) [supervisor.docker.manager] Image homeassistant/amd64-addon-samba:12.3.1 does not exist for addon_core_samba
2024-04-09 22:18:07.106 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - addon / core_samba
2024-04-09 22:18:07.107 INFO (MainThread) [supervisor.resolution.module] Create new issue missing_image - addon / core_samba
2024-04-09 22:18:07.564 WARNING (MainThread) [supervisor.addons.manager] Can't start Add-on core_samba
2024-04-09 22:18:12.570 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2024-04-09 22:18:12.570 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 3 add-ons
2024-04-09 22:18:13.806 ERROR (SyncWorker_2) [supervisor.docker.manager] Image homeassistant/amd64-addon-configurator:5.8.0 does not exist for addon_core_configurator
2024-04-09 22:18:13.808 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - addon / core_configurator
2024-04-09 22:18:13.808 INFO (MainThread) [supervisor.resolution.module] Create new issue missing_image - addon / core_configurator
2024-04-09 22:18:14.286 WARNING (MainThread) [supervisor.addons.manager] Can't start Add-on core_configurator
2024-04-09 22:18:15.272 ERROR (SyncWorker_4) [supervisor.docker.manager] Image ghcr.io/hassio-addons/node-red/amd64:17.0.11 does not exist for addon_a0d7b954_nodered
2024-04-09 22:18:15.275 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - addon / a0d7b954_nodered
2024-04-09 22:18:15.275 INFO (MainThread) [supervisor.resolution.module] Create new issue missing_image - addon / a0d7b954_nodered
2024-04-09 22:18:15.741 WARNING (MainThread) [supervisor.addons.manager] Can't start Add-on a0d7b954_nodered
2024-04-09 22:18:16.745 ERROR (SyncWorker_2) [supervisor.docker.manager] Image zigbee2mqtt/zigbee2mqtt-amd64:1.36.1-1 does not exist for addon_45df7312_zigbee2mqtt
2024-04-09 22:18:16.747 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - addon / 45df7312_zigbee2mqtt
2024-04-09 22:18:16.747 INFO (MainThread) [supervisor.resolution.module] Create new issue missing_image - addon / 45df7312_zigbee2mqtt
2024-04-09 22:18:17.206 WARNING (MainThread) [supervisor.addons.manager] Can't start Add-on 45df7312_zigbee2mqtt
2024-04-09 22:18:22.795 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-04-09 22:18:22.797 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-04-09 22:18:22.797 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2024-04-09 22:18:22.798 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.4.2
2024-04-09 22:18:22.798 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.4.2.
2024-04-09 22:18:22.800 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-04-09 22:18:22.819 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-04-09 22:18:22.830 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-04-09 22:18:22.862 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-04-09 22:18:22.863 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-04-09 22:18:22.866 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-04-09 22:18:22.866 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-04-09 22:18:22.866 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-04-09 22:18:23.323 INFO (MainThread) [supervisor.host.services] Updating service information
2024-04-09 22:18:23.329 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-04-09 22:18:23.439 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-04-09 22:18:23.502 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-04-09 22:18:23.692 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-04-09 22:18:27.133 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-04-09 22:18:27.133 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-04-09 22:18:27.133 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-04-09 22:18:27.558 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-04-09 22:18:27.559 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-04-09 22:18:27.559 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-04-09 22:18:27.569 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-04-09 22:18:27.569 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-04-09 22:18:31.716 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-09 22:18:31.717 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-04-09 22:18:31.724 INFO (MainThread) [supervisor.resolution.fixups.addon_execute_repair] Installing image for addon %s
2024-04-09 22:18:31.726 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-addon-mosquitto with tag 6.4.0.
 楼主| 发表于 2024-4-13 22:05:52 | 显示全部楼层
各位大佬,问题已解决。是homeassistant在更新
GMT+8, 2025-12-18 10:44 , Processed in 1.115848 second(s), 14 queries , MemCached On.
